June 11, 20251 yr I am trying to host a discord bot that I am putting together which I have hosted on a private github repo being pushed to docker hub to install as a container on my unraid server.Issue is, it for some reason isn't updating the installed dependencies when I add a new one to my requirements.txtI am a huge novice when it comes to docker and was hoping someone can shed some light on what im doing wrong?Here is my dockerfile omitting private info# Use an official Python runtime as a parent imageFROM python:3.10-slim# Install git and upgrade pipRUN apt-get update && \apt-get install -y git && \pip install --upgrade pip && \rm -rf /var/lib/apt/lists/*# Set the working directoryWORKDIR /app# Copy the entrypoint script into the containerCOPY docker-entrypoint.sh /app/docker-entrypoint.sh# Make the entrypoint script executableRUN chmod +x /app/docker-entrypoint.sh# Set the entrypointENTRYPOINT ["/app/docker-entrypoint.sh"]# Default commandCMD []and here is my docker-entrypoint.sh fileset -eTARGET_BRANCH=${GIT_BRANCH:-main}APP_DIR="/app"GIT_SOURCE_DIR="/app_source_repo"if [ -z "$GITHUB_TOKEN" ]; then echo "Error: GITHUB_TOKEN not set."; exit 1; fiif [ -z "$GIT_REPO_URL" ]; then echo "Error: GIT_REPO_URL not set."; exit 1; fiecho "Ensuring git repository ($GIT_REPO_URL, branch $TARGET_BRANCH) is up to date in $GIT_SOURCE_DIR..."AUTH_GIT_REPO_URL=$(echo "$GIT_REPO_URL" | sed "s|https://|https://x-access-token:${GITHUB_TOKEN}@|")if [ -d "$GIT_SOURCE_DIR/.git" ]; thenecho "Existing repository found in $GIT_SOURCE_DIR. Attempting to update..."cd "$GIT_SOURCE_DIR"git config http.sslVerify truegit config pull.rebase falsecurrent_branch=$(git rev-parse --abbrev-ref HEAD)if [ "$current_branch" != "$TARGET_BRANCH" ]; thenecho "Current branch is $current_branch, switching to $TARGET_BRANCH..."git checkout "$TARGET_BRANCH" || git checkout -b "$TARGET_BRANCH" origin/"$TARGET_BRANCH"figit fetch origin "$TARGET_BRANCH"echo "Resetting to origin/$TARGET_BRANCH..."git reset --hard "origin/$TARGET_BRANCH"echo "Cleaning repository..."git clean -fdxcd "$APP_DIR"echo "Repository updated."elseecho "No existing repository found. Cloning fresh into $GIT_SOURCE_DIR..."rm -rf "$GIT_SOURCE_DIR"git clone --branch "$TARGET_BRANCH" --single-branch "$AUTH_GIT_REPO_URL" "$GIT_SOURCE_DIR"echo "Repository cloned."fiecho "Copying necessary files from $GIT_SOURCE_DIR to $APP_DIR..."mkdir -p "$APP_DIR/src"rm -rf "$APP_DIR/src"/* "$APP_DIR/requirements.txt"if [ -d "$GIT_SOURCE_DIR/src" ]; thencp -R "$GIT_SOURCE_DIR/src/." "$APP_DIR/src/"echo "Copied src/ directory."elseecho "Error: src/ directory not found in repository at $GIT_SOURCE_DIR/src."exit 1fiif [ -f "$GIT_SOURCE_DIR/requirements.txt" ]; thencp "$GIT_SOURCE_DIR/requirements.txt" "$APP_DIR/requirements.txt"echo "Copied requirements.txt."elseecho "Error: requirements.txt not found in repository at $GIT_SOURCE_DIR/requirements.txt."exit 1fiecho "Necessary files copied to $APP_DIR."echo "Installing/Updating Python dependencies from $APP_DIR/requirements.txt..."pip install --no-cache-dir -r "$APP_DIR/requirements.txt"cd "$APP_DIR/src"echo "Starting bot from $APP_DIR/src/bot.py..."exec python bot.py "$@"Any help would be much appreciated! docker-entrypoint.sh Dockerfile Edited June 11, 20251 yr by Abhi
