July 6, 20251 yr Hey,I decided it was time to stop ignoring the reiserfs is depreciated message and do something about itI took the opportunity to move out a 2tb for a 6tb and add more storage. I move everything I can to the other drives using unbalanced. It can't move a few episodes but I'm not bothered, I pull the drive, add the new one and let it rebuild. it makes it resierfs without asking me what file system I wanted (so I think I missed something here). After the rebuild I finish moving the remaining files to Disk 7, spin the server down, format disk 1 for xfs and try to move everything over from disk 7. The plan being to repeat the cycle for the next few weeks and update every drive as I go.Something odd happens here, the move command fails at some stage and I restart it, and complete the move but disk 7 never gets any space back, and as you can see disk 1 is now fuller than disk 7 was!At the same time this has happened I start to see other odd behaviour, all the machines running kodi suddenly can't see the mariadb docker which keeps all the played statuses etcTrying to connect to the server via windows on 3 separate machines gets this:The docker images appear to run until you try to access them, and after they stop you get this:The log on //unraidtext error warn system array login Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck?Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370248 0x0 SD]Jul 6 16:48:59 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 45598 does not match to the expected one 1Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 478611531. Fsck?Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370160 0x0 SD]Jul 6 17:29:54 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0Jul 6 17:29:54 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Transmitter ID)Jul 6 17:29:54 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00001001/00002000Jul 6 17:29:54 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First)Jul 6 17:29:54 Wintermute kernel: xhci_hcd 0000:01:00.0: [12] Timeout Jul 6 17:29:54 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0Jul 6 17:38:17 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0Jul 6 17:38:17 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Transmitter ID)Jul 6 17:38:17 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00001001/00002000Jul 6 17:38:17 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First)Jul 6 17:38:17 Wintermute kernel: xhci_hcd 0000:01:00.0: [12] Timeout Jul 6 17:38:17 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0Jul 6 17:40:21 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0Jul 6 17:40:21 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Transmitter ID)Jul 6 17:40:21 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00001001/00002000Jul 6 17:40:21 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First)Jul 6 17:40:21 Wintermute kernel: xhci_hcd 0000:01:00.0: [12] Timeout Jul 6 17:40:21 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0Jul 6 17:54:08 Wintermute emhttpd: cmd: /usr/local/emhttp/plugins/fix.common.problems/scripts/newperms.shJul 6 18:00:11 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0Jul 6 18:00:11 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Transmitter ID)Jul 6 18:00:11 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00001001/00002000Jul 6 18:00:11 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First)Jul 6 18:00:11 Wintermute kernel: xhci_hcd 0000:01:00.0: [12] Timeout Jul 6 18:00:11 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0Jul 6 18:01:47 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0Jul 6 18:01:47 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Transmitter ID)Jul 6 18:01:47 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00001001/00002000Jul 6 18:01:47 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First)Jul 6 18:01:47 Wintermute kernel: xhci_hcd 0000:01:00.0: [12] Timeout Jul 6 18:01:47 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0Jul 6 18:11:24 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0Jul 6 18:11:24 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID)Jul 6 18:11:24 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000Jul 6 18:11:24 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 18:13:54 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0Jul 6 18:13:54 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Transmitter ID)Jul 6 18:13:54 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00001001/00002000Jul 6 18:13:54 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First)Jul 6 18:13:54 Wintermute kernel: xhci_hcd 0000:01:00.0: [12] Timeout Jul 6 18:13:54 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0Jul 6 18:35:13 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0Jul 6 18:35:13 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID)Jul 6 18:35:13 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000Jul 6 18:35:13 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 18:55:08 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0Jul 6 18:55:08 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Transmitter ID)Jul 6 18:55:08 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00001001/00002000Jul 6 18:55:08 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First)Jul 6 18:55:08 Wintermute kernel: xhci_hcd 0000:01:00.0: [12] Timeout Jul 6 18:55:08 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0Jul 6 18:59:16 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0Jul 6 18:59:16 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Transmitter ID)Jul 6 18:59:16 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00001001/00002000Jul 6 18:59:16 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First)Jul 6 18:59:16 Wintermute kernel: xhci_hcd 0000:01:00.0: [12] Timeout Jul 6 18:59:16 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0Jul 6 19:01:35 Wintermute nginx: 2025/07/06 19:01:35 [error] 8235#8235: *50052 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 192.168.50.48, server: , request: "GET /plugins/dynamix.local.master/include/LocalMaster.php HTTP/1.1", subrequest: "/auth-request.php", upstream: "fastcgi://unix:/var/run/php-fpm.sock", host: "192.168.50.245", referrer: "http://192.168.50.245/Tools/DockerSafeNewPerms"Jul 6 19:01:35 Wintermute nginx: 2025/07/06 19:01:35 [error] 8235#8235: *50052 auth request unexpected status: 504 while sending to client, client: 192.168.50.48, server: , request: "GET /plugins/dynamix.local.master/include/LocalMaster.php HTTP/1.1", host: "192.168.50.245", referrer: "http://192.168.50.245/Tools/DockerSafeNewPerms"Jul 6 19:05:51 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0Jul 6 19:05:51 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID)Jul 6 19:05:51 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000Jul 6 19:05:51 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 19:19:04 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0Jul 6 19:19:04 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)Jul 6 19:19:04 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000001/00002000Jul 6 19:19:04 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First)Jul 6 19:19:51 Wintermute kernel: docker0: port 2(veth08eb3e5) entered disabled stateJul 6 19:19:51 Wintermute kernel: veth4f4882b: renamed from eth0Jul 6 19:29:42 Wintermute nginx: 2025/07/06 19:29:42 [error] 8235#8235: *65133 limiting requests, excess: 20.953 by zone "authlimit", client: 192.168.50.48, server: , request: "PROPFIND /login HTTP/1.1", host: "192.168.50.245"Jul 6 19:29:42 Wintermute nginx: 2025/07/06 19:29:42 [error] 8235#8235: *65135 limiting requests, excess: 20.918 by zone "authlimit", client: 192.168.50.48, server: , request: "PROPFIND /login HTTP/1.1", host: "192.168.50.245"Jul 6 19:29:43 Wintermute nginx: 2025/07/06 19:29:43 [error] 8235#8235: *65137 limiting requests, excess: 20.881 by zone "authlimit", client: 192.168.50.48, server: , request: "PROPFIND /login HTTP/1.1", host: "192.168.50.245"Jul 6 19:35:11 Wintermute kernel: kvm_amd: SVM disabled (by BIOS) in MSR_VM_CR on CPU 1Jul 6 19:41:31 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0Jul 6 19:41:31 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Transmitter ID)Jul 6 19:41:31 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00001001/00002000Jul 6 19:41:31 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First)Jul 6 19:41:31 Wintermute kernel: xhci_hcd 0000:01:00.0: [12] Timeout Jul 6 19:41:31 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0Jul 6 19:42:06 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0Jul 6 19:42:06 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Transmitter ID)Jul 6 19:42:06 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00001001/00002000Jul 6 19:42:06 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First)Jul 6 19:42:06 Wintermute kernel: xhci_hcd 0000:01:00.0: [12] Timeout Jul 6 19:42:06 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0I've tried to rerun new docker safe permissions thinking it was that and it's all looking fine. I wanted to install a plugin to check for duplicates and free up space on disk 7 but no dockers will install and I can't manually look at the shares as I can't access them via windows.System logJul 6 15:58:24 Wintermute kernel: Linux version 6.6.78-Unraid (root@Develop-70) (gcc (GCC) 14.2.0, GNU ld version 2.43.1-slack151) #2 SMP PREEMPT_DYNAMIC Thu Feb 20 13:33:15 PST 2025 Jul 6 15:58:24 Wintermute kernel: Command line: BOOT_IMAGE=/bzimage initrd=/bzroot Jul 6 15:58:24 Wintermute kernel: BIOS-provided physical RAM map: Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009b3ff] usable Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x000000000009b400-0x000000000009ffff] reserved Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000003ffffff] usable Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x0000000004000000-0x0000000004009fff] ACPI NVS Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x000000000400a000-0x0000000009cfffff] usable Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x0000000009d00000-0x0000000009ffffff] reserved Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x000000000a000000-0x000000000affffff] usable Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x000000000b000000-0x000000000b01ffff] reserved Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x000000000b020000-0x000000009ba0afff] usable Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x000000009ba0b000-0x000000009bb55fff] reserved Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x000000009bb56000-0x000000009bc4afff] usable Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x000000009bc4b000-0x000000009c015fff] ACPI NVS Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x000000009c016000-0x000000009cf40fff] reserved Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x000000009cf41000-0x000000009effffff] usable Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x000000009f000000-0x00000000dfffffff] reserved Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x00000000fd800000-0x00000000fdffffff] reserved Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x00000000fea00000-0x00000000fea0ffff] reserved Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x00000000feb80000-0x00000000fec01fff] reserved Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x00000000fec30000-0x00000000fec30fff] reserved Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x00000000fed40000-0x00000000fed44fff] reserved Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x00000000fedc2000-0x00000000fedcffff] reserved Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x00000000fedd4000-0x00000000fedd5fff] reserved Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000feefffff] reserved Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved Jul 6 15:58:24 Wintermute kernel: BIOS-e820: [mem 0x0000000100000000-0x000000041f33ffff] usable Jul 6 15:58:24 Wintermute kernel: NX (Execute Disable) protection: active Jul 6 15:58:24 Wintermute kernel: APIC: Static calls initialized Jul 6 15:58:24 Wintermute kernel: SMBIOS 3.1.1 present. Jul 6 15:58:24 Wintermute kernel: DMI: Gigabyte Technology Co., Ltd. AB350M-Gaming 3/AB350M-Gaming 3-CF, BIOS F23d 04/17/2018 Jul 6 15:58:24 Wintermute kernel: tsc: Fast TSC calibration failed Jul 6 15:58:24 Wintermute kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved Jul 6 15:58:24 Wintermute kernel: e820: remove [mem 0x000a0000-0x000fffff] usable Jul 6 15:58:24 Wintermute kernel: last_pfn = 0x41f340 max_arch_pfn = 0x400000000 Jul 6 15:58:24 Wintermute kernel: MTRR map: 5 entries (3 fixed + 2 variable; max 20), built from 9 variable MTRRs Jul 6 15:58:24 Wintermute kernel: x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT Jul 6 15:58:24 Wintermute kernel: e820: update [mem 0xe0000000-0xffffffff] usable ==> reserved Jul 6 15:58:24 Wintermute kernel: last_pfn = 0x9f000 max_arch_pfn = 0x400000000 Jul 6 15:58:24 Wintermute kernel: Using GB pages for direct mapping Jul 6 15:58:24 Wintermute kernel: RAMDISK: [mem 0x7e050000-0x7fffffff] Jul 6 15:58:24 Wintermute kernel: ACPI: Early table checksum verification disabled Jul 6 15:58:24 Wintermute kernel: ACPI: RSDP 0x00000000000F05B0 000024 (v02 ALASKA) Jul 6 15:58:24 Wintermute kernel: ACPI: XSDT 0x000000009BC4B098 0000B4 (v01 ALASKA A M I 01072009 AMI 00010013) Jul 6 15:58:24 Wintermute kernel: ACPI: FACP 0x000000009BC51A20 000114 (v06 ALASKA A M I 01072009 AMI 00010013) Jul 6 15:58:24 Wintermute kernel: ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20230628/tbfadt-615) Jul 6 15:58:24 Wintermute kernel: ACPI: DSDT 0x000000009BC4B1E8 006833 (v02 ALASKA A M I 01072009 INTL 20120913) Jul 6 15:58:24 Wintermute kernel: ACPI: FACS 0x000000009BFFFE00 000040 Jul 6 15:58:24 Wintermute kernel: ACPI: APIC 0x000000009BC51B38 0000DE (v03 ALASKA A M I 01072009 AMI 00010013) Jul 6 15:58:24 Wintermute kernel: ACPI: FPDT 0x000000009BC51C18 000044 (v01 ALASKA A M I 01072009 AMI 00010013) Jul 6 15:58:24 Wintermute kernel: ACPI: FIDT 0x000000009BC51C60 00009C (v01 ALASKA A M I 01072009 AMI 00010013) Jul 6 15:58:24 Wintermute kernel: ACPI: SSDT 0x000000009BC51D00 005367 (v02 ALASKA A M I 00000002 MSFT 02000002) Jul 6 15:58:24 Wintermute kernel: ACPI: SSDT 0x000000009BC57068 0007DC (v01 ALASKA A M I 00000001 AMD 00000001) Jul 6 15:58:24 Wintermute kernel: ACPI: CRAT 0x000000009BC57848 000810 (v01 ALASKA A M I 00000001 AMD 00000001) Jul 6 15:58:24 Wintermute kernel: ACPI: CDIT 0x000000009BC58058 000029 (v01 ALASKA A M I 00000001 AMD 00000001) Jul 6 15:58:24 Wintermute kernel: ACPI: SSDT 0x000000009BC58088 002DBA (v01 ALASKA A M I 00000001 INTL 20120913) Jul 6 15:58:24 Wintermute kernel: ACPI: MCFG 0x000000009BC5AE48 00003C (v01 ALASKA A M I 01072009 MSFT 00010013) Jul 6 15:58:24 Wintermute kernel: ACPI: HPET 0x000000009BC5AE88 000038 (v01 ALASKA A M I 01072009 AMI 00000005) Jul 6 15:58:24 Wintermute kernel: ACPI: UEFI 0x000000009BC5AEC0 000042 (v01 ALASKA A M I 00000000 00000000) Jul 6 15:58:24 Wintermute kernel: ACPI: IVRS 0x000000009BC5AF08 0000D0 (v02 ALASKA A M I 00000001 AMD 00000000) Jul 6 15:58:24 Wintermute kernel: ACPI: SSDT 0x000000009BC5AFD8 0000F8 (v01 ALASKA A M I 00001000 INTL 20120913) Jul 6 15:58:24 Wintermute kernel: ACPI: SSDT 0x000000009BC5B0D0 000E96 (v01 ALASKA A M I 00000001 INTL 20120913) Jul 6 15:58:24 Wintermute kernel: ACPI: SSDT 0x000000009BC5BF68 000850 (v01 ALASKA A M I 00000001 INTL 20120913) Jul 6 15:58:24 Wintermute kernel: ACPI: SSDT 0x000000009BC5C7B8 001A41 (v01 ALASKA A M I 00000001 INTL 20120913) Jul 6 15:58:24 Wintermute kernel: ACPI: WSMT 0x000000009BC5E200 000028 (v01 ALASKA A M I 01072009 AMI 00010013) Jul 6 15:58:24 Wintermute kernel: ACPI: Reserving FACP table memory at [mem 0x9bc51a20-0x9bc51b33] Jul 6 15:58:24 Wintermute kernel: ACPI: Reserving DSDT table memory at [mem 0x9bc4b1e8-0x9bc51a1a] Jul 6 15:58:24 Wintermute kernel: ACPI: Reserving FACS table memory at [mem 0x9bfffe00-0x9bfffe3f] Jul 6 15:58:24 Wintermute kernel: ACPI: Reserving APIC table memory at [mem 0x9bc51b38-0x9bc51c15] Jul 6 15:58:24 Wintermute kernel: ACPI: Reserving FPDT table memory at [mem 0x9bc51c18-0x9bc51c5b] Jul 6 15:58:24 Wintermute kernel: ACPI: Reserving FIDT table memory at [mem 0x9bc51c60-0x9bc51cfb] Jul 6 15:58:24 Wintermute kernel: ACPI: Reserving SSDT table memory at [mem 0x9bc51d00-0x9bc57066] Jul 6 15:58:24 Wintermute kernel: ACPI: Reserving SSDT table memory at [mem 0x9bc57068-0x9bc57843] Jul 6 15:58:24 Wintermute kernel: ACPI: Reserving CRAT table memory at [mem 0x9bc57848-0x9bc58057] Jul 6 15:58:24 Wintermute kernel: ACPI: Reserving CDIT table memory at [mem 0x9bc58058-0x9bc58080] Jul 6 15:58:24 Wintermute kernel: ACPI: Reserving SSDT table memory at [mem 0x9bc58088-0x9bc5ae41] Jul 6 15:58:24 Wintermute kernel: ACPI: Reserving MCFG table memory at [mem 0x9bc5ae48-0x9bc5ae83] Jul 6 15:58:24 Wintermute kernel: ACPI: Reserving HPET table memory at [mem 0x9bc5ae88-0x9bc5aebf] Jul 6 15:58:24 Wintermute kernel: ACPI: Reserving UEFI table memory at [mem 0x9bc5aec0-0x9bc5af01] Jul 6 15:58:24 Wintermute kernel: ACPI: Reserving IVRS table memory at [mem 0x9bc5af08-0x9bc5afd7] Jul 6 15:58:24 Wintermute kernel: ACPI: Reserving SSDT table memory at [mem 0x9bc5afd8-0x9bc5b0cf] Jul 6 15:58:24 Wintermute kernel: ACPI: Reserving SSDT table memory at [mem 0x9bc5b0d0-0x9bc5bf65] Jul 6 15:58:24 Wintermute kernel: ACPI: Reserving SSDT table memory at [mem 0x9bc5bf68-0x9bc5c7b7] Jul 6 15:58:24 Wintermute kernel: ACPI: Reserving SSDT table memory at [mem 0x9bc5c7b8-0x9bc5e1f8] Jul 6 15:58:24 Wintermute kernel: ACPI: Reserving WSMT table memory at [mem 0x9bc5e200-0x9bc5e227] Jul 6 15:58:24 Wintermute kernel: No NUMA configuration found Jul 6 15:58:24 Wintermute kernel: Faking a node at [mem 0x0000000000000000-0x000000041f33ffff] Jul 6 15:58:24 Wintermute kernel: NODE_DATA(0) allocated [mem 0x41f33a000-0x41f33ffff] Jul 6 15:58:24 Wintermute kernel: Zone ranges: Jul 6 15:58:24 Wintermute kernel: DMA [mem 0x0000000000001000-0x0000000000ffffff] Jul 6 15:58:24 Wintermute kernel: DMA32 [mem 0x0000000001000000-0x00000000ffffffff] Jul 6 15:58:24 Wintermute kernel: Normal [mem 0x0000000100000000-0x000000041f33ffff] Jul 6 15:58:24 Wintermute kernel: Device empty Jul 6 15:58:24 Wintermute kernel: Movable zone start for each node Jul 6 15:58:24 Wintermute kernel: Early memory node ranges Jul 6 15:58:24 Wintermute kernel: node 0: [mem 0x0000000000001000-0x000000000009afff] Jul 6 15:58:24 Wintermute kernel: node 0: [mem 0x0000000000100000-0x0000000003ffffff] Jul 6 15:58:24 Wintermute kernel: node 0: [mem 0x000000000400a000-0x0000000009cfffff] Jul 6 15:58:24 Wintermute kernel: node 0: [mem 0x000000000a000000-0x000000000affffff] Jul 6 15:58:24 Wintermute kernel: node 0: [mem 0x000000000b020000-0x000000009ba0afff] Jul 6 15:58:24 Wintermute kernel: node 0: [mem 0x000000009bb56000-0x000000009bc4afff] Jul 6 15:58:24 Wintermute kernel: node 0: [mem 0x000000009cf41000-0x000000009effffff] Jul 6 15:58:24 Wintermute kernel: node 0: [mem 0x0000000100000000-0x000000041f33ffff] Jul 6 15:58:24 Wintermute kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000041f33ffff] Jul 6 15:58:24 Wintermute kernel: On node 0, zone DMA: 1 pages in unavailable ranges Jul 6 15:58:24 Wintermute kernel: On node 0, zone DMA: 101 pages in unavailable ranges Jul 6 15:58:24 Wintermute kernel: On node 0, zone DMA32: 10 pages in unavailable ranges Jul 6 15:58:24 Wintermute kernel: On node 0, zone DMA32: 768 pages in unavailable ranges Jul 6 15:58:24 Wintermute kernel: On node 0, zone DMA32: 32 pages in unavailable ranges Jul 6 15:58:24 Wintermute kernel: On node 0, zone DMA32: 331 pages in unavailable ranges Jul 6 15:58:24 Wintermute kernel: On node 0, zone DMA32: 4854 pages in unavailable ranges Jul 6 15:58:24 Wintermute kernel: On node 0, zone Normal: 4096 pages in unavailable ranges Jul 6 15:58:24 Wintermute kernel: On node 0, zone Normal: 3264 pages in unavailable ranges Jul 6 15:58:24 Wintermute kernel: ACPI: PM-Timer IO Port: 0x808 Jul 6 15:58:24 Wintermute kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1]) Jul 6 15:58:24 Wintermute kernel: IOAPIC[0]: apic_id 5, version 33, address 0xfec00000, GSI 0-23 Jul 6 15:58:24 Wintermute kernel: IOAPIC[1]: apic_id 6, version 33, address 0xfec01000, GSI 24-55 Jul 6 15:58:24 Wintermute kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl) Jul 6 15:58:24 Wintermute kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level) Jul 6 15:58:24 Wintermute kernel: ACPI: Using ACPI (MADT) for SMP configuration information Jul 6 15:58:24 Wintermute kernel: ACPI: HPET id: 0x10228201 base: 0xfed00000 Jul 6 15:58:24 Wintermute kernel: smpboot: Allowing 16 CPUs, 12 hotplug CPUs Jul 6 15:58:24 Wintermute kernel: [mem 0xe0000000-0xf7ffffff] available for PCI devices Jul 6 15:58:24 Wintermute kernel: Booting paravirtualized kernel on bare hardware Jul 6 15:58:24 Wintermute kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns Jul 6 15:58:24 Wintermute kernel: setup_percpu: NR_CPUS:256 nr_cpumask_bits:16 nr_cpu_ids:16 nr_node_ids:1 Jul 6 15:58:24 Wintermute kernel: percpu: Embedded 56 pages/cpu s191336 r8192 d29848 u262144 Jul 6 15:58:24 Wintermute kernel: pcpu-alloc: s191336 r8192 d29848 u262144 alloc=1*2097152 Jul 6 15:58:24 Wintermute kernel: pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15 Jul 6 15:58:24 Wintermute kernel: Kernel command line: BOOT_IMAGE=/bzimage initrd=/bzroot Jul 6 15:58:24 Wintermute kernel: Unknown kernel command line parameters "BOOT_IMAGE=/bzimage", will be passed to user space. Jul 6 15:58:24 Wintermute kernel: random: crng init done Jul 6 15:58:24 Wintermute kernel: Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear) Jul 6 15:58:24 Wintermute kernel: Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) Jul 6 15:58:24 Wintermute kernel: Fallback order for Node 0: 0 Jul 6 15:58:24 Wintermute kernel: Built 1 zonelists, mobility grouping on. Total pages: 3857317 Jul 6 15:58:24 Wintermute kernel: Policy zone: Normal Jul 6 15:58:24 Wintermute kernel: mem auto-init: stack:off, heap alloc:off, heap free:off Jul 6 15:58:24 Wintermute kernel: software IO TLB: area num 16. Jul 6 15:58:24 Wintermute kernel: Memory: 15270408K/15674812K available (14336K kernel code, 1990K rwdata, 5568K rodata, 2900K init, 2040K bss, 404148K reserved, 0K cma-reserved) Jul 6 15:58:24 Wintermute kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1 Jul 6 15:58:24 Wintermute kernel: ftrace: allocating 48027 entries in 188 pages Jul 6 15:58:24 Wintermute kernel: ftrace: allocated 188 pages with 5 groups Jul 6 15:58:24 Wintermute kernel: Dynamic Preempt: voluntary Jul 6 15:58:24 Wintermute kernel: rcu: Preemptible hierarchical RCU implementation. Jul 6 15:58:24 Wintermute kernel: rcu: RCU event tracing is enabled. Jul 6 15:58:24 Wintermute kernel: rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=16. Jul 6 15:58:24 Wintermute kernel: Trampoline variant of Tasks RCU enabled. Jul 6 15:58:24 Wintermute kernel: Rude variant of Tasks RCU enabled. Jul 6 15:58:24 Wintermute kernel: Tracing variant of Tasks RCU enabled. Jul 6 15:58:24 Wintermute kernel: rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies. Jul 6 15:58:24 Wintermute kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=16 Jul 6 15:58:24 Wintermute kernel: NR_IRQS: 16640, nr_irqs: 1096, preallocated irqs: 16 Jul 6 15:58:24 Wintermute kernel: rcu: srcu_init: Setting srcu_struct sizes based on contention. Jul 6 15:58:24 Wintermute kernel: Console: colour VGA+ 80x25 Jul 6 15:58:24 Wintermute kernel: printk: console [tty0] enabled Jul 6 15:58:24 Wintermute kernel: ACPI: Core revision 20230628 Jul 6 15:58:24 Wintermute kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns Jul 6 15:58:24 Wintermute kernel: APIC: Switch to symmetric I/O mode setup Jul 6 15:58:24 Wintermute kernel: AMD-Vi: Using global IVHD EFR:0x4f77ef22294ada, EFR2:0x0 Jul 6 15:58:24 Wintermute kernel: APIC: Switched APIC routing to: physical flat Jul 6 15:58:24 Wintermute kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1 Jul 6 15:58:24 Wintermute kernel: tsc: PIT calibration matches HPET. 1 loops Jul 6 15:58:24 Wintermute kernel: tsc: Detected 3493.009 MHz processor Jul 6 15:58:24 Wintermute kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x325984ccf6b, max_idle_ns: 440795246717 ns Jul 6 15:58:24 Wintermute kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 6986.01 BogoMIPS (lpj=3493009) Jul 6 15:58:24 Wintermute kernel: AMD Zen1 DIV0 bug detected. Disable SMT for full protection. Jul 6 15:58:24 Wintermute kernel: LVT offset 1 assigned for vector 0xf9 Jul 6 15:58:24 Wintermute kernel: LVT offset 2 assigned for vector 0xf4 Jul 6 15:58:24 Wintermute kernel: process: using mwait in idle threads Jul 6 15:58:24 Wintermute kernel: Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 512 Jul 6 15:58:24 Wintermute kernel: Last level dTLB entries: 4KB 1536, 2MB 1536, 4MB 768, 1GB 0 Jul 6 15:58:24 Wintermute kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization Jul 6 15:58:24 Wintermute kernel: Spectre V2 : Mitigation: Retpolines Jul 6 15:58:24 Wintermute kernel: Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch Jul 6 15:58:24 Wintermute kernel: Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT