Need Help Setting up Docker from Docker Hub
I'm trying to setup this docker from Docker Hub:
https://hub.docker.com/layers/jamesbrooks/perforce-server/latest/images/sha256-7c687f1e19cca773b8c2b05db55cd3b55960ca505ddb87a54696a14bb58d07e8
Which is based off this:
https://github.com/ambakshi/docker-perforce
I think the main issue I'm having is that I have no idea how to setup the paths for the container to work properly. Should I be making some new shares for this? or does the docker take care of that?
Here are the results of my poor attempt to let CA convert it:
docker run
  -d
  --name='perforce-server'
  --net='bridge'
  --pids-limit 2048
  -e TZ="America/Los_Angeles"
  -e HOST_OS="Unraid"
  -e HOST_HOSTNAME="Unraid01"
  -e HOST_CONTAINERNAME="perforce-server"
  -e 'NAME'='perforce-server'
  -e 'P4NAME'='master'
  -e 'P4TCP'='1666'
  -e 'P4PORT'='1666'
  -e 'P4USER'='admin'
  -e 'P4PASSWD'='pass12349ers'
  -e 'P4CASE'='-C0'
  -e 'P4CHARSET'='utf8'
  -e 'JNL_PREFIX'='master'
  -e 'P4HOME'='/p4'
  -e 'P4ROOT'='/p4/root'
  -e 'P4DEPOTS'='/p4/depots'
  -e 'P4CKP'='/p4/checkpoints'
  -e 'Community_Applications_Conversion'='true'
  -l net.unraid.docker.icon=''
  -p '1666:1666/tcp'
  -v '/mnt/user/appdata/perforce-server/':'/p4':'rw'
  -v '/mnt/user/appdata/perforce-server/logs/':'/opt/perforce/servers/server-instance/logs/':'ro' 'jamesbrooks/perforce-server:latest'
df8aeaeb05806897b60bb8893d24da060c16869c03683de1c8b093ed59454d80
docker: Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: exec: "./docker-entrypoint.sh": stat ./docker-entrypoint.sh: no such file or directory: unknown.
The command failed.
