June 13, 20251 yr Help: USB errors causing WebUI lag – CMOS reset no longer works, BIOS time keeps changingAfter clearing the CMOS used to fix the issue, but now it no longer helps. I've also noticed that the BIOS time is not matching the actual time. I tried manually correcting it, but as soon as I boot into Unraid and then go back into BIOS, the time is off again.Whenever this issue occurs, the WebUI becomes very sluggish and unresponsive.Additionally, I don't know what device "usb2-2" refers to. I’ve already unplugged all USB devices from the system.Does anyone have any idea what might be causing these USB errors and the time drift? Any help would be greatly appreciated!
June 14, 20251 yr Community Expert 13 hours ago, Yang0hui said:Help: USB errors causing WebUI lagThis is typically caused by the Connect plugin with MSI boards that have Mystic Light function, try uninstalling it and reboot.13 hours ago, Yang0hui said:CMOS reset no longer works, BIOS time keeps changingThat sounds like a board issue.
June 14, 20251 yr Author 5 hours ago, JorgeB said:这通常是由具有 Mystic Light 功能的 MSI 主板的 Connect 插件引起的,请尝试卸载它并重新启动。这听起来像是董事会的问题。I think I've resolved the issue for now. I disabled USB 3.0 in the motherboard BIOS, restarted into Unraid, and there are no more error messages in the logs. The webUI is also no longer lagging. I tested the motherboard's coin battery as well, and it seems to be working normally. This issue feels quite strange, as I’ve never encountered anything like it before.
June 15, 20251 yr Community Expert 20 hours ago, Yang0hui said:I disabled USB 3.0 in the motherboard BIOSIf you still have the Connect plugin installed, please post new diags, just to make sure the errors are gone.