Jul 6 15:58:24 Wintermute kernel: Spectre V2 : Enabling Speculation Barrier for firmware calls Jul 6 15:58:24 Wintermute kernel: RETBleed: Mitigation: untrained return thunk Jul 6 15:58:24 Wintermute kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier Jul 6 15:58:24 Wintermute kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl Jul 6 15:58:24 Wintermute kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers' Jul 6 15:58:24 Wintermute kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers' Jul 6 15:58:24 Wintermute kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers' Jul 6 15:58:24 Wintermute kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256 Jul 6 15:58:24 Wintermute kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compacted' format. Jul 6 15:58:24 Wintermute kernel: Freeing SMP alternatives memory: 24K Jul 6 15:58:24 Wintermute kernel: pid_max: default: 32768 minimum: 301 Jul 6 15:58:24 Wintermute kernel: Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear) Jul 6 15:58:24 Wintermute kernel: Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear) Jul 6 15:58:24 Wintermute kernel: smpboot: CPU0: AMD Ryzen 3 2200G with Radeon Vega Graphics (family: 0x17, model: 0x11, stepping: 0x0) Jul 6 15:58:24 Wintermute kernel: RCU Tasks: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=16. Jul 6 15:58:24 Wintermute kernel: RCU Tasks Rude: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=16. Jul 6 15:58:24 Wintermute kernel: RCU Tasks Trace: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=16. Jul 6 15:58:24 Wintermute kernel: Performance Events: Fam17h+ core perfctr, AMD PMU driver. Jul 6 15:58:24 Wintermute kernel: ... version: 0 Jul 6 15:58:24 Wintermute kernel: ... bit width: 48 Jul 6 15:58:24 Wintermute kernel: ... generic registers: 6 Jul 6 15:58:24 Wintermute kernel: ... value mask: 0000ffffffffffff Jul 6 15:58:24 Wintermute kernel: ... max period: 00007fffffffffff Jul 6 15:58:24 Wintermute kernel: ... fixed-purpose events: 0 Jul 6 15:58:24 Wintermute kernel: ... event mask: 000000000000003f Jul 6 15:58:24 Wintermute kernel: signal: max sigframe size: 1776 Jul 6 15:58:24 Wintermute kernel: rcu: Hierarchical SRCU implementation. Jul 6 15:58:24 Wintermute kernel: rcu: Max phase no-delay instances is 400. Jul 6 15:58:24 Wintermute kernel: smp: Bringing up secondary CPUs ... Jul 6 15:58:24 Wintermute kernel: smpboot: x86: Booting SMP configuration: Jul 6 15:58:24 Wintermute kernel: .... node #0, CPUs: #1 #2 #3 Jul 6 15:58:24 Wintermute kernel: smp: Brought up 1 node, 4 CPUs Jul 6 15:58:24 Wintermute kernel: smpboot: Max logical packages: 4 Jul 6 15:58:24 Wintermute kernel: smpboot: Total of 4 processors activated (27944.07 BogoMIPS) Jul 6 15:58:24 Wintermute kernel: devtmpfs: initialized Jul 6 15:58:24 Wintermute kernel: x86/mm: Memory block size: 128MB Jul 6 15:58:24 Wintermute kernel: ACPI: PM: Registering ACPI NVS region [mem 0x04000000-0x04009fff] (40960 bytes) Jul 6 15:58:24 Wintermute kernel: ACPI: PM: Registering ACPI NVS region [mem 0x9bc4b000-0x9c015fff] (3977216 bytes) Jul 6 15:58:24 Wintermute kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns Jul 6 15:58:24 Wintermute kernel: futex hash table entries: 4096 (order: 6, 262144 bytes, linear) Jul 6 15:58:24 Wintermute kernel: pinctrl core: initialized pinctrl subsystem Jul 6 15:58:24 Wintermute kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family Jul 6 15:58:24 Wintermute kernel: audit: initializing netlink subsys (disabled) Jul 6 15:58:24 Wintermute kernel: audit: type=2000 audit(1751813847.143:1): state=initialized audit_enabled=0 res=1 Jul 6 15:58:24 Wintermute kernel: thermal_sys: Registered thermal governor 'fair_share' Jul 6 15:58:24 Wintermute kernel: thermal_sys: Registered thermal governor 'bang_bang' Jul 6 15:58:24 Wintermute kernel: thermal_sys: Registered thermal governor 'step_wise' Jul 6 15:58:24 Wintermute kernel: thermal_sys: Registered thermal governor 'user_space' Jul 6 15:58:24 Wintermute kernel: cpuidle: using governor ladder Jul 6 15:58:24 Wintermute kernel: cpuidle: using governor menu Jul 6 15:58:24 Wintermute kernel: PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000) Jul 6 15:58:24 Wintermute kernel: PCI: Using configuration type 1 for base access Jul 6 15:58:24 Wintermute kernel: kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible. Jul 6 15:58:24 Wintermute kernel: HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages Jul 6 15:58:24 Wintermute kernel: HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page Jul 6 15:58:24 Wintermute kernel: HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages Jul 6 15:58:24 Wintermute kernel: HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page Jul 6 15:58:24 Wintermute kernel: raid6: avx2x4 gen() 22015 MB/s Jul 6 15:58:24 Wintermute kernel: raid6: avx2x2 gen() 27511 MB/s Jul 6 15:58:24 Wintermute kernel: raid6: avx2x1 gen() 25063 MB/s Jul 6 15:58:24 Wintermute kernel: raid6: using algorithm avx2x2 gen() 27511 MB/s Jul 6 15:58:24 Wintermute kernel: raid6: .... xor() 16127 MB/s, rmw enabled Jul 6 15:58:24 Wintermute kernel: raid6: using avx2x2 recovery algorithm Jul 6 15:58:24 Wintermute kernel: ACPI: Added _OSI(Module Device) Jul 6 15:58:24 Wintermute kernel: ACPI: Added _OSI(Processor Device) Jul 6 15:58:24 Wintermute kernel: ACPI: Added _OSI(3.0 _SCP Extensions) Jul 6 15:58:24 Wintermute kernel: ACPI: Added _OSI(Processor Aggregator Device) Jul 6 15:58:24 Wintermute kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.SMIC], AE_ALREADY_EXISTS (20230628/dswload2-326) Jul 6 15:58:24 Wintermute kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220) Jul 6 15:58:24 Wintermute kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.SMIB], AE_ALREADY_EXISTS (20230628/dsfield-637) Jul 6 15:58:24 Wintermute kernel: ACPI: 8 ACPI AML tables successfully acquired and loaded Jul 6 15:58:24 Wintermute kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored Jul 6 15:58:24 Wintermute kernel: ACPI: _OSC evaluation for CPUs failed, trying _PDC Jul 6 15:58:24 Wintermute kernel: ACPI: Interpreter enabled Jul 6 15:58:24 Wintermute kernel: ACPI: PM: (supports S0 S3 S5) Jul 6 15:58:24 Wintermute kernel: ACPI: Using IOAPIC for interrupt routing Jul 6 15:58:24 Wintermute kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug Jul 6 15:58:24 Wintermute kernel: PCI: Using E820 reservations for host bridge windows Jul 6 15:58:24 Wintermute kernel: ACPI: Enabled 2 GPEs in block 00 to 1F Jul 6 15:58:24 Wintermute kernel: ACPI: \_SB_.P0ST: New power resource Jul 6 15:58:24 Wintermute kernel: ACPI: \_SB_.P3ST: New power resource Jul 6 15:58:24 Wintermute kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff]) Jul 6 15:58:24 Wintermute kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3] Jul 6 15:58:24 Wintermute kernel: acpi PNP0A08:00: _OSC: platform does not support [LTR] Jul 6 15:58:24 Wintermute kernel: acpi PNP0A08:00: _OSC: OS now controls [PME AER PCIeCapability] Jul 6 15:58:24 Wintermute kernel: acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge Jul 6 15:58:24 Wintermute kernel: PCI host bridge to bus 0000:00 Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:00: root bus resource [io 0x0000-0x03af window] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7 window] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:00: root bus resource [io 0x03b0-0x03df window] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000dffff window] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:00: root bus resource [mem 0xe0000000-0xfec2ffff window] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:00: root bus resource [mem 0xfee00000-0xffffffff window] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:00: root bus resource [bus 00-ff] Jul 6 15:58:24 Wintermute kernel: pci 0000:00:00.0: [1022:15d0] type 00 class 0x060000 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:00.2: [1022:15d1] type 00 class 0x080600 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:01.0: [1022:1452] type 00 class 0x060000 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:01.2: [1022:15d3] type 01 class 0x060400 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:01.2: PME# supported from D0 D3hot D3cold Jul 6 15:58:24 Wintermute kernel: pci 0000:00:08.0: [1022:1452] type 00 class 0x060000 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:08.1: [1022:15db] type 01 class 0x060400 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:08.1: enabling Extended Tags Jul 6 15:58:24 Wintermute kernel: pci 0000:00:08.1: PME# supported from D0 D3hot D3cold Jul 6 15:58:24 Wintermute kernel: pci 0000:00:08.2: [1022:15dc] type 01 class 0x060400 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:08.2: enabling Extended Tags Jul 6 15:58:24 Wintermute kernel: pci 0000:00:08.2: PME# supported from D0 D3hot D3cold Jul 6 15:58:24 Wintermute kernel: pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:14.3: [1022:790e] type 00 class 0x060100 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:18.0: [1022:15e8] type 00 class 0x060000 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:18.1: [1022:15e9] type 00 class 0x060000 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:18.2: [1022:15ea] type 00 class 0x060000 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:18.3: [1022:15eb] type 00 class 0x060000 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:18.4: [1022:15ec] type 00 class 0x060000 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:18.5: [1022:15ed] type 00 class 0x060000 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:18.6: [1022:15ee] type 00 class 0x060000 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:18.7: [1022:15ef] type 00 class 0x060000 Jul 6 15:58:24 Wintermute kernel: pci 0000:01:00.0: [1022:43bb] type 00 class 0x0c0330 Jul 6 15:58:24 Wintermute kernel: pci 0000:01:00.0: reg 0x10: [mem 0xfe8a0000-0xfe8a7fff 64bit] Jul 6 15:58:24 Wintermute kernel: pci 0000:01:00.0: PME# supported from D3hot D3cold Jul 6 15:58:24 Wintermute kernel: pci 0000:01:00.1: [1022:43b7] type 00 class 0x010601 Jul 6 15:58:24 Wintermute kernel: pci 0000:01:00.1: reg 0x24: [mem 0xfe880000-0xfe89ffff] Jul 6 15:58:24 Wintermute kernel: pci 0000:01:00.1: reg 0x30: [mem 0xfe800000-0xfe87ffff pref] Jul 6 15:58:24 Wintermute kernel: pci 0000:01:00.1: PME# supported from D3hot D3cold Jul 6 15:58:24 Wintermute kernel: pci 0000:01:00.2: [1022:43b2] type 01 class 0x060400 Jul 6 15:58:24 Wintermute kernel: pci 0000:01:00.2: PME# supported from D3hot D3cold Jul 6 15:58:24 Wintermute kernel: pci 0000:00:01.2: PCI bridge to [bus 01-05] Jul 6 15:58:24 Wintermute kernel: pci 0000:00:01.2: bridge window [io 0xf000-0xffff] Jul 6 15:58:24 Wintermute kernel: pci 0000:00:01.2: bridge window [mem 0xfe600000-0xfe8fffff] Jul 6 15:58:24 Wintermute kernel: pci 0000:00:01.2: bridge window [mem 0xf0300000-0xf03fffff 64bit pref] Jul 6 15:58:24 Wintermute kernel: pci 0000:02:00.0: [1022:43b4] type 01 class 0x060400 Jul 6 15:58:24 Wintermute kernel: pci 0000:02:00.0: PME# supported from D3hot D3cold Jul 6 15:58:24 Wintermute kernel: pci 0000:02:01.0: [1022:43b4] type 01 class 0x060400 Jul 6 15:58:24 Wintermute kernel: pci 0000:02:01.0: PME# supported from D3hot D3cold Jul 6 15:58:24 Wintermute kernel: pci 0000:02:04.0: [1022:43b4] type 01 class 0x060400 Jul 6 15:58:24 Wintermute kernel: pci 0000:02:04.0: PME# supported from D3hot D3cold Jul 6 15:58:24 Wintermute kernel: pci 0000:01:00.2: PCI bridge to [bus 02-05] Jul 6 15:58:24 Wintermute kernel: pci 0000:01:00.2: bridge window [io 0xf000-0xffff] Jul 6 15:58:24 Wintermute kernel: pci 0000:01:00.2: bridge window [mem 0xfe600000-0xfe7fffff] Jul 6 15:58:24 Wintermute kernel: pci 0000:01:00.2: bridge window [mem 0xf0300000-0xf03fffff 64bit pref] Jul 6 15:58:24 Wintermute kernel: pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000 Jul 6 15:58:24 Wintermute kernel: pci 0000:03:00.0: reg 0x10: [io 0xf000-0xf0ff] Jul 6 15:58:24 Wintermute kernel: pci 0000:03:00.0: reg 0x18: [mem 0xfe700000-0xfe700fff 64bit] Jul 6 15:58:24 Wintermute kernel: pci 0000:03:00.0: reg 0x20: [mem 0xf0300000-0xf0303fff 64bit pref] Jul 6 15:58:24 Wintermute kernel: pci 0000:03:00.0: supports D1 D2 Jul 6 15:58:24 Wintermute kernel: pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold Jul 6 15:58:24 Wintermute kernel: pci 0000:02:00.0: PCI bridge to [bus 03] Jul 6 15:58:24 Wintermute kernel: pci 0000:02:00.0: bridge window [io 0xf000-0xffff] Jul 6 15:58:24 Wintermute kernel: pci 0000:02:00.0: bridge window [mem 0xfe700000-0xfe7fffff] Jul 6 15:58:24 Wintermute kernel: pci 0000:02:00.0: bridge window [mem 0xf0300000-0xf03fffff 64bit pref] Jul 6 15:58:24 Wintermute kernel: pci 0000:04:00.0: [1b21:1064] type 00 class 0x010601 Jul 6 15:58:24 Wintermute kernel: pci 0000:04:00.0: reg 0x10: [mem 0xfe682000-0xfe683fff] Jul 6 15:58:24 Wintermute kernel: pci 0000:04:00.0: reg 0x24: [mem 0xfe680000-0xfe681fff] Jul 6 15:58:24 Wintermute kernel: pci 0000:04:00.0: reg 0x30: [mem 0xfe600000-0xfe67ffff pref] Jul 6 15:58:24 Wintermute kernel: pci 0000:04:00.0: PME# supported from D0 D3hot D3cold Jul 6 15:58:24 Wintermute kernel: pci 0000:04:00.0: 4.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x1 link at 0000:02:01.0 (capable of 7.876 Gb/s with 8.0 GT/s PCIe x1 link) Jul 6 15:58:24 Wintermute kernel: pci 0000:02:01.0: PCI bridge to [bus 04] Jul 6 15:58:24 Wintermute kernel: pci 0000:02:01.0: bridge window [mem 0xfe600000-0xfe6fffff] Jul 6 15:58:24 Wintermute kernel: pci 0000:02:04.0: PCI bridge to [bus 05] Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.0: [1002:15dd] type 00 class 0x030000 Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.0: reg 0x10: [mem 0xe0000000-0xefffffff 64bit pref] Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.0: reg 0x18: [mem 0xf0000000-0xf01fffff 64bit pref] Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.0: reg 0x20: [io 0xe000-0xe0ff] Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.0: reg 0x24: [mem 0xfe500000-0xfe57ffff] Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.0: enabling Extended Tags Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff] Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.0: PME# supported from D1 D2 D3hot D3cold Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.1: [1002:15de] type 00 class 0x040300 Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.1: reg 0x10: [mem 0xfe588000-0xfe58bfff] Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.1: enabling Extended Tags Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.1: PME# supported from D1 D2 D3hot D3cold Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.2: [1022:15df] type 00 class 0x108000 Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.2: reg 0x18: [mem 0xfe400000-0xfe4fffff] Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.2: reg 0x24: [mem 0xfe58c000-0xfe58dfff] Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.2: enabling Extended Tags Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.3: [1022:15e0] type 00 class 0x0c0330 Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.3: reg 0x10: [mem 0xfe300000-0xfe3fffff 64bit] Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.3: enabling Extended Tags Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.3: PME# supported from D0 D3hot D3cold Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.4: [1022:15e1] type 00 class 0x0c0330 Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.4: reg 0x10: [mem 0xfe200000-0xfe2fffff 64bit] Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.4: enabling Extended Tags Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.4: PME# supported from D0 D3hot D3cold Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.6: [1022:15e3] type 00 class 0x040300 Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.6: reg 0x10: [mem 0xfe580000-0xfe587fff] Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.6: enabling Extended Tags Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.6: PME# supported from D0 D3hot D3cold Jul 6 15:58:24 Wintermute kernel: pci 0000:00:08.1: PCI bridge to [bus 06] Jul 6 15:58:24 Wintermute kernel: pci 0000:00:08.1: bridge window [io 0xe000-0xefff] Jul 6 15:58:24 Wintermute kernel: pci 0000:00:08.1: bridge window [mem 0xfe200000-0xfe5fffff] Jul 6 15:58:24 Wintermute kernel: pci 0000:00:08.1: bridge window [mem 0xe0000000-0xf01fffff 64bit pref] Jul 6 15:58:24 Wintermute kernel: pci 0000:07:00.0: [1022:7901] type 00 class 0x010601 Jul 6 15:58:24 Wintermute kernel: pci 0000:07:00.0: reg 0x24: [mem 0xfe900000-0xfe9007ff] Jul 6 15:58:24 Wintermute kernel: pci 0000:07:00.0: enabling Extended Tags Jul 6 15:58:24 Wintermute kernel: pci 0000:07:00.0: PME# supported from D3hot D3cold Jul 6 15:58:24 Wintermute kernel: pci 0000:00:08.2: PCI bridge to [bus 07] Jul 6 15:58:24 Wintermute kernel: pci 0000:00:08.2: bridge window [mem 0xfe900000-0xfe9fffff] Jul 6 15:58:24 Wintermute kernel: ACPI: PCI: Interrupt link LNKA configured for IRQ 0 Jul 6 15:58:24 Wintermute kernel: ACPI: PCI: Interrupt link LNKB configured for IRQ 0 Jul 6 15:58:24 Wintermute kernel: ACPI: PCI: Interrupt link LNKC configured for IRQ 0 Jul 6 15:58:24 Wintermute kernel: ACPI: PCI: Interrupt link LNKD configured for IRQ 0 Jul 6 15:58:24 Wintermute kernel: ACPI: PCI: Interrupt link LNKE configured for IRQ 0 Jul 6 15:58:24 Wintermute kernel: ACPI: PCI: Interrupt link LNKF configured for IRQ 0 Jul 6 15:58:24 Wintermute kernel: ACPI: PCI: Interrupt link LNKG configured for IRQ 0 Jul 6 15:58:24 Wintermute kernel: ACPI: PCI: Interrupt link LNKH configured for IRQ 0 Jul 6 15:58:24 Wintermute kernel: iommu: Default domain type: Passthrough Jul 6 15:58:24 Wintermute kernel: SCSI subsystem initialized Jul 6 15:58:24 Wintermute kernel: libata version 3.00 loaded. Jul 6 15:58:24 Wintermute kernel: ACPI: bus type USB registered Jul 6 15:58:24 Wintermute kernel: usbcore: registered new interface driver usbfs Jul 6 15:58:24 Wintermute kernel: usbcore: registered new interface driver hub Jul 6 15:58:24 Wintermute kernel: usbcore: registered new device driver usb Jul 6 15:58:24 Wintermute kernel: pps_core: LinuxPPS API ver. 1 registered Jul 6 15:58:24 Wintermute kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]> Jul 6 15:58:24 Wintermute kernel: PTP clock support registered Jul 6 15:58:24 Wintermute kernel: PCI: Using ACPI for IRQ routing Jul 6 15:58:24 Wintermute kernel: PCI: pci_cache_line_size set to 64 bytes Jul 6 15:58:24 Wintermute kernel: e820: reserve RAM buffer [mem 0x0009b400-0x0009ffff] Jul 6 15:58:24 Wintermute kernel: e820: reserve RAM buffer [mem 0x09d00000-0x0bffffff] Jul 6 15:58:24 Wintermute kernel: e820: reserve RAM buffer [mem 0x0b000000-0x0bffffff] Jul 6 15:58:24 Wintermute kernel: e820: reserve RAM buffer [mem 0x9ba0b000-0x9bffffff] Jul 6 15:58:24 Wintermute kernel: e820: reserve RAM buffer [mem 0x9bc4b000-0x9bffffff] Jul 6 15:58:24 Wintermute kernel: e820: reserve RAM buffer [mem 0x9f000000-0x9fffffff] Jul 6 15:58:24 Wintermute kernel: e820: reserve RAM buffer [mem 0x41f340000-0x41fffffff] Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.0: vgaarb: setting as boot VGA device Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.0: vgaarb: bridge control possible Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none Jul 6 15:58:24 Wintermute kernel: vgaarb: loaded Jul 6 15:58:24 Wintermute kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0 Jul 6 15:58:24 Wintermute kernel: hpet0: 3 comparators, 32-bit 14.318180 MHz counter Jul 6 15:58:24 Wintermute kernel: clocksource: Switched to clocksource tsc-early Jul 6 15:58:24 Wintermute kernel: FS-Cache: Loaded Jul 6 15:58:24 Wintermute kernel: pnp: PnP ACPI init Jul 6 15:58:24 Wintermute kernel: system 00:00: [mem 0xf8000000-0xfbffffff] has been reserved Jul 6 15:58:24 Wintermute kernel: system 00:01: [mem 0xfeb80000-0xfebfffff] could not be reserved Jul 6 15:58:24 Wintermute kernel: system 00:03: [io 0x0a00-0x0a2f] has been reserved Jul 6 15:58:24 Wintermute kernel: system 00:03: [io 0x0a30-0x0a3f] has been reserved Jul 6 15:58:24 Wintermute kernel: system 00:03: [io 0x0a40-0x0a4f] has been reserved Jul 6 15:58:24 Wintermute kernel: pnp 00:04: [dma 0 disabled] Jul 6 15:58:24 Wintermute kernel: pnp 00:05: [dma 0 disabled] Jul 6 15:58:24 Wintermute kernel: pnp 00:06: [dma 0 disabled] Jul 6 15:58:24 Wintermute kernel: system 00:07: [io 0x04d0-0x04d1] has been reserved Jul 6 15:58:24 Wintermute kernel: system 00:07: [io 0x040b] has been reserved Jul 6 15:58:24 Wintermute kernel: system 00:07: [io 0x04d6] has been reserved Jul 6 15:58:24 Wintermute kernel: system 00:07: [io 0x0c00-0x0c01] has been reserved Jul 6 15:58:24 Wintermute kernel: system 00:07: [io 0x0c14] has been reserved Jul 6 15:58:24 Wintermute kernel: system 00:07: [io 0x0c50-0x0c51] has been reserved Jul 6 15:58:24 Wintermute kernel: system 00:07: [io 0x0c52] has been reserved Jul 6 15:58:24 Wintermute kernel: system 00:07: [io 0x0c6c] has been reserved Jul 6 15:58:24 Wintermute kernel: system 00:07: [io 0x0c6f] has been reserved Jul 6 15:58:24 Wintermute kernel: system 00:07: [io 0x0cd0-0x0cd1] has been reserved Jul 6 15:58:24 Wintermute kernel: system 00:07: [io 0x0cd2-0x0cd3] has been reserved Jul 6 15:58:24 Wintermute kernel: system 00:07: [io 0x0cd4-0x0cd5] has been reserved Jul 6 15:58:24 Wintermute kernel: system 00:07: [io 0x0cd6-0x0cd7] has been reserved Jul 6 15:58:24 Wintermute kernel: system 00:07: [io 0x0cd8-0x0cdf] has been reserved Jul 6 15:58:24 Wintermute kernel: system 00:07: [io 0x0800-0x089f] has been reserved Jul 6 15:58:24 Wintermute kernel: system 00:07: [io 0x0b00-0x0b0f] has been reserved Jul 6 15:58:24 Wintermute kernel: system 00:07: [io 0x0b20-0x0b3f] has been reserved Jul 6 15:58:24 Wintermute kernel: system 00:07: [io 0x0900-0x090f] has been reserved Jul 6 15:58:24 Wintermute kernel: system 00:07: [io 0x0910-0x091f] has been reserved Jul 6 15:58:24 Wintermute kernel: system 00:07: [mem 0xfec00000-0xfec00fff] could not be reserved Jul 6 15:58:24 Wintermute kernel: system 00:07: [mem 0xfec01000-0xfec01fff] could not be reserved Jul 6 15:58:24 Wintermute kernel: system 00:07: [mem 0xfedc0000-0xfedc0fff] has been reserved Jul 6 15:58:24 Wintermute kernel: system 00:07: [mem 0xfee00000-0xfee00fff] has been reserved Jul 6 15:58:24 Wintermute kernel: system 00:07: [mem 0xfed80000-0xfed8ffff] could not be reserved Jul 6 15:58:24 Wintermute kernel: system 00:07: [mem 0xfec10000-0xfec10fff] has been reserved Jul 6 15:58:24 Wintermute kernel: system 00:07: [mem 0xff000000-0xffffffff] has been reserved Jul 6 15:58:24 Wintermute kernel: pnp: PnP ACPI: found 8 devices Jul 6 15:58:24 Wintermute kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns Jul 6 15:58:24 Wintermute kernel: NET: Registered PF_INET protocol family Jul 6 15:58:24 Wintermute kernel: IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear) Jul 6 15:58:24 Wintermute kernel: tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear) Jul 6 15:58:24 Wintermute kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) Jul 6 15:58:24 Wintermute kernel: TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear) Jul 6 15:58:24 Wintermute kernel: TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear) Jul 6 15:58:24 Wintermute kernel: TCP: Hash tables configured (established 131072 bind 65536) Jul 6 15:58:24 Wintermute kernel: UDP hash table entries: 8192 (order: 6, 262144 bytes, linear) Jul 6 15:58:24 Wintermute kernel: UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear) Jul 6 15:58:24 Wintermute kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family Jul 6 15:58:24 Wintermute kernel: pci 0000:02:00.0: PCI bridge to [bus 03] Jul 6 15:58:24 Wintermute kernel: pci 0000:02:00.0: bridge window [io 0xf000-0xffff] Jul 6 15:58:24 Wintermute kernel: pci 0000:02:00.0: bridge window [mem 0xfe700000-0xfe7fffff] Jul 6 15:58:24 Wintermute kernel: pci 0000:02:00.0: bridge window [mem 0xf0300000-0xf03fffff 64bit pref] Jul 6 15:58:24 Wintermute kernel: pci 0000:02:01.0: PCI bridge to [bus 04] Jul 6 15:58:24 Wintermute kernel: pci 0000:02:01.0: bridge window [mem 0xfe600000-0xfe6fffff] Jul 6 15:58:24 Wintermute kernel: pci 0000:02:04.0: PCI bridge to [bus 05] Jul 6 15:58:24 Wintermute kernel: pci 0000:01:00.2: PCI bridge to [bus 02-05] Jul 6 15:58:24 Wintermute kernel: pci 0000:01:00.2: bridge window [io 0xf000-0xffff] Jul 6 15:58:24 Wintermute kernel: pci 0000:01:00.2: bridge window [mem 0xfe600000-0xfe7fffff] Jul 6 15:58:24 Wintermute kernel: pci 0000:01:00.2: bridge window [mem 0xf0300000-0xf03fffff 64bit pref] Jul 6 15:58:24 Wintermute kernel: pci 0000:00:01.2: PCI bridge to [bus 01-05] Jul 6 15:58:24 Wintermute kernel: pci 0000:00:01.2: bridge window [io 0xf000-0xffff] Jul 6 15:58:24 Wintermute kernel: pci 0000:00:01.2: bridge window [mem 0xfe600000-0xfe8fffff] Jul 6 15:58:24 Wintermute kernel: pci 0000:00:01.2: bridge window [mem 0xf0300000-0xf03fffff 64bit pref] Jul 6 15:58:24 Wintermute kernel: pci 0000:00:08.1: PCI bridge to [bus 06] Jul 6 15:58:24 Wintermute kernel: pci 0000:00:08.1: bridge window [io 0xe000-0xefff] Jul 6 15:58:24 Wintermute kernel: pci 0000:00:08.1: bridge window [mem 0xfe200000-0xfe5fffff] Jul 6 15:58:24 Wintermute kernel: pci 0000:00:08.1: bridge window [mem 0xe0000000-0xf01fffff 