Unmountable: wrong or no file system drive showing during data-rebuild and after data-rebuilt
Hello,
I have two drives that showed up with the Red X on them on a dual parity system. I went through these steps exactly.
This is a view before the drive replacement .
The bad drives were replaced and the rebuild process started.
datarebuiltduring.webpDuring the rebuild process it says "Unmountable: wrong or no file system" .
I assume I did something incorrectly, but is there a way to fix this or a possible explanation on what I did wrong?
tower-diagnostics-20250613-1339.zip
Check filesystem
Your logs are nothing but a container continuously restarting twice a minute so the cause is not visible. Might want to fix that first.
Edited by Kilrah