64bit pref] Jul 6 15:58:24 Wintermute kernel: pci 0000:00:08.2: PCI bridge to [bus 07] Jul 6 15:58:24 Wintermute kernel: pci 0000:00:08.2: bridge window [mem 0xfe900000-0xfe9fffff] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:00: resource 4 [io 0x0000-0x03af window] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7 window] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:00: resource 6 [io 0x03b0-0x03df window] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000dffff window] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:00: resource 9 [mem 0xe0000000-0xfec2ffff window] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:00: resource 10 [mem 0xfee00000-0xffffffff window] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:01: resource 0 [io 0xf000-0xffff] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:01: resource 1 [mem 0xfe600000-0xfe8fffff] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:01: resource 2 [mem 0xf0300000-0xf03fffff 64bit pref] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:02: resource 0 [io 0xf000-0xffff] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:02: resource 1 [mem 0xfe600000-0xfe7fffff] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:02: resource 2 [mem 0xf0300000-0xf03fffff 64bit pref] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:03: resource 0 [io 0xf000-0xffff] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:03: resource 1 [mem 0xfe700000-0xfe7fffff] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:03: resource 2 [mem 0xf0300000-0xf03fffff 64bit pref] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:04: resource 1 [mem 0xfe600000-0xfe6fffff] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:06: resource 0 [io 0xe000-0xefff] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:06: resource 1 [mem 0xfe200000-0xfe5fffff] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:06: resource 2 [mem 0xe0000000-0xf01fffff 64bit pref] Jul 6 15:58:24 Wintermute kernel: pci_bus 0000:07: resource 1 [mem 0xfe900000-0xfe9fffff] Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.1: D0 power state depends on 0000:06:00.0 Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.3: extending delay after power-on from D3hot to 20 msec Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.4: extending delay after power-on from D3hot to 20 msec Jul 6 15:58:24 Wintermute kernel: PCI: CLS 64 bytes, default 64 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported Jul 6 15:58:24 Wintermute kernel: Unpacking initramfs... Jul 6 15:58:24 Wintermute kernel: pci 0000:00:01.0: Adding to iommu group 0 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:01.2: Adding to iommu group 1 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:08.0: Adding to iommu group 2 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:08.1: Adding to iommu group 3 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:08.2: Adding to iommu group 2 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:14.0: Adding to iommu group 4 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:14.3: Adding to iommu group 4 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:18.0: Adding to iommu group 5 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:18.1: Adding to iommu group 5 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:18.2: Adding to iommu group 5 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:18.3: Adding to iommu group 5 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:18.4: Adding to iommu group 5 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:18.5: Adding to iommu group 5 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:18.6: Adding to iommu group 5 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:18.7: Adding to iommu group 5 Jul 6 15:58:24 Wintermute kernel: pci 0000:01:00.0: Adding to iommu group 6 Jul 6 15:58:24 Wintermute kernel: pci 0000:01:00.1: Adding to iommu group 6 Jul 6 15:58:24 Wintermute kernel: pci 0000:01:00.2: Adding to iommu group 6 Jul 6 15:58:24 Wintermute kernel: pci 0000:02:00.0: Adding to iommu group 6 Jul 6 15:58:24 Wintermute kernel: pci 0000:02:01.0: Adding to iommu group 6 Jul 6 15:58:24 Wintermute kernel: pci 0000:02:04.0: Adding to iommu group 6 Jul 6 15:58:24 Wintermute kernel: pci 0000:03:00.0: Adding to iommu group 6 Jul 6 15:58:24 Wintermute kernel: pci 0000:04:00.0: Adding to iommu group 6 Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.0: Adding to iommu group 7 Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.1: Adding to iommu group 8 Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.2: Adding to iommu group 8 Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.3: Adding to iommu group 8 Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.4: Adding to iommu group 8 Jul 6 15:58:24 Wintermute kernel: pci 0000:06:00.6: Adding to iommu group 8 Jul 6 15:58:24 Wintermute kernel: pci 0000:07:00.0: Adding to iommu group 2 Jul 6 15:58:24 Wintermute kernel: pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40 Jul 6 15:58:24 Wintermute kernel: AMD-Vi: Extended features (0x4f77ef22294ada, 0x0): PPR NX GT IA GA PC GA_vAPIC Jul 6 15:58:24 Wintermute kernel: AMD-Vi: Interrupt remapping enabled Jul 6 15:58:24 Wintermute kernel: AMD-Vi: Virtual APIC enabled Jul 6 15:58:24 Wintermute kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB) Jul 6 15:58:24 Wintermute kernel: software IO TLB: mapped [mem 0x0000000097a0b000-0x000000009ba0b000] (64MB) Jul 6 15:58:24 Wintermute kernel: amd_uncore: 4 amd_df counters detected Jul 6 15:58:24 Wintermute kernel: amd_uncore: 6 amd_l3 counters detected Jul 6 15:58:24 Wintermute kernel: perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank). Jul 6 15:58:24 Wintermute kernel: Initialise system trusted keyrings Jul 6 15:58:24 Wintermute kernel: workingset: timestamp_bits=40 max_order=22 bucket_order=0 Jul 6 15:58:24 Wintermute kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher Jul 6 15:58:24 Wintermute kernel: fuse: init (API version 7.39) Jul 6 15:58:24 Wintermute kernel: SGI XFS with ACLs, security attributes, no debug enabled Jul 6 15:58:24 Wintermute kernel: xor: automatically using best checksumming function avx Jul 6 15:58:24 Wintermute kernel: Key type asymmetric registered Jul 6 15:58:24 Wintermute kernel: Asymmetric key parser 'x509' registered Jul 6 15:58:24 Wintermute kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249) Jul 6 15:58:24 Wintermute kernel: io scheduler mq-deadline registered Jul 6 15:58:24 Wintermute kernel: io scheduler kyber registered Jul 6 15:58:24 Wintermute kernel: io scheduler bfq registered Jul 6 15:58:24 Wintermute kernel: pcieport 0000:00:01.2: PME: Signaling with IRQ 26 Jul 6 15:58:24 Wintermute kernel: pcieport 0000:00:01.2: AER: enabled with IRQ 26 Jul 6 15:58:24 Wintermute kernel: pcieport 0000:00:08.1: PME: Signaling with IRQ 27 Jul 6 15:58:24 Wintermute kernel: pcieport 0000:00:08.2: PME: Signaling with IRQ 28 Jul 6 15:58:24 Wintermute kernel: IPMI message handler: version 39.2 Jul 6 15:58:24 Wintermute kernel: Monitor-Mwait will be used to enter C-1 state Jul 6 15:58:24 Wintermute kernel: ACPI: \_PR_.P000: Found 2 idle states Jul 6 15:58:24 Wintermute kernel: ACPI: \_PR_.P001: Found 2 idle states Jul 6 15:58:24 Wintermute kernel: ACPI: \_PR_.P002: Found 2 idle states Jul 6 15:58:24 Wintermute kernel: ACPI: \_PR_.P003: Found 2 idle states Jul 6 15:58:24 Wintermute kernel: Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled Jul 6 15:58:24 Wintermute kernel: 00:05: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A Jul 6 15:58:24 Wintermute kernel: 00:06: ttyS1 at I/O 0x2f8 (irq = 10, base_baud = 115200) is a 16550A Jul 6 15:58:24 Wintermute kernel: tsc: Refined TSC clocksource calibration: 3493.422 MHz Jul 6 15:58:24 Wintermute kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x325b0b626e6, max_idle_ns: 440795343347 ns Jul 6 15:58:24 Wintermute kernel: clocksource: Switched to clocksource tsc Jul 6 15:58:24 Wintermute kernel: Freeing initrd memory: 32448K Jul 6 15:58:24 Wintermute kernel: lp: driver loaded but no devices found Jul 6 15:58:24 Wintermute kernel: Hangcheck: starting hangcheck timer 0.9.1 (tick is 180 seconds, margin is 60 seconds). Jul 6 15:58:24 Wintermute kernel: parport_pc 00:04: reported by Plug and Play ACPI Jul 6 15:58:24 Wintermute kernel: parport0: PC-style at 0x378, irq 5 [PCSPP(,...)] Jul 6 15:58:24 Wintermute kernel: lp0: using parport0 (interrupt-driven). Jul 6 15:58:24 Wintermute kernel: loop: module loaded Jul 6 15:58:24 Wintermute kernel: Rounding down aligned max_sectors from 4294967295 to 4294967288 Jul 6 15:58:24 Wintermute kernel: db_root: cannot open: /etc/target Jul 6 15:58:24 Wintermute kernel: VFIO - User Level meta-driver version: 0.3 Jul 6 15:58:24 Wintermute kernel: xhci_hcd 0000:01:00.0: xHCI Host Controller Jul 6 15:58:24 Wintermute kernel: xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1 Jul 6 15:58:24 Wintermute kernel: xhci_hcd 0000:01:00.0: hcc params 0x0200ef81 hci version 0x110 quirks 0x0000010048000010 Jul 6 15:58:24 Wintermute kernel: xhci_hcd 0000:01:00.0: xHCI Host Controller Jul 6 15:58:24 Wintermute kernel: xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2 Jul 6 15:58:24 Wintermute kernel: xhci_hcd 0000:01:00.0: Host supports USB 3.1 Enhanced SuperSpeed Jul 6 15:58:24 Wintermute kernel: hub 1-0:1.0: USB hub found Jul 6 15:58:24 Wintermute kernel: hub 1-0:1.0: 10 ports detected Jul 6 15:58:24 Wintermute kernel: usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. Jul 6 15:58:24 Wintermute kernel: hub 2-0:1.0: USB hub found Jul 6 15:58:24 Wintermute kernel: hub 2-0:1.0: 4 ports detected Jul 6 15:58:24 Wintermute kernel: usb: port power management may be unreliable Jul 6 15:58:24 Wintermute kernel: xhci_hcd 0000:06:00.3: xHCI Host Controller Jul 6 15:58:24 Wintermute kernel: xhci_hcd 0000:06:00.3: new USB bus registered, assigned bus number 3 Jul 6 15:58:24 Wintermute kernel: xhci_hcd 0000:06:00.3: hcc params 0x0270ffe5 hci version 0x110 quirks 0x0000000840000010 Jul 6 15:58:24 Wintermute kernel: xhci_hcd 0000:06:00.3: xHCI Host Controller Jul 6 15:58:24 Wintermute kernel: xhci_hcd 0000:06:00.3: new USB bus registered, assigned bus number 4 Jul 6 15:58:24 Wintermute kernel: xhci_hcd 0000:06:00.3: Host supports USB 3.1 Enhanced SuperSpeed Jul 6 15:58:24 Wintermute kernel: hub 3-0:1.0: USB hub found Jul 6 15:58:24 Wintermute kernel: hub 3-0:1.0: 4 ports detected Jul 6 15:58:24 Wintermute kernel: usb usb4: We don't know the algorithms for LPM for this host, disabling LPM. Jul 6 15:58:24 Wintermute kernel: hub 4-0:1.0: USB hub found Jul 6 15:58:24 Wintermute kernel: hub 4-0:1.0: 4 ports detected Jul 6 15:58:24 Wintermute kernel: xhci_hcd 0000:06:00.4: xHCI Host Controller Jul 6 15:58:24 Wintermute kernel: xhci_hcd 0000:06:00.4: new USB bus registered, assigned bus number 5 Jul 6 15:58:24 Wintermute kernel: xhci_hcd 0000:06:00.4: hcc params 0x0260ffe5 hci version 0x110 quirks 0x0000000840000010 Jul 6 15:58:24 Wintermute kernel: xhci_hcd 0000:06:00.4: xHCI Host Controller Jul 6 15:58:24 Wintermute kernel: xhci_hcd 0000:06:00.4: new USB bus registered, assigned bus number 6 Jul 6 15:58:24 Wintermute kernel: xhci_hcd 0000:06:00.4: Host supports USB 3.1 Enhanced SuperSpeed Jul 6 15:58:24 Wintermute kernel: hub 5-0:1.0: USB hub found Jul 6 15:58:24 Wintermute kernel: hub 5-0:1.0: 1 port detected Jul 6 15:58:24 Wintermute kernel: usb usb6: We don't know the algorithms for LPM for this host, disabling LPM. Jul 6 15:58:24 Wintermute kernel: hub 6-0:1.0: USB hub found Jul 6 15:58:24 Wintermute kernel: hub 6-0:1.0: 1 port detected Jul 6 15:58:24 Wintermute kernel: usbcore: registered new interface driver uas Jul 6 15:58:24 Wintermute kernel: usbcore: registered new interface driver usb-storage Jul 6 15:58:24 Wintermute kernel: i8042: PNP: No PS/2 controller found. Jul 6 15:58:24 Wintermute kernel: mousedev: PS/2 mouse device common for all mice Jul 6 15:58:24 Wintermute kernel: usbcore: registered new interface driver synaptics_usb Jul 6 15:58:24 Wintermute kernel: input: PC Speaker as /devices/platform/pcspkr/input/input0 Jul 6 15:58:24 Wintermute kernel: rtc_cmos 00:02: RTC can wake from S4 Jul 6 15:58:24 Wintermute kernel: rtc_cmos 00:02: registered as rtc0 Jul 6 15:58:24 Wintermute kernel: rtc_cmos 00:02: setting system clock to 2025-07-06T14:57:29 UTC (1751813849) Jul 6 15:58:24 Wintermute kernel: rtc_cmos 00:02: alarms up to one month, y3k, 114 bytes nvram, hpet irqs Jul 6 15:58:24 Wintermute kernel: amd_pstate: the _CPC object is not present in SBIOS or ACPI disabled Jul 6 15:58:24 Wintermute kernel: hid: raw HID events driver (C) Jiri Kosina Jul 6 15:58:24 Wintermute kernel: usbcore: registered new interface driver usbhid Jul 6 15:58:24 Wintermute kernel: usbhid: USB HID core driver Jul 6 15:58:24 Wintermute kernel: ipip: IPv4 and MPLS over IPv4 tunneling driver Jul 6 15:58:24 Wintermute kernel: NET: Registered PF_INET6 protocol family Jul 6 15:58:24 Wintermute kernel: Segment Routing with IPv6 Jul 6 15:58:24 Wintermute kernel: RPL Segment Routing with IPv6 Jul 6 15:58:24 Wintermute kernel: In-situ OAM (IOAM) with IPv6 Jul 6 15:58:24 Wintermute kernel: 9pnet: Installing 9P2000 support Jul 6 15:58:24 Wintermute kernel: microcode: CPU1: patch_level=0x0810100b Jul 6 15:58:24 Wintermute kernel: microcode: CPU3: patch_level=0x0810100b Jul 6 15:58:24 Wintermute kernel: microcode: CPU0: patch_level=0x0810100b Jul 6 15:58:24 Wintermute kernel: microcode: CPU2: patch_level=0x0810100b Jul 6 15:58:24 Wintermute kernel: microcode: Microcode Update Driver: v2.2. Jul 6 15:58:24 Wintermute kernel: IPI shorthand broadcast: enabled Jul 6 15:58:24 Wintermute kernel: sched_clock: Marking stable (2179002206, -8882245)->(2176369261, -6249300) Jul 6 15:58:24 Wintermute kernel: registered taskstats version 1 Jul 6 15:58:24 Wintermute kernel: Loading compiled-in X.509 certificates Jul 6 15:58:24 Wintermute kernel: Btrfs loaded, zoned=no, fsverity=no Jul 6 15:58:24 Wintermute kernel: clk: Disabling unused clocks Jul 6 15:58:24 Wintermute kernel: usb 1-1: new high-speed USB device number 2 using xhci_hcd Jul 6 15:58:24 Wintermute kernel: usb-storage 1-1:1.0: USB Mass Storage device detected Jul 6 15:58:24 Wintermute kernel: scsi host0: usb-storage 1-1:1.0 Jul 6 15:58:24 Wintermute kernel: scsi 0:0:0:0: Direct-Access Lexar JD FireFly 3000 PQ: 0 ANSI: 0 CCS Jul 6 15:58:24 Wintermute kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0 Jul 6 15:58:24 Wintermute kernel: sd 0:0:0:0: [sda] 15663104 512-byte logical blocks: (8.02 GB/7.47 GiB) Jul 6 15:58:24 Wintermute kernel: sd 0:0:0:0: [sda] Write Protect is off Jul 6 15:58:24 Wintermute kernel: sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00 Jul 6 15:58:24 Wintermute kernel: sd 0:0:0:0: [sda] No Caching mode page found Jul 6 15:58:24 Wintermute kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through Jul 6 15:58:24 Wintermute kernel: sda: sda1 Jul 6 15:58:24 Wintermute kernel: sd 0:0:0:0: [sda] Attached SCSI removable disk Jul 6 15:58:24 Wintermute kernel: floppy0: no floppy controllers found Jul 6 15:58:24 Wintermute kernel: Freeing unused kernel image (initmem) memory: 2900K Jul 6 15:58:24 Wintermute kernel: Write protecting the kernel read-only data: 20480k Jul 6 15:58:24 Wintermute kernel: Freeing unused kernel image (rodata/data gap) memory: 576K Jul 6 15:58:24 Wintermute kernel: rodata_test: all tests were successful Jul 6 15:58:24 Wintermute kernel: Run /init as init process Jul 6 15:58:24 Wintermute kernel: with arguments: Jul 6 15:58:24 Wintermute kernel: /init Jul 6 15:58:24 Wintermute kernel: with environment: Jul 6 15:58:24 Wintermute kernel: HOME=/ Jul 6 15:58:24 Wintermute kernel: TERM=linux Jul 6 15:58:24 Wintermute kernel: BOOT_IMAGE=/bzimage Jul 6 15:58:24 Wintermute kernel: loop0: detected capacity change from 0 to 1141304 Jul 6 15:58:24 Wintermute kernel: loop1: detected capacity change from 0 to 182736 Jul 6 15:58:24 Wintermute kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1 Jul 6 15:58:24 Wintermute kernel: ACPI: button: Power Button [PWRB] Jul 6 15:58:24 Wintermute kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2 Jul 6 15:58:24 Wintermute kernel: ACPI: button: Power Button [PWRF] Jul 6 15:58:24 Wintermute kernel: ahci 0000:01:00.1: version 3.0 Jul 6 15:58:24 Wintermute kernel: ahci 0000:01:00.1: SSS flag set, parallel bus scan disabled Jul 6 15:58:24 Wintermute kernel: ahci 0000:01:00.1: AHCI 0001.0301 32 slots 8 ports 6 Gbps 0x33 impl SATA mode Jul 6 15:58:24 Wintermute kernel: ahci 0000:01:00.1: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part sxs deso sadm sds apst Jul 6 15:58:24 Wintermute kernel: acpi_cpufreq: overriding BIOS provided _PSD data Jul 6 15:58:24 Wintermute kernel: scsi host1: ahci Jul 6 15:58:24 Wintermute kernel: scsi host2: ahci Jul 6 15:58:24 Wintermute kernel: Linux agpgart interface v0.103 Jul 6 15:58:24 Wintermute kernel: piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0 Jul 6 15:58:24 Wintermute kernel: piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection Jul 6 15:58:24 Wintermute kernel: scsi host3: ahci Jul 6 15:58:24 Wintermute kernel: piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20 Jul 6 15:58:24 Wintermute kernel: ccp 0000:06:00.2: psp: unable to access the device: you might be running a broken BIOS. Jul 6 15:58:24 Wintermute kernel: scsi host4: ahci Jul 6 15:58:24 Wintermute kernel: scsi host5: ahci Jul 6 15:58:24 Wintermute kernel: scsi host6: ahci Jul 6 15:58:24 Wintermute kernel: scsi host7: ahci Jul 6 15:58:24 Wintermute kernel: scsi host8: ahci Jul 6 15:58:24 Wintermute kernel: ata1: SATA max UDMA/133 abar m131072@0xfe880000 port 0xfe880100 irq 48 Jul 6 15:58:24 Wintermute kernel: ata2: SATA max UDMA/133 abar m131072@0xfe880000 port 0xfe880180 irq 48 Jul 6 15:58:24 Wintermute kernel: ata3: DUMMY Jul 6 15:58:24 Wintermute kernel: ata4: DUMMY Jul 6 15:58:24 Wintermute kernel: ata5: SATA max UDMA/133 abar m131072@0xfe880000 port 0xfe880300 irq 48 Jul 6 15:58:24 Wintermute kernel: ata6: SATA max UDMA/133 abar m131072@0xfe880000 port 0xfe880380 irq 48 Jul 6 15:58:24 Wintermute kernel: ata7: DUMMY Jul 6 15:58:24 Wintermute kernel: ata8: DUMMY Jul 6 15:58:24 Wintermute kernel: ahci 0000:04:00.0: SSS flag set, parallel bus scan disabled Jul 6 15:58:24 Wintermute kernel: RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer Jul 6 15:58:24 Wintermute kernel: RAPL PMU: hw unit of domain package 2^-16 Joules Jul 6 15:58:24 Wintermute kernel: r8169 0000:03:00.0 eth0: RTL8168g/8111g, e0:d5:5e:29:6b:fb, XID 4c0, IRQ 53 Jul 6 15:58:24 Wintermute kernel: r8169 0000:03:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko] Jul 6 15:58:24 Wintermute kernel: ahci 0000:04:00.0: AHCI 0001.0301 32 slots 24 ports 6 Gbps 0xffff0f impl SATA mode Jul 6 15:58:24 Wintermute kernel: ahci 0000:04:00.0: flags: 64bit ncq sntf stag pm led clo only pio sxs deso sadm sds apst Jul 6 15:58:24 Wintermute kernel: scsi host9: ahci Jul 6 15:58:24 Wintermute kernel: scsi host10: ahci Jul 6 15:58:24 Wintermute kernel: scsi host11: ahci Jul 6 15:58:24 Wintermute kernel: scsi host12: ahci Jul 6 15:58:24 Wintermute kernel: scsi host13: ahci Jul 6 15:58:24 Wintermute kernel: ACPI: bus type drm_connector registered Jul 6 15:58:24 Wintermute kernel: scsi host14: ahci Jul 6 15:58:24 Wintermute kernel: scsi host15: ahci Jul 6 15:58:24 Wintermute kernel: scsi host16: ahci Jul 6 15:58:24 Wintermute kernel: scsi host17: ahci Jul 6 15:58:24 Wintermute kernel: scsi host18: ahci Jul 6 15:58:24 Wintermute kernel: scsi host19: ahci Jul 6 15:58:24 Wintermute kernel: scsi host20: ahci Jul 6 15:58:24 Wintermute kernel: scsi host21: ahci Jul 6 15:58:24 Wintermute kernel: scsi host22: ahci Jul 6 15:58:24 Wintermute kernel: scsi host23: ahci Jul 6 15:58:24 Wintermute kernel: scsi host24: ahci Jul 6 15:58:24 Wintermute kernel: scsi host25: ahci Jul 6 15:58:24 Wintermute kernel: scsi host26: ahci Jul 6 15:58:24 Wintermute kernel: scsi host27: ahci Jul 6 15:58:24 Wintermute kernel: scsi host28: ahci Jul 6 15:58:24 Wintermute kernel: scsi host29: ahci Jul 6 15:58:24 Wintermute kernel: scsi host30: ahci Jul 6 15:58:24 Wintermute kernel: scsi host31: ahci Jul 6 15:58:24 Wintermute kernel: scsi host32: ahci Jul 6 15:58:24 Wintermute kernel: ata9: SATA max UDMA/133 abar m8192@0xfe680000 port 0xfe680100 irq 52 Jul 6 15:58:24 Wintermute kernel: ata10: SATA max UDMA/133 abar m8192@0xfe680000 port 0xfe680180 irq 52 Jul 6 15:58:24 Wintermute kernel: ata11: SATA max UDMA/133 abar m8192@0xfe680000 port 0xfe680200 irq 52 Jul 6 15:58:24 Wintermute kernel: ata12: SATA max UDMA/133 abar m8192@0xfe680000 port 0xfe680280 irq 52 Jul 6 15:58:24 Wintermute kernel: ata13: DUMMY Jul 6 15:58:24 Wintermute kernel: ata14: DUMMY Jul 6 15:58:24 Wintermute kernel: ata15: DUMMY Jul 6 15:58:24 Wintermute kernel: ata16: DUMMY Jul 6 15:58:24 Wintermute kernel: ata17: SATA max UDMA/133 abar m8192@0xfe680000 port 0xfe680500 irq 52 Jul 6 15:58:24 Wintermute kernel: ata18: SATA max UDMA/133 abar m8192@0xfe680000 port 0xfe680580 irq 52 Jul 6 15:58:24 Wintermute kernel: ata19: SATA max UDMA/133 abar m8192@0xfe680000 port 0xfe680600 irq 52 Jul 6 15:58:24 Wintermute kernel: ata20: SATA max UDMA/133 abar m8192@0xfe680000 port 0xfe680680 irq 52 Jul 6 15:58:24 Wintermute kernel: ata21: SATA max UDMA/133 abar m8192@0xfe680000 port 0xfe680700 irq 52 Jul 6 15:58:24 Wintermute kernel: ata22: SATA max UDMA/133 abar m8192@0xfe680000 port 0xfe680780 irq 52 Jul 6 15:58:24 Wintermute kernel: ata23: SATA max UDMA/133 abar m8192@0xfe680000 port 0xfe680800 irq 52 Jul 6 15:58:24 Wintermute kernel: ata24: SATA max UDMA/133 abar m8192@0xfe680000 port 0xfe680880 irq 52 Jul 6 15:58:24 Wintermute kernel: ata25: SATA max UDMA/133 abar m8192@0xfe680000 port 0xfe680900 irq 52 Jul 6 15:58:24 Wintermute kernel: ata26: SATA max UDMA/133 abar m8192@0xfe680000 port 0xfe680980 irq 52 Jul 6 15:58:24 Wintermute kernel: ata27: SATA max UDMA/133 abar m8192@0xfe680000 port 0xfe680a00 irq 52 Jul 6 15:58:24 Wintermute kernel: ata28: SATA max UDMA/133 abar m8192@0xfe680000 port 0xfe680a80 irq 52 Jul 6 15:58:24 Wintermute kernel: ata29: SATA max UDMA/133 abar m8192@0xfe680000 port 0xfe680b00 irq 52 Jul 6 15:58:24 Wintermute kernel: ata30: SATA max UDMA/133 abar m8192@0xfe680000 port 0xfe680b80 irq 52 Jul 6 15:58:24 Wintermute kernel: ata31: SATA max UDMA/133 abar m8192@0xfe680000 port 0xfe680c00 irq 52 Jul 6 15:58:24 Wintermute kernel: ata32: SATA max UDMA/133 abar m8192@0xfe680000 port 0xfe680c80 irq 52 Jul 6 15:58:24 Wintermute kernel: ahci 0000:07:00.0: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode Jul 6 15:58:24 Wintermute kernel: ahci 0000:07:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part sxs Jul 6 15:58:24 Wintermute kernel: scsi host33: ahci Jul 6 15:58:24 Wintermute kernel: scsi host34: ahci Jul 6 15:58:24 Wintermute kernel: ata33: SATA max UDMA/133 abar m2048@0xfe900000 port 0xfe900100 irq 54 Jul 6 15:58:24 Wintermute kernel: ata34: SATA max UDMA/133 abar m2048@0xfe900000 port 0xfe900180 irq 55 Jul 6 15:58:24 Wintermute kernel: ata9: SATA link down (SStatus 0 SControl 300) Jul 6 15:58:24 Wintermute kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300) Jul 6 15:58:24 Wintermute kernel: ata1.00: ATA-10: ST6000DM003-2CY186, 0001, max UDMA/133 Jul 6 15:58:24 Wintermute kernel: ata1.00: 11721045168 sectors, multi 16: LBA48 NCQ (depth 32), AA Jul 6 15:58:24 Wintermute kernel: ata34: SATA link up 6.0 Gbps (SStatus 133 SControl 300) Jul 6 15:58:24 Wintermute kernel: ata34.00: ATA-9: WDC WD20EZRX-00D8PB0, 80.00A80, max UDMA/133 Jul 6 15:58:24 Wintermute kernel: ata34.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 32), AA Jul 6 15:58:24 Wintermute kernel: ata34.00: configured for UDMA/133 Jul 6 15:58:24 Wintermute kernel: ata1.00: configured for UDMA/133 Jul 6 15:58:24 Wintermute kernel: scsi 1:0:0:0: Direct-Access ATA ST6000DM003-2CY1 0001 PQ: 0 ANSI: 5 Jul 6 15:58:24 Wintermute kernel: sd 1:0:0:0: Attached scsi generic sg1 type 0 Jul 6 15:58:24 Wintermute kernel: sd 1:0:0:0: [sdb] 11721045168 512-byte logical blocks: (6.00 TB/5.46 TiB) Jul 6 15:58:24 Wintermute kernel: sd 1:0:0:0: [sdb] 4096-byte physical blocks Jul 6 15:58:24 Wintermute kernel: sd 1:0:0:0: [sdb] Write Protect is off Jul 6 15:58:24 Wintermute kernel: sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00 Jul 6 15:58:24 Wintermute kernel: sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Jul 6 15:58:24 Wintermute kernel: sd 1:0:0:0: [sdb] Preferred minimum I/O size 4096 bytes Jul 6 15:58:24 Wintermute kernel: sdb: sdb1 Jul 6 15:58:24 Wintermute kernel: sd 1:0:0:0: [sdb] Attached SCSI disk Jul 6 15:58:24 Wintermute kernel: ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300) Jul 6 15:58:24 Wintermute kernel: ata2.00: ATA-10: ST6000DM003-2CY186, 0001, max UDMA/133 Jul 6 15:58:24 Wintermute kernel: ata2.00: 11721045168 sectors, multi 16: LBA48 NCQ (depth 32), AA Jul 6 15:58:24 Wintermute kernel: ata2.00: configured for UDMA/133 Jul 6 15:58:24 Wintermute kernel: scsi 2:0:0:0: Direct-Access ATA ST6000DM003-2CY1 0001 PQ: 0 ANSI: 5 Jul 6 15:58:24 Wintermute kernel: sd 2:0:0:0: Attached scsi generic sg2 type 0 Jul 6 15:58:24 Wintermute kernel: sd 2:0:0:0: [sdc] 11721045168 512-byte logical blocks: (6.00 TB/5.46 TiB) Jul 6 15:58:24 Wintermute kernel: sd 2:0:0:0: [sdc] 4096-byte physical blocks Jul 6 15:58:24 Wintermute kernel: sd 2:0:0:0: [sdc] Write Protect is off Jul 6 15:58:24 Wintermute kernel: sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00 Jul 6 15:58:24 Wintermute kernel: sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Jul 6 15:58:24 Wintermute kernel: sd 2:0:0:0: [sdc] Preferred minimum I/O size 4096 bytes Jul 6 15:58:24 Wintermute kernel: ata33: SATA link up 6.0 Gbps (SStatus 133 SControl 300) Jul 6 15:58:24 Wintermute kernel: sdc: sdc1 Jul 6 15:58:24 Wintermute kernel: sd 2:0:0:0: [sdc] Attached SCSI disk Jul 6 15:58:24 Wintermute kernel: ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300) Jul 6 15:58:24 Wintermute kernel: ata5.00: ATA-9: WDC WD60EFRX-68L0BN1, 82.00A82, max UDMA/133 Jul 6 15:58:24 Wintermute kernel: ata5.00: 11721045168 sectors, multi 16: LBA48 NCQ (depth 32), AA Jul 6 15:58:24 Wintermute kernel: ata5.00: configured for UDMA/133 Jul 6 15:58:24 Wintermute kernel: scsi 5:0:0:0: Direct-Access ATA WDC WD60EFRX-68L 0A82 PQ: 0 ANSI: 5 Jul 6 15:58:24 Wintermute kernel: sd 5:0:0:0: Attached scsi generic sg3 type 0 Jul 6 15:58:24 Wintermute kernel: sd 5:0:0:0: [sdd] 11721045168 512-byte logical blocks: (6.00 TB/5.46 TiB) Jul 6 15:58:24 Wintermute kernel: sd 5:0:0:0: [sdd] 4096-byte physical blocks Jul 6 15:58:24 Wintermute kernel: sd 5:0:0:0: [sdd] Write Protect is off Jul 6 15:58:24 Wintermute kernel: sd 5:0:0:0: [sdd] Mode Sense: 00 3a 00 00 Jul 6 15:58:24 Wintermute kernel: sd 5:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Jul 6 15:58:24 Wintermute kernel: sd 5:0:0:0: [sdd] Preferred minimum I/O size 4096 bytes Jul 6 15:58:24 Wintermute kernel: sdd: sdd1 Jul 6 15:58:24 Wintermute kernel: sd 5:0:0:0: [sdd] Attached SCSI disk Jul 6 15:58:24 Wintermute kernel: ata33.00: ATA-10: ST6000DM003-2U9186, 0001, max UDMA/133 Jul 6 15:58:24 Wintermute kernel: ata33.00: 11721045168 sectors, multi 16: LBA48 NCQ (depth 32), AA Jul 6 15:58:24 Wintermute kernel: ata33.00: configured for UDMA/133 Jul 6 15:58:24 Wintermute kernel: ata6: SATA link up 6.0 Gbps (SStatus 133 SControl 300) Jul 6 15:58:24 Wintermute kernel: ata6.00: ATA-10: WDC WD40EZRZ-00GXCB0, 80.00A80, max UDMA/133 Jul 6 15:58:24 Wintermute kernel: ata6.00: 7814037168 sectors, multi 16: LBA48 NCQ (depth 32), AA Jul 6 15:58:24 Wintermute kernel: ata6.00: configured for UDMA/133 Jul 6 15:58:24 Wintermute kernel: scsi 6:0:0:0: Direct-Access ATA WDC WD40EZRZ-00G 0A80 PQ: 0 ANSI: 5 Jul 6 15:58:24 Wintermute kernel: sd 6:0:0:0: Attached scsi generic sg4 type 0 Jul 6 15:58:24 Wintermute kernel: sd 6:0:0:0: [sde] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB) Jul 6 15:58:24 Wintermute kernel: sd 6:0:0:0: [sde] 4096-byte physical blocks Jul 6 15:58:24 Wintermute kernel: sd 6:0:0:0: [sde] Write Protect is off Jul 6 15:58:24 Wintermute kernel: sd 6:0:0:0: [sde] Mode Sense: 00 3a 00 00 Jul 6 15:58:24 Wintermute kernel: sd 6:0:0:0: [sde] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Jul 6 15:58:24 Wintermute kernel: sd 6:0:0:0: [sde] Preferred minimum I/O size 4096 bytes Jul 6 15:58:24 Wintermute kernel: ata10: SATA link down (SStatus 0 SControl 300) Jul 6 15:58:24 Wintermute kernel: sde: sde1 Jul 6 15:58:24 Wintermute kernel: sd 6:0:0:0: [sde] Attached SCSI disk Jul 6 15:58:24 Wintermute kernel: ata11: SATA link up 6.0 Gbps (SStatus 133 SControl 300) Jul 6 15:58:24 Wintermute kernel: ata11.00: ATA-10: WDC WD40EFRX-68N32N0, 82.00A82, max UDMA/133 Jul 6 15:58:24 Wintermute kernel: ata11.00: 7814037168 sectors, multi 16: LBA48 NCQ (depth 32), AA Jul 6 15:58:24 Wintermute kernel: ata11.00: configured for UDMA/133 Jul 6 15:58:24 Wintermute kernel: scsi 11:0:0:0: Direct-Access ATA WDC WD40EFRX-68N 0A82 PQ: 0 ANSI: 5 Jul 6 15:58:24 Wintermute kernel: sd 11:0:0:0: Attached scsi generic sg5 type 0 Jul 6 15:58:24 Wintermute kernel: sd 11:0:0:0: [sdf] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB) Jul 6 15:58:24 Wintermute kernel: sd 11:0:0:0: [sdf] 4096-byte physical blocks Jul 6 15:58:24 Wintermute kernel: sd 11:0:0:0: [sdf] Write Protect is off Jul 6 15:58:24 Wintermute kernel: sd 11:0:0:0: [sdf] Mode Sense: 00 3a 00 00 Jul 6 15:58:24 Wintermute kernel: sd 11:0:0:0: [sdf] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Jul 6 15:58:24 Wintermute kernel: sd 11:0:0:0: [sdf] Preferred minimum I/O size 4096 bytes Jul 6 15:58:24 Wintermute kernel: sdf: sdf1 Jul 6 15:58:24 Wintermute kernel: sd 11:0:0:0: [sdf] Attached SCSI removable disk Jul 6 15:58:24 Wintermute kernel: ata12: SATA link up 6.0 Gbps (SStatus 133 SControl 300) Jul 6 15:58:24 Wintermute kernel: ata12.00: ATA-9: WDC WD60EFRX-68MYMN1, 82.00A82, max UDMA/133 Jul 6 15:58:24 Wintermute kernel: ata12.00: 11721045168 sectors, multi 0: LBA48 NCQ (depth 32), AA Jul 6 15:58:24 Wintermute kernel: ata12.00: configured for UDMA/133 Jul 6 15:58:24 Wintermute kernel: scsi 12:0:0:0: Direct-Access ATA WDC WD60EFRX-68M 0A82 PQ: 0 ANSI: 5 Jul 6 15:58:24 Wintermute kernel: sd 12:0:0:0: Attached scsi generic sg6 type 0 Jul 6 15:58:24 Wintermute kernel: sd 12:0:0:0: [sdg] 11721045168 512-byte logical blocks: (6.00 TB/5.46 TiB) Jul 6 15:58:24 Wintermute kernel: sd 12:0:0:0: [sdg] 4096-byte physical blocks Jul 6 15:58:24 Wintermute kernel: sd 12:0:0:0: [sdg] Write Protect is off Jul 6 15:58:24 Wintermute kernel: sd 12:0:0:0: [sdg] Mode Sense: 00 3a 00 00 Jul 6 15:58:24 Wintermute kernel: sd 12:0:0:0: [sdg] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Jul 6 15:58:24 Wintermute kernel: sd 12:0:0:0: [sdg] Preferred minimum I/O size 4096 bytes Jul 6 15:58:24 Wintermute kernel: sdg: sdg1 Jul 6 15:58:24 Wintermute kernel: sd 12:0:0:0: [sdg] Attached SCSI removable disk Jul 6 15:58:24 Wintermute kernel: ata17: SATA link down (SStatus 0 SControl 300) Jul 6 15:58:24 Wintermute kernel: ata18: SATA link down (SStatus 0 SControl 300) Jul 6 15:58:24 Wintermute kernel: ata19: SATA link down (SStatus 0 SControl 300) Jul 6 15:58:24 Wintermute kernel: ata20: SATA link down (SStatus 0 SControl 300) Jul 6 15:58:24 Wintermute kernel: ata21: SATA link down (SStatus 0 SControl 300) Jul 6 15:58:24 Wintermute kernel: ata22: SATA link down (SStatus 0 SControl 300) Jul 6 15:58:24 Wintermute kernel: ata23: SATA link down (SStatus 0 SControl 300) Jul 6 15:58:24 Wintermute kernel: ata24: SATA link down (SStatus 0 SControl 300) Jul 6 15:58:24 Wintermute kernel: ata25: SATA link down (SStatus 0 SControl 300) Jul 6 15:58:24 Wintermute kernel: ata26: SATA link down (SStatus 0 SControl 300) Jul 6 15:58:24 Wintermute kernel: ata27: SATA link down (SStatus 0 SControl 300) Jul 6 15:58:24 Wintermute kernel: ata28: SATA link down (SStatus 0 SControl 300) Jul 6 15:58:24 Wintermute kernel: ata29: SATA link down (SStatus 0 SControl 300) Jul 6 15:58:24 Wintermute kernel: ata30: SATA link down (SStatus 0 SControl 300) Jul 6 15:58:24 Wintermute kernel: ata31: SATA link down (SStatus 0 SControl 300) Jul 6 15:58:24 Wintermute kernel: ata32: SATA link down (SStatus 0 SControl 300) Jul 6 15:58:24 Wintermute kernel: scsi 33:0:0:0: Direct-Access ATA ST6000DM003-2U91 0001 PQ: 0 ANSI: 5 Jul 6 15:58:24 Wintermute kernel: sd 33:0:0:0: Attached scsi generic sg7 type 0 Jul 6 15:58:24 Wintermute kernel: sd 33:0:0:0: [sdh] 11721045168 512-byte logical blocks: (6.00 TB/5.46 TiB) Jul 6 15:58:24 Wintermute kernel: sd 33:0:0:0: [sdh] 4096-byte physical blocks Jul 6 15:58:24 Wintermute kernel: scsi 34:0:0:0: Direct-Access ATA WDC WD20EZRX-00D 0A80 PQ: 0 ANSI: 5 Jul 6 15:58:24 Wintermute kernel: sd 33:0:0:0: [sdh] Write Protect is off Jul 6 15:58:24 Wintermute kernel: sd 33:0:0:0: [sdh] Mode Sense: 00 3a 00 00 Jul 6 15:58:24 Wintermute kernel: sd 33:0:0:0: [sdh] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Jul 6 15:58:24 Wintermute kernel: sd 33:0:0:0: [sdh] Preferred minimum I/O size 4096 bytes Jul 6 15:58:24 Wintermute kernel: sd 34:0:0:0: Attached scsi generic sg8 type 0 Jul 6 15:58:24 Wintermute kernel: sd 34:0:0:0: [sdi] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB) Jul 6 15:58:24 Wintermute kernel: sd 34:0:0:0: [sdi] 4096-byte physical blocks Jul 6 15:58:24 Wintermute kernel: sd 34:0:0:0: [sdi] Write Protect is off Jul 6 15:58:24 Wintermute kernel: sd 34:0:0:0: [sdi] Mode Sense: 00 3a 00 00 Jul 6 15:58:24 Wintermute kernel: sd 34:0:0:0: [sdi] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Jul 6 15:58:24 Wintermute kernel: sd 34:0:0:0: [sdi] Preferred minimum I/O size 4096 bytes Jul 6 15:58:24 Wintermute kernel: sdh: sdh1 Jul 6 15:58:24 Wintermute kernel: sd 33:0:0:0: [sdh] Attached SCSI removable disk Jul 6 15:58:24 Wintermute kernel: sdi: sdi1 Jul 6 15:58:24 Wintermute kernel: sd 34:0:0:0: [sdi] Attached SCSI removable disk Jul 6 15:58:24 Wintermute kernel: cryptd: max_cpu_qlen set to 1000 Jul 6 15:58:24 Wintermute kernel: it87: Found IT8792E/IT8795E chip at 0xa60, revision 3 Jul 6 15:58:24 Wintermute kernel: AVX2 version of gcm_enc/dec engaged. Jul 6 15:58:24 Wintermute kernel: AES CTR mode by8 optimization enabled Jul 6 15:58:24 Wintermute kernel: kvm_amd: SVM disabled (by BIOS) in MSR_VM_CR on CPU 3 Jul 6 15:58:24 Wintermute kernel: EDAC MC: Ver: 3.0.0 Jul 6 15:58:24 Wintermute kernel: MCE: In-kernel MCE decoding enabled. Jul 6 15:58:24 Wintermute kernel: [drm] amdgpu kernel modesetting enabled. Jul 6 15:58:24 Wintermute kernel: amdgpu: Virtual CRAT table created for CPU Jul 6 15:58:24 Wintermute kernel: amdgpu: Topology: Add CPU node Jul 6 15:58:24 Wintermute kernel: [drm] initializing kernel modesetting (RAVEN 0x1002:0x15DD 0x1458:0xD000 0xC8). Jul 6 15:58:24 Wintermute kernel: [drm] register mmio base: 0xFE500000 Jul 6 15:58:24 Wintermute kernel: [drm] register mmio size: 524288 Jul 6 15:58:24 Wintermute kernel: [drm] add ip block number 0 <soc15_common> Jul 6 15:58:24 Wintermute kernel: [drm] add ip block number 1 <gmc_v9_0> Jul 6 15:58:24 Wintermute kernel: [drm] add ip block number 2 <vega10_ih> Jul 6 15:58:24 Wintermute kernel: [drm] add ip block number 3 <psp> Jul 6 15:58:24 Wintermute kernel: [drm] add ip block number 4 <powerplay> Jul 6 15:58:24 Wintermute kernel: [drm] add ip block number 5 <dm> Jul 6 15:58:24 Wintermute kernel: [drm] add ip block number 6 <gfx_v9_0> Jul 6 15:58:24 Wintermute kernel: [drm] add ip block number 7 <sdma_v4_0> Jul 6 15:58:24 Wintermute kernel: [drm] add ip block number 8 <vcn_v1_0> Jul 6 15:58:24 Wintermute kernel: ata12.00: exception Emask 0x11 SAct 0x2000 SErr 0x0 action 0x6 frozen Jul 6 15:58:24 Wintermute kernel: ata12.00: irq_stat 0x48000008, interface fatal error Jul 6 15:58:24 Wintermute kernel: ata12.00: failed command: READ FPDMA QUEUED Jul 6 15:58:24 Wintermute kernel: ata12.00: cmd 60/f8:68:48:02:00/01:00:00:00:00/40 tag 13 ncq dma 258048 in Jul 6 15:58:24 Wintermute kernel: res 41/84:00:00:00:00/00:00:00:00:00/00 Emask 0x10 (ATA bus error) Jul 6 15:58:24 Wintermute kernel: ata12.00: status: { DRDY ERR } Jul 6 15:58:24 Wintermute kernel: ata12.00: error: { ICRC ABRT } Jul 6 15:58:24 Wintermute kernel: ata12: hard resetting link Jul 6 15:58:24 Wintermute kernel: [drm] BIOS signature incorrect 73 7 Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: amdgpu: Fetched VBIOS from ROM BAR Jul 6 15:58:24 Wintermute kernel: amdgpu: ATOM BIOS: 113-RAVEN-106 Jul 6 15:58:24 Wintermute kernel: [drm] VCN decode is enabled in VM mode Jul 6 15:58:24 Wintermute kernel: [drm] VCN encode is enabled in VM mode Jul 6 15:58:24 Wintermute kernel: [drm] JPEG decode is enabled in VM mode Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: vgaarb: deactivate vga console Jul 6 15:58:24 Wintermute kernel: Console: switching to colour dummy device 80x25 Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: amdgpu: Trusted Memory Zone (TMZ) feature enabled Jul 6 15:58:24 Wintermute kernel: [drm] vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: amdgpu: VRAM: 1024M 0x000000F400000000 - 0x000000F43FFFFFFF (1024M used) Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: amdgpu: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF Jul 6 15:58:24 Wintermute kernel: [drm] Detected VRAM RAM=1024M, BAR=1024M Jul 6 15:58:24 Wintermute kernel: [drm] RAM width 64bits DDR4 Jul 6 15:58:24 Wintermute kernel: [drm] amdgpu: 1024M of VRAM memory ready Jul 6 15:58:24 Wintermute kernel: [drm] amdgpu: 7473M of GTT memory ready. Jul 6 15:58:24 Wintermute kernel: [drm] GART: num cpu pages 262144, num gpu pages 262144 Jul 6 15:58:24 Wintermute kernel: [drm] PCIE GART of 1024M enabled. Jul 6 15:58:24 Wintermute kernel: [drm] PTB located at 0x000000F400A00000 Jul 6 15:58:24 Wintermute kernel: amdgpu: hwmgr_sw_init smu backed is smu10_smu Jul 6 15:58:24 Wintermute kernel: [drm] Found VCN firmware Version ENC: 1.15 DEC: 3 VEP: 0 Revision: 0 Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: amdgpu: Will use PSP to load VCN firmware Jul 6 15:58:24 Wintermute kernel: [drm] reserve 0x400000 from 0xf43fc00000 for PSP TMR Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: amdgpu: RAS: optional ras ta ucode is not available Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: amdgpu: RAP: optional rap ta ucode is not available Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available Jul 6 15:58:24 Wintermute kernel: [drm] DM_PPLIB: values for F clock Jul 6 15:58:24 Wintermute kernel: [drm] DM_PPLIB: 400000 in kHz, 3649 in mV Jul 6 15:58:24 Wintermute kernel: [drm] DM_PPLIB: 933000 in kHz, 4074 in mV Jul 6 15:58:24 Wintermute kernel: [drm] DM_PPLIB: 1067000 in kHz, 4250 in mV Jul 6 15:58:24 Wintermute kernel: [drm] DM_PPLIB: values for DCF clock Jul 6 15:58:24 Wintermute kernel: [drm] DM_PPLIB: 300000 in kHz, 3649 in mV Jul 6 15:58:24 Wintermute kernel: [drm] DM_PPLIB: 600000 in kHz, 4074 in mV Jul 6 15:58:24 Wintermute kernel: [drm] DM_PPLIB: 626000 in kHz, 4250 in mV Jul 6 15:58:24 Wintermute kernel: [drm] DM_PPLIB: 654000 in kHz, 4399 in mV Jul 6 15:58:24 Wintermute kernel: [drm] Display Core v3.2.247 initialized on DCN 1.0 Jul 6 15:58:24 Wintermute kernel: [drm] kiq ring mec 2 pipe 1 q 0 Jul 6 15:58:24 Wintermute kernel: [drm] VCN decode and encode initialized successfully(under SPG Mode). Jul 6 15:58:24 Wintermute kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart Jul 6 15:58:24 Wintermute kernel: kfd kfd: amdgpu: Total number of KFD nodes to be created: 1 Jul 6 15:58:24 Wintermute kernel: amdgpu: Virtual CRAT table created for GPU Jul 6 15:58:24 Wintermute kernel: amdgpu: Topology: Add dGPU node [0x15dd:0x1002] Jul 6 15:58:24 Wintermute kernel: kfd kfd: amdgpu: added device 1002:15dd Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: amdgpu: SE 1, SH per SE 1, CU per SH 11, active_cu_number 8 Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0 Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: amdgpu: ring gfx_low uses VM inv eng 1 on hub 0 Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: amdgpu: ring gfx_high uses VM inv eng 4 on hub 0 Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 5 on hub 0 Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 6 on hub 0 Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 7 on hub 0 Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 8 on hub 0 Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 9 on hub 0 Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 10 on hub 0 Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 11 on hub 0 Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 12 on hub 0 Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: amdgpu: ring kiq_0.2.1.0 uses VM inv eng 13 on hub 0 Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 8 Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 8 Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 8 Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 8 Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 8 Jul 6 15:58:24 Wintermute kernel: [drm] Initialized amdgpu 3.54.0 20150101 for 0000:06:00.0 on minor 0 Jul 6 15:58:24 Wintermute kernel: amdgpu 0000:06:00.0: [drm] Cannot find any crtc or sizes Jul 6 15:58:24 Wintermute kernel: ata12: SATA link up 6.0 Gbps (SStatus 133 SControl 300) Jul 6 15:58:24 Wintermute kernel: ata12.00: configured for UDMA/133 Jul 6 15:58:24 Wintermute kernel: sd 12:0:0:0: [sdg] tag#13 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=DRIVER_OK cmd_age=1s Jul 6 15:58:24 Wintermute kernel: sd 12:0:0:0: [sdg] tag#13 Sense Key : 0xb [current] Jul 6 15:58:24 Wintermute kernel: sd 12:0:0:0: [sdg] tag#13 ASC=0x47 ASCQ=0x0 Jul 6 15:58:24 Wintermute kernel: sd 12:0:0:0: [sdg] tag#13 CDB: opcode=0x88 88 00 00 00 00 00 00 00 02 48 00 00 01 f8 00 00 Jul 6 15:58:24 Wintermute kernel: I/O error, dev sdg, sector 584 op 0x0:(READ) flags 0x80700 phys_seg 58 prio class 2 Jul 6 15:58:24 Wintermute kernel: ata12: EH complete Jul 6 15:58:24 Wintermute rc.rsyslogd: Syslog server daemon... Started. Jul 6 15:58:24 Wintermute rc.M: Updating X font indexes... Jul 6 15:58:24 Wintermute rc.M: /usr/bin/fc-cache -f Jul 6 15:58:24 Wintermute rc.udev: Updating hardware database index... Jul 6 15:58:24 Wintermute rc.udev: udevadm hwdb --update Jul 6 15:58:24 Wintermute rc.udev: Triggering udev events... Jul 6 15:58:24 Wintermute rc.udev: udevadm trigger --type=subsystems --action=change Jul 6 15:58:24 Wintermute rc.udev: udevadm trigger --type=devices --action=change Jul 6 15:58:24 Wintermute rc.udev: udevadm settle --timeout=120 Jul 6 15:58:25 Wintermute kernel: ata12.00: exception Emask 0x11 SAct 0x300000 SErr 0x0 action 0x6 frozen Jul 6 15:58:25 Wintermute kernel: ata12.00: irq_stat 0x48000008, interface fatal error Jul 6 15:58:25 Wintermute kernel: ata12.00: failed command: READ FPDMA QUEUED Jul 6 15:58:25 Wintermute kernel: ata12.00: cmd 60/a8:a0:28:f1:a0/00:00:ba:02:00/40 tag 20 ncq dma 86016 in Jul 6 15:58:25 Wintermute kernel: res 41/84:00:00:00:00/00:00:00:00:00/00 Emask 0x10 (ATA bus error) Jul 6 15:58:25 Wintermute kernel: ata12.00: status: { DRDY ERR } Jul 6 15:58:25 Wintermute kernel: ata12.00: error: { ICRC ABRT } Jul 6 15:58:25 Wintermute kernel: ata12.00: failed command: READ FPDMA QUEUED Jul 6 15:58:25 Wintermute kernel: ata12.00: cmd 60/28:a8:d8:f1:a0/00:00:ba:02:00/40 tag 21 ncq dma 20480 in Jul 6 15:58:25 Wintermute kernel: res 41/84:00:00:00:00/00:00:00:00:00/00 Emask 0x10 (ATA bus error) Jul 6 15:58:25 Wintermute kernel: ata12.00: status: { DRDY ERR } Jul 6 15:58:25 Wintermute kernel: ata12.00: error: { ICRC ABRT } Jul 6 15:58:25 Wintermute kernel: ata12: hard resetting link Jul 6 15:58:25 Wintermute rsyslogd: [origin software="rsyslogd" swVersion="8.2102.0" x-pid="1331" x-info="https://www.rsyslog.com"] start Jul 6 15:58:25 Wintermute kernel: ata12: SATA link up 6.0 Gbps (SStatus 133 SControl 300) Jul 6 15:58:25 Wintermute kernel: ata12.00: configured for UDMA/133 Jul 6 15:58:25 Wintermute kernel: sd 12:0:0:0: [sdg] tag#20 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=DRIVER_OK cmd_age=0s Jul 6 15:58:25 Wintermute kernel: sd 12:0:0:0: [sdg] tag#20 Sense Key : 0xb [current] Jul 6 15:58:25 Wintermute kernel: sd 12:0:0:0: [sdg] tag#20 ASC=0x47 ASCQ=0x0 Jul 6 15:58:25 Wintermute kernel: sd 12:0:0:0: [sdg] tag#20 CDB: opcode=0x88 88 00 00 00 00 02 ba a0 f1 28 00 00 00 a8 00 00 Jul 6 15:58:25 Wintermute kernel: I/O error, dev sdg, sector 11721044264 op 0x0:(READ) flags 0x80700 phys_seg 13 prio class 2 Jul 6 15:58:25 Wintermute kernel: sd 12:0:0:0: [sdg] tag#21 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=DRIVER_OK cmd_age=0s Jul 6 15:58:25 Wintermute kernel: sd 12:0:0:0: [sdg] tag#21 Sense Key : 0xb [current] Jul 6 15:58:25 Wintermute kernel: sd 12:0:0:0: [sdg] tag#21 ASC=0x47 ASCQ=0x0 Jul 6 15:58:25 Wintermute kernel: sd 12:0:0:0: [sdg] tag#21 CDB: opcode=0x88 88 00 00 00 00 02 ba a0 f1 d8 00 00 00 28 00 00 Jul 6 15:58:25 Wintermute kernel: I/O error, dev sdg, sector 11721044440 op 0x0:(READ) flags 0x80700 phys_seg 5 prio class 2 Jul 6 15:58:25 Wintermute kernel: ata12: EH complete Jul 6 15:58:25 Wintermute rc.inet1: ip -4 addr add 127.0.0.1/8 dev lo Jul 6 15:58:25 Wintermute rc.inet1: ip -6 addr add ::1/128 dev lo Jul 6 15:58:25 Wintermute rc.inet1: ip link set lo up Jul 6 15:58:25 Wintermute rc.inet1: ip link add link eth0 name vhost0 address 02:ef:58:ed:2e:e0 type macvtap mode bridge Jul 6 15:58:25 Wintermute rc.inet1: ip link set vhost0 up Jul 6 15:58:25 Wintermute rc.inet1: ip link set eth0 up Jul 6 15:58:25 Wintermute kernel: Generic FE-GE Realtek PHY r8169-0-300:00: attached PHY driver (mii_bus:phy_addr=r8169-0-300:00, irq=MAC) Jul 6 15:58:26 Wintermute kernel: r8169 0000:03:00.0 eth0: entered promiscuous mode Jul 6 15:58:26 Wintermute kernel: r8169 0000:03:00.0 eth0: Link is Down Jul 6 15:58:28 Wintermute kernel: r8169 0000:03:00.0 eth0: Link is Up - 1Gbps/Full - flow control off Jul 6 15:58:29 Wintermute rc.inet1: interface eth0 is UP, setting static ipv4 address Jul 6 15:58:30 Wintermute rc.inet1: ip -4 addr add 192.168.50.245/255.255.255.0 dev eth0 metric 1 Jul 6 15:58:30 Wintermute rc.inet1: ip -4 route add default via 192.168.50.1 dev eth0 Jul 6 15:58:30 Wintermute rc.messagebus: Starting System Message Bus... Jul 6 15:58:30 Wintermute rc.messagebus: /usr/bin/dbus-uuidgen --ensure Jul 6 15:58:30 Wintermute rc.messagebus: /usr/bin/dbus-daemon --system Jul 6 15:58:30 Wintermute rc.messagebus: System Message Bus... Started. Jul 6 15:58:30 Wintermute rc.elogind: Starting Elogin daemon... Jul 6 15:58:30 Wintermute rc.elogind: /lib64/elogind/elogind --daemon Jul 6 15:58:30 Wintermute elogind-daemon[1555]: New seat seat0. Jul 6 15:58:30 Wintermute elogind-daemon[1555]: Watching system buttons on /dev/input/event2 (Power Button) Jul 6 15:58:30 Wintermute elogind-daemon[1555]: Watching system buttons on /dev/input/event1 (Power Button) Jul 6 15:58:30 Wintermute rc.elogind: Elogin daemon... Started. Jul 6 15:58:30 Wintermute rc.ip_forward: Activating IPv4 packet forwarding. Jul 6 15:58:30 Wintermute rc.ip_forward: Activating IPv6 packet forwarding. Jul 6 15:58:30 Wintermute rc.inetd: Starting Internet daemon... Jul 6 15:58:30 Wintermute rc.inetd: /usr/sbin/inetd Jul 6 15:58:31 Wintermute rc.inetd: Internet daemon... Started. Jul 6 15:58:31 Wintermute rc.sshd: Starting SSH server daemon... Jul 6 15:58:31 Wintermute rc.sshd: /usr/sbin/sshd Jul 6 15:58:31 Wintermute sshd[1625]: Server listening on 192.168.50.245 port 22. Jul 6 15:58:31 Wintermute rc.sshd: SSH server daemon... Started. Jul 6 15:58:31 Wintermute rc.ntpd: Starting NTP server daemon... Jul 6 15:58:31 Wintermute rc.ntpd: NTP server daemon... Service not enabled. Jul 6 15:58:31 Wintermute rc.acpid: Starting ACPI power management daemon... Jul 6 15:58:31 Wintermute rc.acpid: /usr/sbin/acpid Jul 6 15:58:31 Wintermute acpid: starting up with netlink and the input layer Jul 6 15:58:31 Wintermute acpid: 1 rule loaded Jul 6 15:58:31 Wintermute acpid: waiting for events: event logging is off Jul 6 15:58:31 Wintermute rc.acpid: ACPI power management daemon... Started. Jul 6 15:58:31 Wintermute rc.cpufreq: Enabled CPU frequency scaling governor: ondemand Jul 6 15:58:31 Wintermute rc.M: Updating MIME database... Jul 6 15:58:31 Wintermute rc.M: Updating gdk-pixbuf.loaders... Jul 6 15:58:31 Wintermute rc.M: /usr/bin/update-mime-database /usr/share/mime Jul 6 15:58:31 Wintermute rc.M: /usr/bin/update-gdk-pixbuf-loaders Jul 6 15:58:31 Wintermute rc.M: Compiling GSettings XML schema files... Jul 6 15:58:31 Wintermute rc.M: /usr/bin/glib-compile-schemas /usr/share/glib-2.0/schemas Jul 6 15:58:31 Wintermute rc.crond: Starting Cron daemon... Jul 6 15:58:31 Wintermute rc.crond: /usr/sbin/crond Jul 6 15:58:31 Wintermute crond[1700]: /usr/sbin/crond 4.5 dillon's cron daemon, started with loglevel notice Jul 6 15:58:32 Wintermute rc.crond: Cron daemon... Started. Jul 6 15:58:32 Wintermute rc.atd: Starting AT daemon... Jul 6 15:58:32 Wintermute rc.atd: /usr/sbin/atd -b 15 -l 1 Jul 6 15:58:32 Wintermute rc.atd: AT daemon... Started. Jul 6 15:58:32 Wintermute rc.wireguard: iptables -N WIREGUARD Jul 6 15:58:32 Wintermute rc.wireguard: iptables -A FORWARD -j WIREGUARD Jul 6 15:58:32 Wintermute rc.wireguard: ip6tables -N WIREGUARD Jul 6 15:58:32 Wintermute rc.wireguard: ip6tables -A FORWARD -j WIREGUARD Jul 6 15:58:32 Wintermute rc.wireguard: mkdir -p /boot/config/wireguard Jul 6 15:58:32 Wintermute rc.wireguard: ln -sf /boot/config/wireguard /etc Jul 6 15:58:32 Wintermute rc.avahidaemon: Starting Avahi mDNS/DNS-SD daemon... Jul 6 15:58:32 Wintermute rc.avahidaemon: /usr/sbin/avahi-daemon -D Jul 6 15:58:32 Wintermute avahi-daemon[1771]: Found user 'avahi' (UID 61) and group 'avahi' (GID 214). Jul 6 15:58:32 Wintermute avahi-daemon[1771]: Successfully dropped root privileges. Jul 6 15:58:32 Wintermute avahi-daemon[1771]: avahi-daemon 0.8 starting up. Jul 6 15:58:32 Wintermute avahi-daemon[1771]: Successfully called chroot(). Jul 6 15:58:32 Wintermute avahi-daemon[1771]: Successfully dropped remaining capabilities. Jul 6 15:58:32 Wintermute avahi-daemon[1771]: Loading service file /services/sftp-ssh.service. Jul 6 15:58:32 Wintermute avahi-daemon[1771]: Loading service file /services/ssh.service. Jul 6 15:58:32 Wintermute avahi-daemon[1771]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.50.245. Jul 6 15:58:32 Wintermute avahi-daemon[1771]: New relevant interface eth0.IPv4 for mDNS. Jul 6 15:58:32 Wintermute avahi-daemon[1771]: Network interface enumeration completed. Jul 6 15:58:32 Wintermute avahi-daemon[1771]: Registering new address record for 192.168.50.245 on eth0.IPv4. Jul 6 15:58:32 Wintermute rc.avahidaemon: Avahi mDNS/DNS-SD daemon... Started. Jul 6 15:58:32 Wintermute rc.avahidnsconfd: Starting Avahi mDNS/DNS-SD DNS server daemon... Jul 6 15:58:32 Wintermute rc.avahidnsconfd: /usr/sbin/avahi-dnsconfd -D Jul 6 15:58:32 Wintermute avahi-dnsconfd[1787]: Successfully connected to Avahi daemon. Jul 6 15:58:32 Wintermute rc.avahidnsconfd: Avahi mDNS/DNS-SD DNS server daemon... Started. Jul 6 15:58:32 Wintermute rc.samba: Starting Samba server daemon... Jul 6 15:58:33 Wintermute rc.samba: /usr/sbin/smbd -D Jul 6 15:58:33 Wintermute rc.samba: /usr/sbin/nmbd -D Jul 6 15:58:33 Wintermute nmbd[1820]: [2025/07/06 15:58:33.305184, 0] ../../source3/nmbd/nmbd_become_dmb.c:294(become_domain_master_browser_bcast) Jul 6 15:58:33 Wintermute nmbd[1820]: become_domain_master_browser_bcast: Jul 6 15:58:33 Wintermute nmbd[1820]: Attempting to become domain master browser on workgroup WORKGROUP on subnet 192.168.50.245 Jul 6 15:58:33 Wintermute nmbd[1820]: [2025/07/06 15:58:33.305292, 0] ../../source3/nmbd/nmbd_become_dmb.c:306(become_domain_master_browser_bcast) Jul 6 15:58:33 Wintermute nmbd[1820]: become_domain_master_browser_bcast: querying subnet 192.168.50.245 for domain master browser on workgroup WORKGROUP Jul 6 15:58:33 Wintermute rc.samba: /usr/sbin/wsdd2 -d -4 Jul 6 15:58:33 Wintermute wsdd2[1832]: starting. Jul 6 15:58:33 Wintermute rc.samba: /usr/sbin/winbindd -D Jul 6 15:58:33 Wintermute avahi-daemon[1771]: Server startup complete. Host name is Wintermute.local. Local service cookie is 2492746363. Jul 6 15:58:33 Wintermute rc.samba: Samba server daemon... Started. Jul 6 15:58:33 Wintermute rc.mcelog: Starting MCElog daemon... Jul 6 15:58:33 Wintermute rc.mcelog: MCElog daemon... Skipped. Jul 6 15:58:34 Wintermute create_network_ini: interface=init, reason=, protocol= Jul 6 15:58:34 Wintermute update_services: delay = 45s Jul 6 15:58:34 Wintermute avahi-daemon[1771]: Service "Wintermute" (/services/ssh.service) successfully established. Jul 6 15:58:34 Wintermute avahi-daemon[1771]: Service "Wintermute" (/services/sftp-ssh.service) successfully established. Jul 6 15:58:35 Wintermute plugin-manager: running: 'anonymous' Jul 6 15:58:35 Wintermute plugin-manager: running: 'anonymous' Jul 6 15:58:35 Wintermute plugin-manager: checking: /boot/config/plugins/ca.update.applications/ca.update.applications-2024.03.17-x86_64-1.txz - MD5 Jul 6 15:58:35 Wintermute plugin-manager: skipping: /boot/config/plugins/ca.update.applications/ca.update.applications-2024.03.17-x86_64-1.txz already exists Jul 6 15:58:35 Wintermute plugin-manager: running: upgradepkg --install-new /boot/config/plugins/ca.update.applications/ca.update.applications-2024.03.17-x86_64-1.txz Jul 6 15:58:35 Wintermute plugin-manager: running: 'anonymous' Jul 6 15:58:35 Wintermute plugin-manager: ca.update.applications.plg installed Jul 6 15:58:35 Wintermute rc.local: plugin: installing: ca.update.applications.plg Jul 6 15:58:35 Wintermute rc.local: Executing hook script: pre_plugin_checks Jul 6 15:58:35 Wintermute rc.local: +============================================================================== Jul 6 15:58:35 Wintermute rc.local: | Installing new package /boot/config/plugins/ca.update.applications/ca.update.applications-2024.03.17-x86_64-1.txz Jul 6 15:58:35 Wintermute rc.local: +============================================================================== Jul 6 15:58:35 Wintermute rc.local: Verifying package ca.update.applications-2024.03.17-x86_64-1.txz. Jul 6 15:58:35 Wintermute rc.local: Installing package ca.update.applications-2024.03.17-x86_64-1.txz: Jul 6 15:58:35 Wintermute rc.local: PACKAGE DESCRIPTION: Jul 6 15:58:35 Wintermute rc.local: Package ca.update.applications-2024.03.17-x86_64-1.txz installed. Jul 6 15:58:35 Wintermute rc.local: ---------------------------------------------------- Jul 6 15:58:35 Wintermute rc.local: ca.update.applications has been installed. Jul 6 15:58:35 Wintermute rc.local: Copyright 2015-2024, Andrew Zawadzki Jul 6 15:58:35 Wintermute rc.local: Version: 2024.03.17 Jul 6 15:58:35 Wintermute rc.local: ---------------------------------------------------- Jul 6 15:58:35 Wintermute rc.local: plugin: ca.update.applications.plg installed Jul 6 15:58:35 Wintermute rc.local: Executing hook script: post_plugin_checks Jul 6 15:58:35 Wintermute plugin-manager: running: 'anonymous' Jul 6 15:58:35 Wintermute plugin-manager: running: 'anonymous' Jul 6 15:58:36 Wintermute plugin-manager: checking: /boot/config/plugins/community.applications/community.applications-2025.06.04a-x86_64-1.txz - MD5 Jul 6 15:58:36 Wintermute plugin-manager: skipping: /boot/config/plugins/community.applications/community.applications-2025.06.04a-x86_64-1.txz already exists Jul 6 15:58:36 Wintermute plugin-manager: running: upgradepkg --install-new --reinstall /boot/config/plugins/community.applications/community.applications-2025.06.04a-x86_64-1.txz Jul 6 15:58:36 Wintermute plugin-manager: running: 'anonymous' Jul 6 15:58:36 Wintermute plugin-manager: community.applications.plg installed Jul 6 15:58:36 Wintermute rc.local: plugin: installing: community.applications.plg Jul 6 15:58:36 Wintermute rc.local: Executing hook script: pre_plugin_checks Jul 6 15:58:36 Wintermute rc.local: Cleaning Up Old Versions Jul 6 15:58:36 Wintermute rc.local: Fixing pinned apps Jul 6 15:58:36 Wintermute rc.local: Setting up cron for background notifications Jul 6 15:58:36 Wintermute rc.local: +============================================================================== Jul 6 15:58:36 Wintermute rc.local: | Installing new package /boot/config/plugins/community.applications/community.applications-2025.06.04a-x86_64-1.txz Jul 6 15:58:36 Wintermute rc.local: +============================================================================== Jul 6 15:58:36 Wintermute rc.local: Verifying package community.applications-2025.06.04a-x86_64-1.txz. Jul 6 15:58:36 Wintermute rc.local: Installing package community.applications-2025.06.04a-x86_64-1.txz: Jul 6 15:58:36 Wintermute rc.local: PACKAGE DESCRIPTION: Jul 6 15:58:36 Wintermute rc.local: Package community.applications-2025.06.04a-x86_64-1.txz installed. Jul 6 15:58:36 Wintermute rc.local: Creating Directories Jul 6 15:58:36 Wintermute rc.local: Adjusting icon for Unraid version Jul 6 15:58:36 Wintermute rc.local: ---------------------------------------------------- Jul 6 15:58:36 Wintermute rc.local: community.applications has been installed. Jul 6 15:58:36 Wintermute rc.local: Copyright 2015-2025, Andrew Zawadzki Jul 6 15:58:36 Wintermute rc.local: Copyright 2024-2025, Lime Technology Jul 6 15:58:36 Wintermute rc.local: Version: 2025.06.04a Jul 6 15:58:36 Wintermute rc.local: ---------------------------------------------------- Jul 6 15:58:36 Wintermute rc.local: plugin: community.applications.plg installed Jul 6 15:58:36 Wintermute rc.local: Executing hook script: post_plugin_checks Jul 6 15:58:36 Wintermute plugin-manager: running: 'anonymous' Jul 6 15:58:36 Wintermute plugin-manager: checking: /boot/config/plugins/compose.manager/compose.manager-package-2025.05.01.txz - MD5 Jul 6 15:58:37 Wintermute plugin-manager: skipping: /boot/config/plugins/compose.manager/compose.manager-package-2025.05.01.txz already exists Jul 6 15:58:37 Wintermute plugin-manager: running: upgradepkg --install-new /boot/config/plugins/compose.manager/compose.manager-package-2025.05.01.txz Jul 6 15:58:39 Wintermute plugin-manager: running: 'anonymous' Jul 6 15:58:39 Wintermute plugin-manager: running: 'anonymous' Jul 6 15:58:39 Wintermute plugin-manager: compose.manager.plg installed Jul 6 15:58:39 Wintermute rc.local: plugin: installing: compose.manager.plg Jul 6 15:58:39 Wintermute rc.local: Executing hook script: pre_plugin_checks Jul 6 15:58:39 Wintermute rc.local: +============================================================================== Jul 6 15:58:39 Wintermute rc.local: | Installing new package /boot/config/plugins/compose.manager/compose.manager-package-2025.05.01.txz Jul 6 15:58:39 Wintermute rc.local: +============================================================================== Jul 6 15:58:39 Wintermute rc.local: Verifying package compose.manager-package-2025.05.01.txz. Jul 6 15:58:39 Wintermute rc.local: Installing package compose.manager-package-2025.05.01.txz: Jul 6 15:58:39 Wintermute rc.local: PACKAGE DESCRIPTION: Jul 6 15:58:39 Wintermute rc.local: Package compose.manager-package-2025.05.01.txz installed. Jul 6 15:58:39 Wintermute rc.local: ---------------------------------------------------- Jul 6 15:58:39 Wintermute rc.local: compose.manager has been installed. Jul 6 15:58:39 Wintermute rc.local: Version: 2025.05.01 Jul 6 15:58:39 Wintermute rc.local: ---------------------------------------------------- Jul 6 15:58:39 Wintermute rc.local: plugin: compose.manager.plg installed Jul 6 15:58:39 Wintermute rc.local: Executing hook script: post_plugin_checks Jul 6 15:58:39 Wintermute plugin-manager: running: 'anonymous' Jul 6 15:58:39 Wintermute plugin-manager: checking: /boot/config/plugins/dynamix.local.master/dynamix.local.master.txz - MD5 Jul 6 15:58:39 Wintermute plugin-manager: skipping: /boot/config/plugins/dynamix.local.master/dynamix.local.master.txz already exists Jul 6 15:58:39 Wintermute plugin-manager: running: upgradepkg --install-new --reinstall /boot/config/plugins/dynamix.local.master/dynamix.local.master.txz Jul 6 15:58:39 Wintermute plugin-manager: running: 'anonymous' Jul 6 15:58:39 Wintermute plugin-manager: dynamix.local.master.plg installed Jul 6 15:58:39 Wintermute rc.local: plugin: installing: dynamix.local.master.plg Jul 6 15:58:39 Wintermute rc.local: Executing hook script: pre_plugin_checks Jul 6 15:58:39 Wintermute rc.local: +============================================================================== Jul 6 15:58:39 Wintermute rc.local: | Installing new package /boot/config/plugins/dynamix.local.master/dynamix.local.master.txz Jul 6 15:58:39 Wintermute rc.local: +============================================================================== Jul 6 15:58:39 Wintermute rc.local: Verifying package dynamix.local.master.txz. Jul 6 15:58:39 Wintermute rc.local: Installing package dynamix.local.master.txz: Jul 6 15:58:39 Wintermute rc.local: PACKAGE DESCRIPTION: Jul 6 15:58:39 Wintermute rc.local: Package dynamix.local.master.txz installed. Jul 6 15:58:39 Wintermute rc.local: ----------------------------------------------------------- Jul 6 15:58:39 Wintermute rc.local: Plugin dynamix.local.master is installed. Jul 6 15:58:39 Wintermute rc.local: This plugin requires Dynamix webGui to operate Jul 6 15:58:39 Wintermute rc.local: Copyright 2023, Bergware International Jul 6 15:58:39 Wintermute rc.local: Version: 2023.02.20 Jul 6 15:58:39 Wintermute rc.local: ----------------------------------------------------------- Jul 6 15:58:39 Wintermute rc.local: plugin: dynamix.local.master.plg installed Jul 6 15:58:39 Wintermute rc.local: Executing hook script: post_plugin_checks Jul 6 15:58:39 Wintermute plugin-manager: running: 'anonymous' Jul 6 15:58:39 Wintermute plugin-manager: checking: /boot/config/plugins/dynamix.system.stats/dynamix.system.stats.txz - MD5 Jul 6 15:58:39 Wintermute plugin-manager: skipping: /boot/config/plugins/dynamix.system.stats/dynamix.system.stats.txz already exists Jul 6 15:58:39 Wintermute plugin-manager: running: upgradepkg --install-new --reinstall /boot/config/plugins/dynamix.system.stats/dynamix.system.stats.txz Jul 6 15:58:39 Wintermute plugin-manager: running: 'anonymous' Jul 6 15:58:39 Wintermute plugin-manager: dynamix.system.stats.plg installed Jul 6 15:58:39 Wintermute rc.local: plugin: installing: dynamix.system.stats.plg Jul 6 15:58:39 Wintermute rc.local: Executing hook script: pre_plugin_checks Jul 6 15:58:39 Wintermute rc.local: +============================================================================== Jul 6 15:58:39 Wintermute rc.local: | Installing new package /boot/config/plugins/dynamix.system.stats/dynamix.system.stats.txz Jul 6 15:58:39 Wintermute rc.local: +============================================================================== Jul 6 15:58:39 Wintermute rc.local: Verifying package dynamix.system.stats.txz. Jul 6 15:58:39 Wintermute rc.local: Installing package dynamix.system.stats.txz: Jul 6 15:58:39 Wintermute rc.local: PACKAGE DESCRIPTION: Jul 6 15:58:39 Wintermute rc.local: Package dynamix.system.stats.txz installed. Jul 6 15:58:39 Wintermute rc.local: plugin: skipping: sysstat-12.7.5.txz - Unraid version too high, requires at most version 6.11.9 Jul 6 15:58:39 Wintermute rc.local: ----------------------------------------------------------- Jul 6 15:58:39 Wintermute rc.local: Plugin dynamix.system.stats is installed. Jul 6 15:58:39 Wintermute rc.local: This plugin requires Dynamix webGui to operate Jul 6 15:58:39 Wintermute rc.local: Copyright 2024, Bergware International Jul 6 15:58:39 Wintermute rc.local: Version: 2025.01.18 Jul 6 15:58:39 Wintermute rc.local: ----------------------------------------------------------- Jul 6 15:58:39 Wintermute rc.local: plugin: dynamix.system.stats.plg installed Jul 6 15:58:39 Wintermute rc.local: Executing hook script: post_plugin_checks Jul 6 15:58:39 Wintermute plugin-manager: checking: /boot/config/plugins/fix.common.problems/fix.common.problems-2025.05.29-x86_64-1.txz - MD5 Jul 6 15:58:39 Wintermute plugin-manager: skipping: /boot/config/plugins/fix.common.problems/fix.common.problems-2025.05.29-x86_64-1.txz already exists Jul 6 15:58:39 Wintermute plugin-manager: running: upgradepkg --install-new /boot/config/plugins/fix.common.problems/fix.common.problems-2025.05.29-x86_64-1.txz Jul 6 15:58:39 Wintermute plugin-manager: running: 'anonymous' Jul 6 15:58:40 Wintermute plugin-manager: fix.common.problems.plg installed Jul 6 15:58:40 Wintermute rc.local: plugin: installing: fix.common.problems.plg Jul 6 15:58:40 Wintermute rc.local: Executing hook script: pre_plugin_checks Jul 6 15:58:40 Wintermute rc.local: +============================================================================== Jul 6 15:58:40 Wintermute rc.local: | Installing new package /boot/config/plugins/fix.common.problems/fix.common.problems-2025.05.29-x86_64-1.txz Jul 6 15:58:40 Wintermute rc.local: +============================================================================== Jul 6 15:58:40 Wintermute rc.local: Verifying package fix.common.problems-2025.05.29-x86_64-1.txz. Jul 6 15:58:40 Wintermute rc.local: Installing package fix.common.problems-2025.05.29-x86_64-1.txz: Jul 6 15:58:40 Wintermute rc.local: PACKAGE DESCRIPTION: Jul 6 15:58:40 Wintermute rc.local: Package fix.common.problems-2025.05.29-x86_64-1.txz installed. Jul 6 15:58:40 Wintermute rc.local: ---------------------------------------------------- Jul 6 15:58:40 Wintermute rc.local: fix.common.problems has been installed. Jul 6 15:58:40 Wintermute rc.local: Copyright 2020-2024, Lime Technology Jul 6 15:58:40 Wintermute rc.local: Copyright 2016-2024, Andrew Zawadzki Jul 6 15:58:40 Wintermute rc.local: Version: 2025.05.29 Jul 6 15:58:40 Wintermute rc.local: ---------------------------------------------------- Jul 6 15:58:40 Wintermute rc.local: plugin: fix.common.problems.plg installed Jul 6 15:58:40 Wintermute rc.local: Executing hook script: post_plugin_checks Jul 6 15:58:40 Wintermute plugin-manager: checking: /boot/config/plugins/unbalanced/unbalanced-2025.02.22.tgz - MD5 Jul 6 15:58:40 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 15:58:40 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 15:58:40 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00002040/00002000 Jul 6 15:58:40 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 6] BadTLP Jul 6 15:58:40 Wintermute plugin-manager: skipping: /boot/config/plugins/unbalanced/unbalanced-2025.02.22.tgz already exists Jul 6 15:58:40 Wintermute plugin-manager: skipping: /boot/config/plugins/unbalanced/unbalanced.cfg already exists Jul 6 15:58:40 Wintermute plugin-manager: skipping: /boot/config/plugins/unbalanced/unbalanced.env already exists Jul 6 15:58:40 Wintermute plugin-manager: running: 'anonymous' Jul 6 15:58:40 Wintermute plugin-manager: creating: /tmp/unbalanced-chkconf - from INLINE content Jul 6 15:58:40 Wintermute plugin-manager: running: /bin/bash /tmp/unbalanced-chkconf Jul 6 15:58:40 Wintermute plugin-manager: unbalanced.plg installed Jul 6 15:58:40 Wintermute rc.local: plugin: installing: unbalanced.plg Jul 6 15:58:40 Wintermute rc.local: Executing hook script: pre_plugin_checks Jul 6 15:58:40 Wintermute rc.local: ----------------------------------------------------------- Jul 6 15:58:40 Wintermute rc.local: unbalanced has been installed. Jul 6 15:58:40 Wintermute rc.local: Copyright (c) Juan B. Rodriguez Jul 6 15:58:40 Wintermute rc.local: Version: 2025.02.22 Jul 6 15:58:40 Wintermute rc.local: ----------------------------------------------------------- Jul 6 15:58:40 Wintermute rc.local: plugin: unbalanced.plg installed Jul 6 15:58:40 Wintermute rc.local: Executing hook script: post_plugin_checks Jul 6 15:58:40 Wintermute plugin-manager: checking: /boot/config/plugins/user.scripts/user.scripts-2025.06.21-x86_64-1.txz - MD5 Jul 6 15:58:40 Wintermute plugin-manager: skipping: /boot/config/plugins/user.scripts/user.scripts-2025.06.21-x86_64-1.txz already exists Jul 6 15:58:40 Wintermute plugin-manager: running: upgradepkg --install-new /boot/config/plugins/user.scripts/user.scripts-2025.06.21-x86_64-1.txz Jul 6 15:58:41 Wintermute plugin-manager: running: 'anonymous' Jul 6 15:58:41 Wintermute plugin-manager: running: 'anonymous' Jul 6 15:58:41 Wintermute plugin-manager: user.scripts.plg installed Jul 6 15:58:41 Wintermute rc.local: plugin: installing: user.scripts.plg Jul 6 15:58:41 Wintermute rc.local: Executing hook script: pre_plugin_checks Jul 6 15:58:41 Wintermute rc.local: +============================================================================== Jul 6 15:58:41 Wintermute rc.local: | Installing new package /boot/config/plugins/user.scripts/user.scripts-2025.06.21-x86_64-1.txz Jul 6 15:58:41 Wintermute rc.local: +============================================================================== Jul 6 15:58:41 Wintermute rc.local: Verifying package user.scripts-2025.06.21-x86_64-1.txz. Jul 6 15:58:41 Wintermute rc.local: Installing package user.scripts-2025.06.21-x86_64-1.txz: Jul 6 15:58:41 Wintermute rc.local: PACKAGE DESCRIPTION: Jul 6 15:58:41 Wintermute rc.local: Package user.scripts-2025.06.21-x86_64-1.txz installed. Jul 6 15:58:41 Wintermute rc.local: ---------------------------------------------------- Jul 6 15:58:41 Wintermute rc.local: user.scripts has been installed. Jul 6 15:58:41 Wintermute rc.local: Copyright 2016-2024, Andrew Zawadzki Jul 6 15:58:41 Wintermute rc.local: Version: 2025.06.21 Jul 6 15:58:41 Wintermute rc.local: ---------------------------------------------------- Jul 6 15:58:41 Wintermute rc.local: plugin: user.scripts.plg installed Jul 6 15:58:41 Wintermute rc.local: Executing hook script: post_plugin_checks Jul 6 15:58:41 Wintermute rc.local: Installing language packs Jul 6 15:58:41 Wintermute rc.local: Starting go script Jul 6 15:58:41 Wintermute kernel: msr: Write to unrecognized MSR 0xc0010292 by zenstates (pid: 3214). Jul 6 15:58:41 Wintermute kernel: msr: See https://git.kernel.org/pub/scm/linux/kernel/git/tip/tip.git/about for details. Jul 6 15:58:41 Wintermute emhttp: Starting emhttpd... Jul 6 15:58:41 Wintermute emhttpd: Unraid(tm) System Management Utility version 7.0.1 Jul 6 15:58:41 Wintermute emhttpd: Copyright (C) 2005-2024, Lime Technology, Inc. Jul 6 15:58:41 Wintermute emhttpd: unclean shutdown detected Jul 6 15:58:41 Wintermute emhttpd: shcmd (5): /usr/local/emhttp/webGui/scripts/update_access Jul 6 15:58:41 Wintermute rc.sshd: Restarting SSH server daemon... Jul 6 15:58:41 Wintermute sshd[1625]: Received signal 15; terminating. Jul 6 15:58:42 Wintermute nmbd[1820]: [2025/07/06 15:58:42.699998, 0] ../../source3/nmbd/nmbd_become_dmb.c:112(become_domain_master_stage2) Jul 6 15:58:42 Wintermute nmbd[1820]: ***** Jul 6 15:58:42 Wintermute nmbd[1820]: Jul 6 15:58:42 Wintermute nmbd[1820]: Samba server WINTERMUTE is now a domain master browser for workgroup WORKGROUP on subnet 192.168.50.245 Jul 6 15:58:42 Wintermute nmbd[1820]: Jul 6 15:58:42 Wintermute nmbd[1820]: ***** Jul 6 15:58:42 Wintermute rc.sshd: Starting SSH server daemon... Jul 6 15:58:43 Wintermute rc.sshd: /usr/sbin/sshd Jul 6 15:58:43 Wintermute sshd[3264]: Server listening on 192.168.50.245 port 22. Jul 6 15:58:43 Wintermute rc.sshd: SSH server daemon... Started. Jul 6 15:58:43 Wintermute rc.inetd: Restarting Internet daemon... Jul 6 15:58:43 Wintermute rc.inetd: Stopping Internet daemon... Jul 6 15:58:43 Wintermute rc.inetd: killall --ns 3271 inetd Jul 6 15:58:43 Wintermute rc.inetd: Internet daemon... Stopped. Jul 6 15:58:44 Wintermute rc.inetd: Starting Internet daemon... Jul 6 15:58:44 Wintermute rc.inetd: /usr/sbin/inetd Jul 6 15:58:44 Wintermute rc.inetd: Internet daemon... Started. Jul 6 15:58:44 Wintermute emhttpd: shcmd (6): modprobe zfs Jul 6 15:58:44 Wintermute kernel: spl: loading out-of-tree module taints kernel. Jul 6 15:58:44 Wintermute kernel: zfs: module license 'CDDL' taints kernel. Jul 6 15:58:44 Wintermute kernel: Disabling lock debugging due to kernel taint Jul 6 15:58:44 Wintermute kernel: zfs: module license taints kernel. Jul 6 15:58:47 Wintermute kernel: ZFS: Loaded module v2.2.7-1, ZFS pool version 5000, ZFS filesystem version 5 Jul 6 15:58:47 Wintermute emhttpd: online: ST6000DM003-2U9186_ZR155L12 (sdh) 512 11721045168 Jul 6 15:58:47 Wintermute emhttpd: online: WDC_WD60EFRX-68MYMN1_WD-WX51D6428012 (sdg) 512 11721045168 Jul 6 15:58:47 Wintermute emhttpd: online: WDC_WD60EFRX-68L0BN1_WD-WX31DB58YDK6 (sdd) 512 11721045168 Jul 6 15:58:47 Wintermute emhttpd: online: WDC_WD40EZRZ-00GXCB0_WD-WCC7K7PFVDZK (sde) 512 7814037168 Jul 6 15:58:47 Wintermute emhttpd: online: ST6000DM003-2CY186_ZR14XNRA (sdb) 512 11721045168 Jul 6 15:58:47 Wintermute emhttpd: online: WDC_WD40EFRX-68N32N0_WD-WCC7K4VDZEJZ (sdf) 512 7814037168 Jul 6 15:58:47 Wintermute emhttpd: online: ST6000DM003-2CY186_ZSC04SZH (sdc) 512 11721045168 Jul 6 15:58:47 Wintermute emhttpd: online: WDC_WD20EZRX-00D8PB0_WD-WCC4M2472398 (sdi) 512 3907029168 Jul 6 15:58:47 Wintermute emhttpd: online: Lexar_JD_FireFly_NSN224MBCTTXBVAJLIYA-0:0 (sda) 512 15663104 Jul 6 15:58:47 Wintermute emhttpd: shcmd (9): /sbin/modprobe md-mod super=/boot/config/super.dat Jul 6 15:58:47 Wintermute kernel: md: unRAID driver 2.9.33 installed Jul 6 15:58:47 Wintermute emhttpd: Pro key detected, GUID: 05DC-A810-24MB-CTTXBVAJLIYA FILE: /boot/config/Pro.key Jul 6 15:58:47 Wintermute kernel: mdcmd (1): import 0 sdb 64 5860522532 0 ST6000DM003-2CY186_ZR14XNRA Jul 6 15:58:47 Wintermute kernel: md: import disk0: (sdb) ST6000DM003-2CY186_ZR14XNRA size: 5860522532 Jul 6 15:58:47 Wintermute kernel: mdcmd (2): import 1 sdh 64 5860522532 0 ST6000DM003-2U9186_ZR155L12 Jul 6 15:58:47 Wintermute kernel: md: import disk1: (sdh) ST6000DM003-2U9186_ZR155L12 size: 5860522532 Jul 6 15:58:47 Wintermute kernel: mdcmd (3): import 2 sdg 64 5860522532 0 WDC_WD60EFRX-68MYMN1_WD-WX51D6428012 Jul 6 15:58:47 Wintermute kernel: md: import disk2: (sdg) WDC_WD60EFRX-68MYMN1_WD-WX51D6428012 size: 5860522532 Jul 6 15:58:47 Wintermute kernel: mdcmd (4): import 3 sdf 64 3907018532 0 WDC_WD40EFRX-68N32N0_WD-WCC7K4VDZEJZ Jul 6 15:58:47 Wintermute kernel: md: import disk3: (sdf) WDC_WD40EFRX-68N32N0_WD-WCC7K4VDZEJZ size: 3907018532 Jul 6 15:58:47 Wintermute kernel: mdcmd (5): import 4 sdc 64 5860522532 0 ST6000DM003-2CY186_ZSC04SZH Jul 6 15:58:47 Wintermute kernel: md: import disk4: (sdc) ST6000DM003-2CY186_ZSC04SZH size: 5860522532 Jul 6 15:58:47 Wintermute kernel: mdcmd (6): import 5 sdi 64 1953514552 0 WDC_WD20EZRX-00D8PB0_WD-WCC4M2472398 Jul 6 15:58:47 Wintermute kernel: md: import disk5: (sdi) WDC_WD20EZRX-00D8PB0_WD-WCC4M2472398 size: 1953514552 Jul 6 15:58:47 Wintermute kernel: mdcmd (7): import 6 sdd 64 5860522532 0 WDC_WD60EFRX-68L0BN1_WD-WX31DB58YDK6 Jul 6 15:58:47 Wintermute kernel: md: import disk6: (sdd) WDC_WD60EFRX-68L0BN1_WD-WX31DB58YDK6 size: 5860522532 Jul 6 15:58:47 Wintermute kernel: mdcmd (8): import 7 sde 64 3907018532 0 WDC_WD40EZRZ-00GXCB0_WD-WCC7K7PFVDZK Jul 6 15:58:47 Wintermute kernel: md: import disk7: (sde) WDC_WD40EZRZ-00GXCB0_WD-WCC7K7PFVDZK size: 3907018532 Jul 6 15:58:47 Wintermute kernel: mdcmd (9): import 8 Jul 6 15:58:47 Wintermute kernel: mdcmd (10): import 9 Jul 6 15:58:47 Wintermute kernel: mdcmd (11): import 10 Jul 6 15:58:47 Wintermute kernel: mdcmd (12): import 11 Jul 6 15:58:47 Wintermute kernel: mdcmd (13): import 12 Jul 6 15:58:47 Wintermute kernel: mdcmd (14): import 13 Jul 6 15:58:47 Wintermute kernel: mdcmd (15): import 14 Jul 6 15:58:47 Wintermute kernel: mdcmd (16): import 15 Jul 6 15:58:47 Wintermute kernel: mdcmd (17): import 16 Jul 6 15:58:47 Wintermute kernel: mdcmd (18): import 17 Jul 6 15:58:47 Wintermute kernel: mdcmd (19): import 18 Jul 6 15:58:47 Wintermute kernel: mdcmd (20): import 19 Jul 6 15:58:47 Wintermute kernel: mdcmd (21): import 20 Jul 6 15:58:47 Wintermute kernel: mdcmd (22): import 21 Jul 6 15:58:47 Wintermute kernel: mdcmd (23): import 22 Jul 6 15:58:47 Wintermute kernel: mdcmd (24): import 23 Jul 6 15:58:47 Wintermute kernel: mdcmd (25): import 24 Jul 6 15:58:47 Wintermute kernel: mdcmd (26): import 25 Jul 6 15:58:47 Wintermute kernel: mdcmd (27): import 26 Jul 6 15:58:47 Wintermute kernel: mdcmd (28): import 27 Jul 6 15:58:47 Wintermute kernel: mdcmd (29): import 28 Jul 6 15:58:47 Wintermute kernel: mdcmd (30): import 29 Jul 6 15:58:47 Wintermute kernel: md: import_slot: 29 empty Jul 6 15:58:47 Wintermute emhttpd: /sbin/blkid /dev/sda1 2>&1 Jul 6 15:58:47 Wintermute emhttpd: /dev/sda1: LABEL_FATBOOT="UNRAID" LABEL="UNRAID" UUID="9668-0AD0" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="c3072e18-01" Jul 6 15:58:47 Wintermute emhttpd: import 30 flash device: (sda) Jul 6 15:58:47 Wintermute SysDriversBuild: Submitting SysDrivers Build Jul 6 15:58:47 Wintermute sysDrivers: SysDrivers Build Starting Jul 6 15:58:47 Wintermute emhttpd: read SMART /dev/sdh Jul 6 15:58:47 Wintermute emhttpd: read SMART /dev/sdg Jul 6 15:58:47 Wintermute emhttpd: read SMART /dev/sdd Jul 6 15:58:47 Wintermute emhttpd: read SMART /dev/sde Jul 6 15:58:47 Wintermute emhttpd: read SMART /dev/sdb Jul 6 15:58:47 Wintermute emhttpd: read SMART /dev/sdf Jul 6 15:58:47 Wintermute emhttpd: read SMART /dev/sdc Jul 6 15:58:47 Wintermute emhttpd: read SMART /dev/sdi Jul 6 15:58:47 Wintermute emhttpd: read SMART /dev/sda Jul 6 15:58:48 Wintermute emhttpd: Starting services... Jul 6 15:58:48 Wintermute emhttpd: shcmd (28): /etc/rc.d/rc.samba reload Jul 6 15:58:48 Wintermute avahi-daemon[1771]: Files changed, reloading. Jul 6 15:58:48 Wintermute avahi-daemon[1771]: Loading service file /services/smb.service. Jul 6 15:58:48 Wintermute emhttpd: shcmd (31): /etc/rc.d/rc.nfsd start Jul 6 15:58:49 Wintermute rc.nfsd: Starting NFS server daemon... Jul 6 15:58:49 Wintermute kernel: RPC: Registered named UNIX socket transport module. Jul 6 15:58:49 Wintermute kernel: RPC: Registered udp transport module. Jul 6 15:58:49 Wintermute kernel: RPC: Registered tcp transport module. Jul 6 15:58:49 Wintermute kernel: RPC: Registered tcp-with-tls transport module. Jul 6 15:58:49 Wintermute kernel: RPC: Registered tcp NFSv4.1 backchannel transport module. Jul 6 15:58:49 Wintermute rc.rpc: Starting RPC server daemon... Jul 6 15:58:49 Wintermute rc.rpc: Starting RPC portmapper Jul 6 15:58:49 Wintermute rc.rpc: /sbin/rpcbind -w -h 192.168.50.245 Jul 6 15:58:49 Wintermute rc.rpc: Starting RPC NSM (Network Status Monitor) Jul 6 15:58:49 Wintermute rc.rpc: /sbin/rpc.statd Jul 6 15:58:49 Wintermute rpc.statd[3832]: Version 2.8.2 starting Jul 6 15:58:49 Wintermute sm-notify[3833]: Version 2.8.2 starting Jul 6 15:58:49 Wintermute rpc.statd[3832]: Failed to read /var/lib/nfs/state: Success Jul 6 15:58:49 Wintermute rpc.statd[3832]: Initializing NSM state Jul 6 15:58:49 Wintermute rc.rpc: RPC server daemon... Started. Jul 6 15:58:49 Wintermute rc.nfsd: /usr/sbin/exportfs -r Jul 6 15:58:49 Wintermute rc.nfsd: /usr/sbin/rpc.nfsd -u -H 192.168.50.245 -H 127.0.0.1 -s 8 Jul 6 15:58:49 Wintermute avahi-daemon[1771]: Service "Wintermute" (/services/smb.service) successfully established. Jul 6 15:58:50 Wintermute kernel: NFSD: Using UMH upcall client tracking operations. Jul 6 15:58:50 Wintermute kernel: NFSD: starting 90-second grace period (net f0000000) Jul 6 15:58:50 Wintermute rc.nfsd: /usr/sbin/rpc.mountd Jul 6 15:58:50 Wintermute rpc.mountd[4103]: Version 2.8.2 starting Jul 6 15:58:50 Wintermute rc.nfsd: NFS server daemon... Started. Jul 6 15:58:50 Wintermute emhttpd: shcmd (33): /etc/rc.d/rc.avahidaemon reload Jul 6 15:58:50 Wintermute avahi-daemon[1771]: Got SIGHUP, reloading. Jul 6 15:58:51 Wintermute emhttpd: Autostart enabled Jul 6 15:58:53 Wintermute emhttpd: shcmd (38): /etc/rc.d/rc.php-fpm start Jul 6 15:58:53 Wintermute rc.php-fpm: Starting PHP-fpm daemon... Jul 6 15:58:53 Wintermute rc.php-fpm: /usr/sbin/php-fpm --daemonize --fpm-config /etc/php-fpm.conf --pid /var/run/php-fpm.pid --allow-to-run-as-root Jul 6 15:58:53 Wintermute rc.php-fpm: PHP-fpm daemon... Started. Jul 6 15:58:53 Wintermute emhttpd: shcmd (39): /etc/rc.d/rc.nginx start Jul 6 15:58:53 Wintermute rc.nginx: Starting Nginx server daemon... Jul 6 15:58:53 Wintermute rc.nginx: Nginx server daemon... Started. Jul 6 15:58:53 Wintermute kernel: mdcmd (31): set md_num_stripes 1280 Jul 6 15:58:53 Wintermute kernel: mdcmd (32): set md_queue_limit 80 Jul 6 15:58:53 Wintermute kernel: mdcmd (33): set md_sync_limit 5 Jul 6 15:58:53 Wintermute kernel: mdcmd (34): set md_write_method Jul 6 15:58:53 Wintermute kernel: mdcmd (35): start STOPPED Jul 6 15:58:53 Wintermute kernel: unraid: allocating 46470K for 1280 stripes (9 disks) Jul 6 15:58:53 Wintermute kernel: md1p1: running, size: 5860522532 blocks Jul 6 15:58:53 Wintermute kernel: md2p1: running, size: 5860522532 blocks Jul 6 15:58:53 Wintermute kernel: md3p1: running, size: 3907018532 blocks Jul 6 15:58:53 Wintermute kernel: md4p1: running, size: 5860522532 blocks Jul 6 15:58:53 Wintermute kernel: md5p1: running, size: 1953514552 blocks Jul 6 15:58:53 Wintermute kernel: md6p1: running, size: 5860522532 blocks Jul 6 15:58:53 Wintermute emhttpd: shcmd (40): udevadm settle Jul 6 15:58:53 Wintermute kernel: md7p1: running, size: 3907018532 blocks Jul 6 15:58:53 Wintermute emhttpd: /sbin/blkid /dev/sda1 2>&1 Jul 6 15:58:53 Wintermute emhttpd: /dev/sda1: LABEL_FATBOOT="UNRAID" LABEL="UNRAID" UUID="9668-0AD0" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="c3072e18-01" Jul 6 15:58:53 Wintermute emhttpd: import 30 flash device: (sda) Jul 6 15:58:53 Wintermute SysDriversBuild: Submitting SysDrivers Build Jul 6 15:58:53 Wintermute emhttpd: shcmd (49): touch /boot/config/forcesync Jul 6 15:58:53 Wintermute sysDrivers: SysDrivers Build Starting Jul 6 15:58:54 Wintermute emhttpd: Mounting disks... Jul 6 15:58:54 Wintermute emhttpd: mounting /mnt/disk1 Jul 6 15:58:54 Wintermute emhttpd: shcmd (50): mkdir -m 0666 -p /mnt/disk1 Jul 6 15:58:54 Wintermute emhttpd: /sbin/blkid /dev/md1p1 2>&1 Jul 6 15:58:54 Wintermute emhttpd: /dev/md1p1: UUID="5d714dee-530d-49a1-9b3d-64ae15b1b8a4" BLOCK_SIZE="512" TYPE="xfs" Jul 6 15:58:54 Wintermute emhttpd: shcmd (51): mount -t xfs -o noatime,nouuid /dev/md1p1 /mnt/disk1 Jul 6 15:58:54 Wintermute kernel: XFS (md1p1): Mounting V5 Filesystem 5d714dee-530d-49a1-9b3d-64ae15b1b8a4 Jul 6 15:58:54 Wintermute sysDrivers: SysDrivers Build Complete Jul 6 15:58:54 Wintermute kernel: XFS (md1p1): Starting recovery (logdev: internal) Jul 6 15:58:54 Wintermute kernel: XFS (md1p1): Ending recovery (logdev: internal) Jul 6 15:58:54 Wintermute emhttpd: shcmd (52): xfs_growfs /mnt/disk1 Jul 6 15:58:54 Wintermute root: meta-data=/dev/md1p1 isize=512 agcount=6, agsize=268435455 blks Jul 6 15:58:54 Wintermute root: = sectsz=512 attr=2, projid32bit=1 Jul 6 15:58:54 Wintermute root: = crc=1 finobt=1, sparse=1, rmapbt=1 Jul 6 15:58:54 Wintermute root: = reflink=1 bigtime=1 inobtcount=1 nrext64=1 Jul 6 15:58:54 Wintermute root: = exchange=0 Jul 6 15:58:54 Wintermute root: data = bsize=4096 blocks=1465130633, imaxpct=5 Jul 6 15:58:54 Wintermute root: = sunit=0 swidth=0 blks Jul 6 15:58:54 Wintermute root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1, parent=0 Jul 6 15:58:54 Wintermute root: log =internal log bsize=4096 blocks=521728, version=2 Jul 6 15:58:54 Wintermute root: = sectsz=512 sunit=0 blks, lazy-count=1 Jul 6 15:58:54 Wintermute root: realtime =none extsz=4096 blocks=0, rtextents=0 Jul 6 15:58:54 Wintermute emhttpd: mounting /mnt/disk2 Jul 6 15:58:54 Wintermute emhttpd: shcmd (53): mkdir -m 0666 -p /mnt/disk2 Jul 6 15:58:54 Wintermute emhttpd: /sbin/blkid /dev/md2p1 2>&1 Jul 6 15:58:54 Wintermute emhttpd: /dev/md2p1: UUID="2f49e765-1205-4cda-97f3-cb57c32f2b16" BLOCK_SIZE="4096" TYPE="reiserfs" Jul 6 15:58:54 Wintermute emhttpd: shcmd (54): mount -t reiserfs -o noatime,user_xattr,acl /dev/md2p1 /mnt/disk2 Jul 6 15:58:54 Wintermute kernel: REISERFS warning: read_super_block: reiserfs filesystem is deprecated and scheduled to be removed from the kernel in 2025 Jul 6 15:58:54 Wintermute kernel: REISERFS (device md2p1): found reiserfs format "3.6" with standard journal Jul 6 15:58:54 Wintermute kernel: REISERFS (device md2p1): using ordered data mode Jul 6 15:58:54 Wintermute kernel: reiserfs: using flush barriers Jul 6 15:58:54 Wintermute kernel: REISERFS (device md2p1): journal params: device md2p1, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30 Jul 6 15:58:54 Wintermute kernel: REISERFS (device md2p1): checking transaction log (md2p1) Jul 6 15:58:54 Wintermute kernel: REISERFS (device md2p1): replayed 6 transactions in 0 seconds Jul 6 15:58:54 Wintermute kernel: REISERFS (device md2p1): Using r5 hash to sort names Jul 6 15:58:54 Wintermute emhttpd: reiserfs: resizing /mnt/disk2 Jul 6 15:58:55 Wintermute emhttpd: mounting /mnt/disk3 Jul 6 15:58:55 Wintermute emhttpd: shcmd (55): mkdir -m 0666 -p /mnt/disk3 Jul 6 15:58:55 Wintermute emhttpd: /sbin/blkid /dev/md3p1 2>&1 Jul 6 15:58:55 Wintermute emhttpd: /dev/md3p1: UUID="1caf85dd-caad-44ea-8e70-21a6244d62d7" BLOCK_SIZE="4096" TYPE="reiserfs" Jul 6 15:58:55 Wintermute emhttpd: shcmd (56): mount -t reiserfs -o noatime,user_xattr,acl /dev/md3p1 /mnt/disk3 Jul 6 15:58:55 Wintermute kernel: REISERFS warning: read_super_block: reiserfs filesystem is deprecated and scheduled to be removed from the kernel in 2025 Jul 6 15:58:55 Wintermute kernel: REISERFS (device md3p1): found reiserfs format "3.6" with standard journal Jul 6 15:58:55 Wintermute kernel: REISERFS (device md3p1): using ordered data mode Jul 6 15:58:55 Wintermute kernel: reiserfs: using flush barriers Jul 6 15:58:55 Wintermute kernel: REISERFS (device md3p1): journal params: device md3p1, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30 Jul 6 15:58:55 Wintermute kernel: REISERFS (device md3p1): checking transaction log (md3p1) Jul 6 15:58:55 Wintermute kernel: REISERFS (device md3p1): replayed 6 transactions in 0 seconds Jul 6 15:58:55 Wintermute kernel: REISERFS (device md3p1): Using r5 hash to sort names Jul 6 15:58:55 Wintermute emhttpd: reiserfs: resizing /mnt/disk3 Jul 6 15:58:55 Wintermute emhttpd: mounting /mnt/disk4 Jul 6 15:58:55 Wintermute emhttpd: shcmd (57): mkdir -m 0666 -p /mnt/disk4 Jul 6 15:58:55 Wintermute emhttpd: /sbin/blkid /dev/md4p1 2>&1 Jul 6 15:58:55 Wintermute emhttpd: /dev/md4p1: UUID="91a692dd-eb92-4556-96bd-eeba29197d62" BLOCK_SIZE="4096" TYPE="reiserfs" Jul 6 15:58:55 Wintermute emhttpd: shcmd (58): mount -t reiserfs -o noatime,user_xattr,acl /dev/md4p1 /mnt/disk4 Jul 6 15:58:55 Wintermute kernel: REISERFS warning: read_super_block: reiserfs filesystem is deprecated and scheduled to be removed from the kernel in 2025 Jul 6 15:58:55 Wintermute kernel: REISERFS (device md4p1): found reiserfs format "3.6" with standard journal Jul 6 15:58:55 Wintermute kernel: REISERFS (device md4p1): using ordered data mode Jul 6 15:58:55 Wintermute kernel: reiserfs: using flush barriers Jul 6 15:58:55 Wintermute kernel: REISERFS (device md4p1): journal params: device md4p1, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30 Jul 6 15:58:55 Wintermute kernel: REISERFS (device md4p1): checking transaction log (md4p1) Jul 6 15:58:55 Wintermute kernel: REISERFS (device md4p1): replayed 6 transactions in 0 seconds Jul 6 15:58:55 Wintermute kernel: REISERFS (device md4p1): Using r5 hash to sort names Jul 6 15:58:55 Wintermute emhttpd: reiserfs: resizing /mnt/disk4 Jul 6 15:58:55 Wintermute emhttpd: mounting /mnt/disk5 Jul 6 15:58:55 Wintermute emhttpd: shcmd (59): mkdir -m 0666 -p /mnt/disk5 Jul 6 15:58:55 Wintermute emhttpd: /sbin/blkid /dev/md5p1 2>&1 Jul 6 15:58:55 Wintermute emhttpd: /dev/md5p1: UUID="cd74e762-6674-4655-bcf8-85c858101577" BLOCK_SIZE="4096" TYPE="reiserfs" Jul 6 15:58:55 Wintermute emhttpd: shcmd (60): mount -t reiserfs -o noatime,user_xattr,acl /dev/md5p1 /mnt/disk5 Jul 6 15:58:55 Wintermute kernel: REISERFS warning: read_super_block: reiserfs filesystem is deprecated and scheduled to be removed from the kernel in 2025 Jul 6 15:58:55 Wintermute kernel: REISERFS (device md5p1): found reiserfs format "3.6" with standard journal Jul 6 15:58:55 Wintermute kernel: REISERFS (device md5p1): using ordered data mode Jul 6 15:58:55 Wintermute kernel: reiserfs: using flush barriers Jul 6 15:58:55 Wintermute kernel: REISERFS (device md5p1): journal params: device md5p1, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30 Jul 6 15:58:55 Wintermute kernel: REISERFS (device md5p1): checking transaction log (md5p1) Jul 6 15:58:56 Wintermute kernel: REISERFS (device md5p1): replayed 7 transactions in 0 seconds Jul 6 15:58:56 Wintermute kernel: REISERFS (device md5p1): Using r5 hash to sort names Jul 6 15:58:56 Wintermute emhttpd: reiserfs: resizing /mnt/disk5 Jul 6 15:58:56 Wintermute emhttpd: mounting /mnt/disk6 Jul 6 15:58:56 Wintermute emhttpd: shcmd (61): mkdir -m 0666 -p /mnt/disk6 Jul 6 15:58:56 Wintermute emhttpd: /sbin/blkid /dev/md6p1 2>&1 Jul 6 15:58:56 Wintermute emhttpd: /dev/md6p1: UUID="490412d5-4b89-4698-bc30-a6c54480147a" BLOCK_SIZE="4096" TYPE="reiserfs" Jul 6 15:58:56 Wintermute emhttpd: shcmd (62): mount -t reiserfs -o noatime,user_xattr,acl /dev/md6p1 /mnt/disk6 Jul 6 15:58:56 Wintermute kernel: REISERFS warning: read_super_block: reiserfs filesystem is deprecated and scheduled to be removed from the kernel in 2025 Jul 6 15:58:56 Wintermute kernel: REISERFS (device md6p1): found reiserfs format "3.6" with standard journal Jul 6 15:58:56 Wintermute kernel: REISERFS (device md6p1): using ordered data mode Jul 6 15:58:56 Wintermute kernel: reiserfs: using flush barriers Jul 6 15:58:56 Wintermute kernel: REISERFS (device md6p1): journal params: device md6p1, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30 Jul 6 15:58:56 Wintermute kernel: REISERFS (device md6p1): checking transaction log (md6p1) Jul 6 15:58:56 Wintermute kernel: REISERFS (device md6p1): replayed 11 transactions in 0 seconds Jul 6 15:58:56 Wintermute kernel: REISERFS (device md6p1): Using r5 hash to sort names Jul 6 15:58:56 Wintermute emhttpd: reiserfs: resizing /mnt/disk6 Jul 6 15:58:56 Wintermute emhttpd: mounting /mnt/disk7 Jul 6 15:58:56 Wintermute emhttpd: shcmd (63): mkdir -m 0666 -p /mnt/disk7 Jul 6 15:58:56 Wintermute emhttpd: /sbin/blkid /dev/md7p1 2>&1 Jul 6 15:58:56 Wintermute emhttpd: /dev/md7p1: UUID="3c9bfd4f-c726-40c5-9d7f-37419d7f7a48" BLOCK_SIZE="4096" TYPE="reiserfs" Jul 6 15:58:56 Wintermute emhttpd: shcmd (64): mount -t reiserfs -o noatime,user_xattr,acl /dev/md7p1 /mnt/disk7 Jul 6 15:58:56 Wintermute kernel: REISERFS warning: read_super_block: reiserfs filesystem is deprecated and scheduled to be removed from the kernel in 2025 Jul 6 15:58:56 Wintermute kernel: REISERFS (device md7p1): found reiserfs format "3.6" with standard journal Jul 6 15:58:56 Wintermute kernel: REISERFS (device md7p1): using ordered data mode Jul 6 15:58:56 Wintermute kernel: reiserfs: using flush barriers Jul 6 15:58:57 Wintermute kernel: REISERFS (device md7p1): journal params: device md7p1, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30 Jul 6 15:58:57 Wintermute kernel: REISERFS (device md7p1): checking transaction log (md7p1) Jul 6 15:58:58 Wintermute kernel: REISERFS (device md7p1): replayed 283 transactions in 0 seconds Jul 6 15:58:58 Wintermute kernel: REISERFS (device md7p1): Using r5 hash to sort names Jul 6 15:58:58 Wintermute emhttpd: reiserfs: resizing /mnt/disk7 Jul 6 15:58:58 Wintermute emhttpd: shcmd (65): /usr/sbin/zfs mount -a Jul 6 15:58:58 Wintermute emhttpd: shcmd (66): sync Jul 6 15:58:59 Wintermute emhttpd: shcmd (67): mkdir /mnt/user0 Jul 6 15:58:59 Wintermute emhttpd: shcmd (68): /usr/libexec/unraid/shfs /mnt/user0 -disks 254 -o default_permissions,allow_other,noatime Jul 6 15:58:59 Wintermute emhttpd: shcmd (69): mkdir /mnt/user Jul 6 15:58:59 Wintermute emhttpd: shcmd (70): /usr/libexec/unraid/shfs /mnt/user -disks 255 -o default_permissions,allow_other,noatime -o remember=330 Jul 6 15:58:59 Wintermute emhttpd: shcmd (73): /usr/local/sbin/update_cron Jul 6 15:58:59 Wintermute root: Delaying execution of fix common problems scan for 10 minutes Jul 6 15:58:59 Wintermute emhttpd: /usr/local/emhttp/plugins/user.scripts/backgroundScript.sh "/tmp/user.scripts/tmpScripts/MSR/script" >/dev/null 2>&1 Jul 6 15:58:59 Wintermute emhttpd: Starting services... Jul 6 15:58:59 Wintermute emhttpd: shcmd (86): /etc/rc.d/rc.samba reload Jul 6 15:59:00 Wintermute sysDrivers: SysDrivers Build Complete Jul 6 15:59:00 Wintermute emhttpd: shcmd (89): exportfs -ra Jul 6 15:59:00 Wintermute emhttpd: shcmd (91): /etc/rc.d/rc.avahidaemon reload Jul 6 15:59:00 Wintermute avahi-daemon[1771]: Got SIGHUP, reloading. Jul 6 15:59:00 Wintermute emhttpd: shcmd (100): /usr/local/sbin/mount_image '/mnt/user/appdata/docker.img' /var/lib/docker 20 Jul 6 15:59:00 Wintermute kernel: loop2: detected capacity change from 0 to 41943040 Jul 6 15:59:00 Wintermute kernel: BTRFS: device fsid 86f5e929-4a8c-4d3e-88bc-d58221cb0bf3 devid 1 transid 1813015 /dev/loop2 scanned by udevd (6384) Jul 6 15:59:00 Wintermute kernel: BTRFS info (device loop2): first mount of filesystem 86f5e929-4a8c-4d3e-88bc-d58221cb0bf3 Jul 6 15:59:00 Wintermute kernel: BTRFS info (device loop2): using crc32c (crc32c-intel) checksum algorithm Jul 6 15:59:00 Wintermute kernel: BTRFS info (device loop2): using free space tree Jul 6 15:59:00 Wintermute kernel: BTRFS warning (device loop2): devid 1 physical 0 len 4194304 inside the reserved space Jul 6 15:59:00 Wintermute root: Resize device id 1 (/dev/loop2) from 20.00GiB to max Jul 6 15:59:00 Wintermute emhttpd: shcmd (102): /etc/rc.d/rc.docker start Jul 6 15:59:00 Wintermute rc.docker: Starting Docker daemon... Jul 6 15:59:07 Wintermute kernel: bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. Jul 6 15:59:07 Wintermute kernel: Bridge firewalling registered Jul 6 15:59:07 Wintermute kernel: Initializing XFRM netlink socket Jul 6 15:59:11 Wintermute rc.docker: Docker daemon... Started. Jul 6 15:59:11 Wintermute rc.docker: Starting network... Jul 6 15:59:11 Wintermute rc.docker: Network started. Jul 6 15:59:11 Wintermute rc.docker: Starting containers... Jul 6 15:59:12 Wintermute update_services: delay = 10s Jul 6 15:59:12 Wintermute kernel: docker0: port 1(veth83d1678) entered blocking state Jul 6 15:59:12 Wintermute kernel: docker0: port 1(veth83d1678) entered disabled state Jul 6 15:59:12 Wintermute kernel: veth83d1678: entered allmulticast mode Jul 6 15:59:12 Wintermute kernel: veth83d1678: entered promiscuous mode Jul 6 15:59:12 Wintermute kernel: mdcmd (36): check correct Jul 6 15:59:12 Wintermute kernel: md: recovery thread: check P ... Jul 6 15:59:13 Wintermute kernel: ata12.00: exception Emask 0x11 SAct 0x3f8 SErr 0x0 action 0x6 frozen Jul 6 15:59:13 Wintermute kernel: ata12.00: irq_stat 0x48000008, interface fatal error Jul 6 15:59:13 Wintermute kernel: ata12.00: failed command: READ FPDMA QUEUED Jul 6 15:59:13 Wintermute kernel: ata12.00: cmd 60/40:18:00:32:00/05:00:00:00:00/40 tag 3 ncq dma 688128 in Jul 6 15:59:13 Wintermute kernel: res 41/84:00:00:00:00/00:00:00:00:00/00 Emask 0x10 (ATA bus error) Jul 6 15:59:13 Wintermute kernel: ata12.00: status: { DRDY ERR } Jul 6 15:59:13 Wintermute kernel: ata12.00: error: { ICRC ABRT } Jul 6 15:59:13 Wintermute kernel: ata12.00: failed command: READ FPDMA QUEUED Jul 6 15:59:13 Wintermute kernel: ata12.00: cmd 60/40:20:40:37:00/05:00:00:00:00/40 tag 4 ncq dma 688128 in Jul 6 15:59:13 Wintermute kernel: res 41/84:00:00:00:00/00:00:00:00:00/00 Emask 0x10 (ATA bus error) Jul 6 15:59:13 Wintermute kernel: ata12.00: status: { DRDY ERR } Jul 6 15:59:13 Wintermute kernel: ata12.00: error: { ICRC ABRT } Jul 6 15:59:13 Wintermute kernel: ata12.00: failed command: READ FPDMA QUEUED Jul 6 15:59:13 Wintermute kernel: ata12.00: cmd 60/40:28:80:3c:00/05:00:00:00:00/40 tag 5 ncq dma 688128 in Jul 6 15:59:13 Wintermute kernel: res 41/84:00:00:00:00/00:00:00:00:00/00 Emask 0x10 (ATA bus error) Jul 6 15:59:13 Wintermute kernel: ata12.00: status: { DRDY ERR } Jul 6 15:59:13 Wintermute kernel: ata12.00: error: { ICRC ABRT } Jul 6 15:59:13 Wintermute kernel: ata12.00: failed command: READ FPDMA QUEUED Jul 6 15:59:13 Wintermute kernel: ata12.00: cmd 60/40:30:c0:41:00/05:00:00:00:00/40 tag 6 ncq dma 688128 in Jul 6 15:59:13 Wintermute kernel: res 41/84:00:00:00:00/00:00:00:00:00/00 Emask 0x10 (ATA bus error) Jul 6 15:59:13 Wintermute kernel: ata12.00: status: { DRDY ERR } Jul 6 15:59:13 Wintermute kernel: ata12.00: error: { ICRC ABRT } Jul 6 15:59:13 Wintermute kernel: ata12.00: failed command: READ FPDMA QUEUED Jul 6 15:59:13 Wintermute kernel: ata12.00: cmd 60/40:38:00:47:00/05:00:00:00:00/40 tag 7 ncq dma 688128 in Jul 6 15:59:13 Wintermute kernel: res 41/84:00:00:00:00/00:00:00:00:00/00 Emask 0x10 (ATA bus error) Jul 6 15:59:13 Wintermute kernel: ata12.00: status: { DRDY ERR } Jul 6 15:59:13 Wintermute kernel: ata12.00: error: { ICRC ABRT } Jul 6 15:59:13 Wintermute kernel: ata12.00: failed command: READ FPDMA QUEUED Jul 6 15:59:13 Wintermute kernel: ata12.00: cmd 60/80:40:40:4c:00/00:00:00:00:00/40 tag 8 ncq dma 65536 in Jul 6 15:59:13 Wintermute kernel: res 41/84:00:00:00:00/00:00:00:00:00/00 Emask 0x10 (ATA bus error) Jul 6 15:59:13 Wintermute kernel: ata12.00: status: { DRDY ERR } Jul 6 15:59:13 Wintermute kernel: ata12.00: error: { ICRC ABRT } Jul 6 15:59:13 Wintermute kernel: ata12.00: failed command: READ FPDMA QUEUED Jul 6 15:59:13 Wintermute kernel: ata12.00: cmd 60/40:48:c0:4c:00/05:00:00:00:00/40 tag 9 ncq dma 688128 in Jul 6 15:59:13 Wintermute kernel: res 41/84:00:00:00:00/00:00:00:00:00/00 Emask 0x10 (ATA bus error) Jul 6 15:59:13 Wintermute kernel: ata12.00: status: { DRDY ERR } Jul 6 15:59:13 Wintermute kernel: ata12.00: error: { ICRC ABRT } Jul 6 15:59:13 Wintermute kernel: ata12: hard resetting link Jul 6 15:59:13 Wintermute kernel: ata12: SATA link up 6.0 Gbps (SStatus 133 SControl 300) Jul 6 15:59:13 Wintermute kernel: ata12.00: configured for UDMA/133 Jul 6 15:59:13 Wintermute kernel: ata12: EH complete Jul 6 15:59:14 Wintermute sudo: root : PWD=/ ; USER=root ; COMMAND=/usr/bin/bash -c 'env DRY_RUN=false NOTIFY_PLAN=0 NOTIFY_TRANSFER=0 RESERVED_AMOUNT=1 RESERVED_UNIT=Gb RSYNC_ARGS=-X VERBOSITY=0 REFRESH_RATE=5000 /usr/local/emhttp/plugins/unbalanced/unbalanced --port 7090' Jul 6 15:59:14 Wintermute sudo: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0) Jul 6 15:59:14 Wintermute kernel: ata12: limiting SATA link speed to 3.0 Gbps Jul 6 15:59:14 Wintermute kernel: ata12.00: exception Emask 0x11 SAct 0x1fc00000 SErr 0x0 action 0x6 frozen Jul 6 15:59:14 Wintermute kernel: ata12.00: irq_stat 0x48000008, interface fatal error Jul 6 15:59:14 Wintermute kernel: ata12.00: failed command: READ FPDMA QUEUED Jul 6 15:59:14 Wintermute kernel: ata12.00: cmd 60/40:b0:40:7b:00/05:00:00:00:00/40 tag 22 ncq dma 688128 in Jul 6 15:59:14 Wintermute kernel: res 41/84:01:01:4f:c2/00:00:00:00:00/00 Emask 0x10 (ATA bus error) Jul 6 15:59:14 Wintermute kernel: ata12.00: status: { DRDY ERR } Jul 6 15:59:14 Wintermute kernel: ata12.00: error: { ICRC ABRT } Jul 6 15:59:14 Wintermute kernel: ata12.00: failed command: READ FPDMA QUEUED Jul 6 15:59:14 Wintermute kernel: ata12.00: cmd 60/40:b8:80:80:00/05:00:00:00:00/40 tag 23 ncq dma 688128 in Jul 6 15:59:14 Wintermute kernel: res 41/84:00:00:00:00/00:00:00:00:00/00 Emask 0x10 (ATA bus error) Jul 6 15:59:14 Wintermute kernel: ata12.00: status: { DRDY ERR } Jul 6 15:59:14 Wintermute kernel: ata12.00: error: { ICRC ABRT } Jul 6 15:59:14 Wintermute kernel: ata12.00: failed command: READ FPDMA QUEUED Jul 6 15:59:14 Wintermute kernel: ata12.00: cmd 60/40:c0:c0:85:00/05:00:00:00:00/40 tag 24 ncq dma 688128 in Jul 6 15:59:14 Wintermute kernel: res 41/84:00:00:00:00/00:00:00:00:00/00 Emask 0x10 (ATA bus error) Jul 6 15:59:14 Wintermute kernel: ata12.00: status: { DRDY ERR } Jul 6 15:59:14 Wintermute kernel: ata12.00: error: { ICRC ABRT } Jul 6 15:59:14 Wintermute kernel: ata12.00: failed command: READ FPDMA QUEUED Jul 6 15:59:14 Wintermute kernel: ata12.00: cmd 60/40:c8:00:8b:00/05:00:00:00:00/40 tag 25 ncq dma 688128 in Jul 6 15:59:14 Wintermute kernel: res 41/84:00:00:00:00/00:00:00:00:00/00 Emask 0x10 (ATA bus error) Jul 6 15:59:14 Wintermute kernel: ata12.00: status: { DRDY ERR } Jul 6 15:59:14 Wintermute kernel: ata12.00: error: { ICRC ABRT } Jul 6 15:59:14 Wintermute kernel: ata12.00: failed command: READ FPDMA QUEUED Jul 6 15:59:14 Wintermute kernel: ata12.00: cmd 60/40:d0:40:90:00/05:00:00:00:00/40 tag 26 ncq dma 688128 in Jul 6 15:59:14 Wintermute kernel: res 41/84:00:00:00:00/00:00:00:00:00/00 Emask 0x10 (ATA bus error) Jul 6 15:59:14 Wintermute kernel: ata12.00: status: { DRDY ERR } Jul 6 15:59:14 Wintermute kernel: ata12.00: error: { ICRC ABRT } Jul 6 15:59:14 Wintermute kernel: ata12.00: failed command: READ FPDMA QUEUED Jul 6 15:59:14 Wintermute kernel: ata12.00: cmd 60/40:d8:80:95:00/05:00:00:00:00/40 tag 27 ncq dma 688128 in Jul 6 15:59:14 Wintermute kernel: res 41/84:00:00:00:00/00:00:00:00:00/00 Emask 0x10 (ATA bus error) Jul 6 15:59:14 Wintermute kernel: ata12.00: status: { DRDY ERR } Jul 6 15:59:14 Wintermute kernel: ata12.00: error: { ICRC ABRT } Jul 6 15:59:14 Wintermute kernel: ata12.00: failed command: READ FPDMA QUEUED Jul 6 15:59:14 Wintermute kernel: ata12.00: cmd 60/80:e0:c0:9a:00/00:00:00:00:00/40 tag 28 ncq dma 65536 in Jul 6 15:59:14 Wintermute kernel: res 41/84:00:00:00:00/00:00:00:00:00/00 Emask 0x10 (ATA bus error) Jul 6 15:59:14 Wintermute kernel: ata12.00: status: { DRDY ERR } Jul 6 15:59:14 Wintermute kernel: ata12.00: error: { ICRC ABRT } Jul 6 15:59:14 Wintermute kernel: ata12: hard resetting link Jul 6 15:59:14 Wintermute kernel: ata12: SATA link up 3.0 Gbps (SStatus 123 SControl 320) Jul 6 15:59:14 Wintermute kernel: ata12.00: configured for UDMA/133 Jul 6 15:59:14 Wintermute kernel: ata12: EH complete Jul 6 15:59:14 Wintermute kernel: eth0: renamed from vethf2197c9 Jul 6 15:59:14 Wintermute kernel: docker0: port 1(veth83d1678) entered blocking state Jul 6 15:59:14 Wintermute kernel: docker0: port 1(veth83d1678) entered forwarding state Jul 6 15:59:15 Wintermute rc.docker: container_add_route DiskSpeed Jul 6 15:59:15 Wintermute rc.docker: DiskSpeed: started successfully! Jul 6 15:59:15 Wintermute kernel: docker0: port 2(veth08eb3e5) entered blocking state Jul 6 15:59:15 Wintermute kernel: docker0: port 2(veth08eb3e5) entered disabled state Jul 6 15:59:15 Wintermute kernel: veth08eb3e5: entered allmulticast mode Jul 6 15:59:15 Wintermute kernel: veth08eb3e5: entered promiscuous mode Jul 6 15:59:15 Wintermute kernel: docker0: port 2(veth08eb3e5) entered blocking state Jul 6 15:59:15 Wintermute kernel: docker0: port 2(veth08eb3e5) entered forwarding state Jul 6 15:59:15 Wintermute kernel: docker0: port 2(veth08eb3e5) entered disabled state Jul 6 15:59:19 Wintermute kernel: eth0: renamed from veth4f4882b Jul 6 15:59:19 Wintermute kernel: docker0: port 2(veth08eb3e5) entered blocking state Jul 6 15:59:19 Wintermute kernel: docker0: port 2(veth08eb3e5) entered forwarding state Jul 6 15:59:19 Wintermute rc.nfsd: Updating NFS server daemon... Jul 6 15:59:19 Wintermute rc.nfsd: Restarting NFS server daemon... Jul 6 15:59:19 Wintermute rc.nfsd: Stopping NFS server daemon... Jul 6 15:59:19 Wintermute rpc.mountd[4103]: Caught signal 15, un-registering and exiting. Jul 6 15:59:19 Wintermute rc.nfsd: /usr/sbin/rpc.nfsd 0 Jul 6 15:59:19 Wintermute rc.nfsd: /usr/sbin/exportfs -au Jul 6 15:59:19 Wintermute rc.nfsd: NFS server daemon... Stopped. Jul 6 15:59:19 Wintermute rc.docker: container_add_route mariadb Jul 6 15:59:19 Wintermute rc.docker: mariadb: started successfully! Jul 6 15:59:19 Wintermute rc.docker: Containers started. Jul 6 15:59:20 Wintermute rc.nfsd: Starting NFS server daemon... Jul 6 15:59:20 Wintermute rc.nfsd: /usr/sbin/exportfs -r Jul 6 15:59:20 Wintermute rc.nfsd: /usr/sbin/rpc.nfsd -u -H 192.168.50.245 -H 127.0.0.1 -s 8 Jul 6 15:59:21 Wintermute webgui: Successful login user root from 192.168.50.48 Jul 6 15:59:22 Wintermute kernel: NFSD: Using UMH upcall client tracking operations. Jul 6 15:59:22 Wintermute kernel: NFSD: starting 90-second grace period (net f0000000) Jul 6 15:59:22 Wintermute rc.nfsd: /usr/sbin/rpc.mountd Jul 6 15:59:22 Wintermute rpc.mountd[8163]: Version 2.8.2 starting Jul 6 15:59:22 Wintermute rc.nfsd: NFS server daemon... Started. Jul 6 15:59:22 Wintermute rc.nginx: Updating Nginx server daemon... Jul 6 15:59:22 Wintermute rc.nginx: Reloading Nginx server daemon... Jul 6 15:59:22 Wintermute rc.nginx: Checking configuration for correct syntax and then trying to open files referenced in configuration... Jul 6 15:59:22 Wintermute rc.nginx: /usr/sbin/nginx -t -c /etc/nginx/nginx.conf Jul 6 15:59:22 Wintermute rc.nginx: Reloading Nginx server daemon configuration... Jul 6 15:59:25 Wintermute nginx: 2025/07/06 15:59:25 [alert] 4958#4958: *93 open socket #18 left in connection 7 Jul 6 15:59:25 Wintermute nginx: 2025/07/06 15:59:25 [alert] 4958#4958: aborting Jul 6 15:59:59 Wintermute chpasswd[9429]: pam_unix(chpasswd:chauthtok): password changed for streamer Jul 6 15:59:59 Wintermute emhttpd: shcmd (108): cp /etc/passwd /etc/shadow /var/lib/samba/private/smbpasswd /boot/config Jul 6 16:00:06 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:00:06 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:00:06 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:00:06 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:00:09 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:00:09 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID) Jul 6 16:00:09 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000001/00002000 Jul 6 16:00:09 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First) Jul 6 16:03:59 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:03:59 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:03:59 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:03:59 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:04:29 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:04:29 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:04:29 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:04:29 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:04:55 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:04:55 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:04:55 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:04:55 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:04:56 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:04:56 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:04:56 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:04:56 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:05:26 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:05:26 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:05:26 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000040/00002000 Jul 6 16:05:26 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 6] BadTLP Jul 6 16:06:19 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:06:19 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:06:19 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:06:19 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:07:18 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:07:18 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:07:18 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:07:18 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:08:00 Wintermute root: Fix Common Problems Version 2025.05.29 Jul 6 16:08:01 Wintermute root: Fix Common Problems: Warning: Docker Application mariadb has an update available for it Jul 6 16:08:02 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:08:02 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:08:02 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:08:02 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:08:46 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:08:46 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:08:46 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:08:46 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:09:05 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:09:05 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:09:05 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:09:05 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:09:28 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:09:28 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:09:28 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:09:28 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:10:01 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:10:01 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:10:01 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:10:01 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:10:45 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:10:45 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:10:45 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:10:45 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:11:02 Wintermute root: Fix Common Problems: Error: ResierFS on disk2 reiserfs Jul 6 16:11:02 Wintermute root: Fix Common Problems: Error: ResierFS on disk3 reiserfs Jul 6 16:11:02 Wintermute root: Fix Common Problems: Error: ResierFS on disk4 reiserfs Jul 6 16:11:02 Wintermute root: Fix Common Problems: Error: ResierFS on disk5 reiserfs Jul 6 16:11:02 Wintermute root: Fix Common Problems: Error: ResierFS on disk6 reiserfs Jul 6 16:11:02 Wintermute root: Fix Common Problems: Error: ResierFS on disk7 reiserfs Jul 6 16:11:03 Wintermute root: Fix Common Problems: Other Warning: Background notifications not enabled Jul 6 16:11:03 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:11:03 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:11:03 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:11:03 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:11:27 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:11:27 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:11:27 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:11:27 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:11:33 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:11:33 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:11:33 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:11:33 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:11:48 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:11:48 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:11:48 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:11:48 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:14:53 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:14:53 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:14:53 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:14:53 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:15:29 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:15:29 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:15:29 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:15:29 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:15:46 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:15:46 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:15:46 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:15:46 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:17:02 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:17:02 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:17:02 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:17:02 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:17:10 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:17:10 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:17:10 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:17:10 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:17:27 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:17:27 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:17:27 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:17:27 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:18:49 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:18:49 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID) Jul 6 16:18:49 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000001/00002000 Jul 6 16:18:49 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First) Jul 6 16:18:59 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:18:59 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:18:59 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:18:59 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:19:53 Wintermute nginx: 2025/07/06 16:19:53 [error] 8235#8235: *7574 limiting requests, excess: 20.088 by zone "authlimit", client: 192.168.50.48, server: , request: "PROPFIND /login HTTP/1.1", host: "192.168.50.245" Jul 6 16:19:53 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:19:53 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:19:53 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:19:53 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:19:54 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 6875 does not match to the expected one 1 Jul 6 16:19:54 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272428. Fsck? Jul 6 16:19:54 Wintermute kernel: REISERFS (device md7p1): Remounting filesystem read-only Jul 6 16:19:54 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370822 373644 0x0 SD] Jul 6 16:19:54 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 6875 does not match to the expected one 1 Jul 6 16:19:54 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272428. Fsck? Jul 6 16:19:54 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370822 373644 0x0 SD] Jul 6 16:19:54 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 6875 does not match to the expected one 1 Jul 6 16:19:54 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272428. Fsck? Jul 6 16:19:54 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370822 373644 0x0 SD] Jul 6 16:19:54 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 6875 does not match to the expected one 1 Jul 6 16:19:54 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272428. Fsck? Jul 6 16:19:54 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370822 384846 0x0 SD] Jul 6 16:19:54 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 6875 does not match to the expected one 1 Jul 6 16:19:54 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272428. Fsck? Jul 6 16:19:54 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370822 384846 0x0 SD] Jul 6 16:19:54 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 6875 does not match to the expected one 1 Jul 6 16:19:54 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272428. Fsck? Jul 6 16:19:54 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370822 384846 0x0 SD] Jul 6 16:19:54 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 33290 does not match to the expected one 1 Jul 6 16:19:54 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 340325448. Fsck? Jul 6 16:19:54 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370266 358622 0x0 SD] Jul 6 16:19:54 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 33290 does not match to the expected one 1 Jul 6 16:19:54 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 340325448. Fsck? Jul 6 16:19:54 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370266 358622 0x0 SD] Jul 6 16:19:54 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 33290 does not match to the expected one 1 Jul 6 16:19:54 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 340325448. Fsck? Jul 6 16:19:54 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370266 358622 0x0 SD] Jul 6 16:19:54 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 33290 does not match to the expected one 1 Jul 6 16:19:54 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 340325448. Fsck? Jul 6 16:19:54 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370266 358623 0x0 SD] Jul 6 16:19:54 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 33290 does not match to the expected one 1 Jul 6 16:19:54 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 340325448. Fsck? Jul 6 16:19:54 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370266 358623 0x0 SD] Jul 6 16:19:54 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 33290 does not match to the expected one 1 Jul 6 16:19:54 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 340325448. Fsck? Jul 6 16:19:54 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370266 358623 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 54999 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272427. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370162 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 54999 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272427. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370162 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 54999 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272427. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370162 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 54999 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272427. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370163 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 54999 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272427. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370163 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 54999 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272427. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370163 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 45598 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 478611531. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 368046 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 45598 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 478611531. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 368046 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 45598 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 478611531. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 368046 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370200 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370200 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370200 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370202 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370202 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370202 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370204 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370204 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370204 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370206 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370206 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370206 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370199 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370199 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370199 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370201 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370201 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370201 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370203 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370203 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370203 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370205 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370205 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370205 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370248 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370248 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370248 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 45598 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 478611531. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370160 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 45598 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 478611531. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370160 0x0 SD] Jul 6 16:19:55 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 45598 does not match to the expected one 1 Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 478611531. Fsck? Jul 6 16:19:55 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370160 0x0 SD] Jul 6 16:20:00 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 6875 does not match to the expected one 1 Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272428. Fsck? Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370822 373644 0x0 SD] Jul 6 16:20:00 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 6875 does not match to the expected one 1 Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272428. Fsck? Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370822 384846 0x0 SD] Jul 6 16:20:00 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 33290 does not match to the expected one 1 Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 340325448. Fsck? Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370266 358622 0x0 SD] Jul 6 16:20:00 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 33290 does not match to the expected one 1 Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 340325448. Fsck? Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370266 358623 0x0 SD] Jul 6 16:20:00 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 54999 does not match to the expected one 1 Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272427. Fsck? Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370162 0x0 SD] Jul 6 16:20:00 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 54999 does not match to the expected one 1 Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272427. Fsck? Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370163 0x0 SD] Jul 6 16:20:00 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 45598 does not match to the expected one 1 Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 478611531. Fsck? Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 368046 0x0 SD] Jul 6 16:20:00 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370200 0x0 SD] Jul 6 16:20:00 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370202 0x0 SD] Jul 6 16:20:00 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370204 0x0 SD] Jul 6 16:20:00 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370206 0x0 SD] Jul 6 16:20:00 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370199 0x0 SD] Jul 6 16:20:00 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370201 0x0 SD] Jul 6 16:20:00 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370203 0x0 SD] Jul 6 16:20:00 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370205 0x0 SD] Jul 6 16:20:00 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370248 0x0 SD] Jul 6 16:20:00 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 45598 does not match to the expected one 1 Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 478611531. Fsck? Jul 6 16:20:00 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370160 0x0 SD] Jul 6 16:20:03 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:20:03 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:20:03 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:20:03 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:20:06 Wintermute kernel: I/O error, dev loop2, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 2 Jul 6 16:20:06 Wintermute kernel: BTRFS error (device loop2): bdev /dev/loop2 errs: wr 0, rd 0, flush 1, corrupt 0, gen 0 Jul 6 16:20:06 Wintermute kernel: BTRFS warning (device loop2): chunk 0 missing 1 devices, max tolerance is 0 for writable mount Jul 6 16:20:06 Wintermute kernel: BTRFS: error (device loop2) in write_all_supers:4094: errno=-5 IO failure (errors while submitting device barriers.) Jul 6 16:20:06 Wintermute kernel: BTRFS info (device loop2: state E): forced readonly Jul 6 16:20:06 Wintermute kernel: BTRFS warning (device loop2: state E): Skipping commit of aborted transaction. Jul 6 16:20:06 Wintermute kernel: BTRFS error (device loop2: state EA): Transaction aborted (error -5) Jul 6 16:20:06 Wintermute kernel: BTRFS: error (device loop2: state EA) in cleanup_transaction:2004: errno=-5 IO failure Jul 6 16:20:15 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:20:15 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:20:15 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:20:15 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:20:27 Wintermute kernel: mdcmd (37): nocheck cancel Jul 6 16:20:27 Wintermute kernel: md: recovery thread: exit status: -4 Jul 6 16:22:32 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 6875 does not match to the expected one 1 Jul 6 16:22:32 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272428. Fsck? Jul 6 16:22:32 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370822 373644 0x0 SD] Jul 6 16:22:32 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 6875 does not match to the expected one 1 Jul 6 16:22:32 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272428. Fsck? Jul 6 16:22:32 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370822 373644 0x0 SD] Jul 6 16:22:32 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 6875 does not match to the expected one 1 Jul 6 16:22:32 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272428. Fsck? Jul 6 16:22:32 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370822 373644 0x0 SD] Jul 6 16:22:32 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 6875 does not match to the expected one 1 Jul 6 16:22:32 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272428. Fsck? Jul 6 16:22:32 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370822 384846 0x0 SD] Jul 6 16:22:32 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 6875 does not match to the expected one 1 Jul 6 16:22:32 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272428. Fsck? Jul 6 16:22:32 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370822 384846 0x0 SD] Jul 6 16:22:32 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 6875 does not match to the expected one 1 Jul 6 16:22:32 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272428. Fsck? Jul 6 16:22:32 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370822 384846 0x0 SD] Jul 6 16:22:32 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 33290 does not match to the expected one 1 Jul 6 16:22:32 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 340325448. Fsck? Jul 6 16:22:32 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370266 358622 0x0 SD] Jul 6 16:22:32 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 33290 does not match to the expected one 1 Jul 6 16:22:32 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 340325448. Fsck? Jul 6 16:22:32 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370266 358622 0x0 SD] Jul 6 16:22:32 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 33290 does not match to the expected one 1 Jul 6 16:22:32 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 340325448. Fsck? Jul 6 16:22:32 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370266 358622 0x0 SD] Jul 6 16:22:32 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 33290 does not match to the expected one 1 Jul 6 16:22:32 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 340325448. Fsck? Jul 6 16:22:32 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370266 358623 0x0 SD] Jul 6 16:22:32 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 33290 does not match to the expected one 1 Jul 6 16:22:32 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 340325448. Fsck? Jul 6 16:22:32 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370266 358623 0x0 SD] Jul 6 16:22:32 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 33290 does not match to the expected one 1 Jul 6 16:22:32 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 340325448. Fsck? Jul 6 16:22:32 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370266 358623 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 54999 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272427. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370162 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 54999 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272427. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370162 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 54999 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272427. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370162 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 54999 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272427. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370163 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 54999 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272427. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370163 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 54999 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272427. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370163 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 45598 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 478611531. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 368046 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 45598 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 478611531. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 368046 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 45598 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 478611531. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 368046 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370200 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370200 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370200 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370202 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370202 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370202 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370204 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370204 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370204 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370206 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370206 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370206 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370199 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370199 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370199 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370201 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370201 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370201 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370203 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370203 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370203 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370205 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370205 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370205 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370248 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370248 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370248 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 45598 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 478611531. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370160 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 45598 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 478611531. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370160 0x0 SD] Jul 6 16:22:33 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 45598 does not match to the expected one 1 Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 478611531. Fsck? Jul 6 16:22:33 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370160 0x0 SD] Jul 6 16:22:35 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 6875 does not match to the expected one 1 Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272428. Fsck? Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370822 373644 0x0 SD] Jul 6 16:22:35 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 6875 does not match to the expected one 1 Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272428. Fsck? Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370822 384846 0x0 SD] Jul 6 16:22:35 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 33290 does not match to the expected one 1 Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 340325448. Fsck? Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370266 358622 0x0 SD] Jul 6 16:22:35 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 33290 does not match to the expected one 1 Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 340325448. Fsck? Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370266 358623 0x0 SD] Jul 6 16:22:35 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 54999 does not match to the expected one 1 Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272427. Fsck? Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370162 0x0 SD] Jul 6 16:22:35 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 54999 does not match to the expected one 1 Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272427. Fsck? Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370163 0x0 SD] Jul 6 16:22:35 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 45598 does not match to the expected one 1 Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 478611531. Fsck? Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 368046 0x0 SD] Jul 6 16:22:35 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370200 0x0 SD] Jul 6 16:22:35 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370202 0x0 SD] Jul 6 16:22:35 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370204 0x0 SD] Jul 6 16:22:35 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370206 0x0 SD] Jul 6 16:22:35 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370199 0x0 SD] Jul 6 16:22:35 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370201 0x0 SD] Jul 6 16:22:35 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370203 0x0 SD] Jul 6 16:22:35 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370205 0x0 SD] Jul 6 16:22:35 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370248 0x0 SD] Jul 6 16:22:35 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 45598 does not match to the expected one 1 Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 478611531. Fsck? Jul 6 16:22:35 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370160 0x0 SD] Jul 6 16:22:41 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:22:41 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Transmitter ID) Jul 6 16:22:41 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00001001/00002000 Jul 6 16:22:41 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First) Jul 6 16:22:41 Wintermute kernel: xhci_hcd 0000:01:00.0: [12] Timeout Jul 6 16:22:41 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:31:33 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:31:33 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:31:33 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:31:33 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:33:03 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:33:03 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 16:33:03 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 16:33:03 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 16:45:12 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:45:12 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Transmitter ID) Jul 6 16:45:12 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00001001/00002000 Jul 6 16:45:12 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First) Jul 6 16:45:12 Wintermute kernel: xhci_hcd 0000:01:00.0: [12] Timeout Jul 6 16:45:12 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:46:00 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 16:46:00 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID) Jul 6 16:46:00 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000001/00002000 Jul 6 16:46:00 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First) Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 6875 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272428. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370822 373644 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 6875 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272428. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370822 373644 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 6875 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272428. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370822 373644 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 6875 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272428. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370822 384846 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 6875 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272428. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370822 384846 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 6875 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272428. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370822 384846 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 33290 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 340325448. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370266 358622 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 33290 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 340325448. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370266 358622 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 33290 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 340325448. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370266 358622 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 33290 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 340325448. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370266 358623 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 33290 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 340325448. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370266 358623 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 33290 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 340325448. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370266 358623 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 54999 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272427. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370162 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 54999 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272427. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370162 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 54999 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272427. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370162 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 54999 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272427. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370163 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 54999 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272427. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370163 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 54999 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272427. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370163 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 45598 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 478611531. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 368046 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 45598 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 478611531. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 368046 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 45598 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 478611531. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 368046 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370200 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370200 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370200 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370202 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370202 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370202 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370204 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370204 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370204 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370206 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370206 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370206 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370199 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370199 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370199 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370201 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370201 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370201 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370203 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370203 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370203 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370205 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370205 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370205 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370248 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370248 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370248 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 45598 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 478611531. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370160 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 45598 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 478611531. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370160 0x0 SD] Jul 6 16:48:57 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 45598 does not match to the expected one 1 Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 478611531. Fsck? Jul 6 16:48:57 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370160 0x0 SD] Jul 6 16:48:59 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 6875 does not match to the expected one 1 Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272428. Fsck? Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370822 373644 0x0 SD] Jul 6 16:48:59 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 6875 does not match to the expected one 1 Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272428. Fsck? Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370822 384846 0x0 SD] Jul 6 16:48:59 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 33290 does not match to the expected one 1 Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 340325448. Fsck? Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370266 358622 0x0 SD] Jul 6 16:48:59 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 33290 does not match to the expected one 1 Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 340325448. Fsck? Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370266 358623 0x0 SD] Jul 6 16:48:59 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 54999 does not match to the expected one 1 Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272427. Fsck? Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370162 0x0 SD] Jul 6 16:48:59 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 54999 does not match to the expected one 1 Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272427. Fsck? Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370163 0x0 SD] Jul 6 16:48:59 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 45598 does not match to the expected one 1 Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 478611531. Fsck? Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 368046 0x0 SD] Jul 6 16:48:59 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370200 0x0 SD] Jul 6 16:48:59 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370202 0x0 SD] Jul 6 16:48:59 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370204 0x0 SD] Jul 6 16:48:59 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370206 0x0 SD] Jul 6 16:48:59 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370199 0x0 SD] Jul 6 16:48:59 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 16150 does not match to the expected one 1 Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272342. Fsck? Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370201 0x0 SD] Jul 6 16:48:59 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 10097 does not match to the expected one 1 Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272343. Fsck? Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370203 0x0 SD] Jul 6 16:48:59 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370205 0x0 SD] Jul 6 16:48:59 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 3591 does not match to the expected one 1 Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck? Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370248 0x0 SD] Jul 6 16:48:59 Wintermute kernel: REISERFS warning: reiserfs-5090 is_tree_node: node level 45598 does not match to the expected one 1 Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-5150 search_by_key: invalid format found in block 478611531. Fsck? Jul 6 16:48:59 Wintermute kernel: REISERFS error (device md7p1): vs-13070 reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [370815 370160 0x0 SD] Jul 6 17:29:54 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 17:29:54 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Transmitter ID) Jul 6 17:29:54 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00001001/00002000 Jul 6 17:29:54 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First) Jul 6 17:29:54 Wintermute kernel: xhci_hcd 0000:01:00.0: [12] Timeout Jul 6 17:29:54 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 17:38:17 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 17:38:17 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Transmitter ID) Jul 6 17:38:17 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00001001/00002000 Jul 6 17:38:17 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First) Jul 6 17:38:17 Wintermute kernel: xhci_hcd 0000:01:00.0: [12] Timeout Jul 6 17:38:17 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 17:40:21 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 17:40:21 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Transmitter ID) Jul 6 17:40:21 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00001001/00002000 Jul 6 17:40:21 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First) Jul 6 17:40:21 Wintermute kernel: xhci_hcd 0000:01:00.0: [12] Timeout Jul 6 17:40:21 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 17:54:08 Wintermute emhttpd: cmd: /usr/local/emhttp/plugins/fix.common.problems/scripts/newperms.sh Jul 6 18:00:11 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 18:00:11 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Transmitter ID) Jul 6 18:00:11 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00001001/00002000 Jul 6 18:00:11 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First) Jul 6 18:00:11 Wintermute kernel: xhci_hcd 0000:01:00.0: [12] Timeout Jul 6 18:00:11 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 18:01:47 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 18:01:47 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Transmitter ID) Jul 6 18:01:47 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00001001/00002000 Jul 6 18:01:47 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First) Jul 6 18:01:47 Wintermute kernel: xhci_hcd 0000:01:00.0: [12] Timeout Jul 6 18:01:47 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 18:11:24 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 18:11:24 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 18:11:24 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 18:11:24 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 18:13:54 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 18:13:54 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Transmitter ID) Jul 6 18:13:54 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00001001/00002000 Jul 6 18:13:54 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First) Jul 6 18:13:54 Wintermute kernel: xhci_hcd 0000:01:00.0: [12] Timeout Jul 6 18:13:54 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 18:35:13 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 18:35:13 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 18:35:13 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 18:35:13 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 18:55:08 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 18:55:08 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Transmitter ID) Jul 6 18:55:08 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00001001/00002000 Jul 6 18:55:08 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First) Jul 6 18:55:08 Wintermute kernel: xhci_hcd 0000:01:00.0: [12] Timeout Jul 6 18:55:08 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 18:59:16 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 18:59:16 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Transmitter ID) Jul 6 18:59:16 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00001001/00002000 Jul 6 18:59:16 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First) Jul 6 18:59:16 Wintermute kernel: xhci_hcd 0000:01:00.0: [12] Timeout Jul 6 18:59:16 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 19:01:35 Wintermute nginx: 2025/07/06 19:01:35 [error] 8235#8235: *50052 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 192.168.50.48, server: , request: "GET /plugins/dynamix.local.master/include/LocalMaster.php HTTP/1.1", subrequest: "/auth-request.php", upstream: "fastcgi://unix:/var/run/php-fpm.sock", host: "192.168.50.245", referrer: "http://192.168.50.245/Tools/DockerSafeNewPerms" Jul 6 19:01:35 Wintermute nginx: 2025/07/06 19:01:35 [error] 8235#8235: *50052 auth request unexpected status: 504 while sending to client, client: 192.168.50.48, server: , request: "GET /plugins/dynamix.local.master/include/LocalMaster.php HTTP/1.1", host: "192.168.50.245", referrer: "http://192.168.50.245/Tools/DockerSafeNewPerms" Jul 6 19:05:51 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 19:05:51 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID) Jul 6 19:05:51 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000080/00002000 Jul 6 19:05:51 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 7] BadDLLP Jul 6 19:19:04 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 19:19:04 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID) Jul 6 19:19:04 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00000001/00002000 Jul 6 19:19:04 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First) Jul 6 19:19:51 Wintermute kernel: docker0: port 2(veth08eb3e5) entered disabled state Jul 6 19:19:51 Wintermute kernel: veth4f4882b: renamed from eth0 Jul 6 19:29:42 Wintermute nginx: 2025/07/06 19:29:42 [error] 8235#8235: *65133 limiting requests, excess: 20.953 by zone "authlimit", client: 192.168.50.48, server: , request: "PROPFIND /login HTTP/1.1", host: "192.168.50.245" Jul 6 19:29:42 Wintermute nginx: 2025/07/06 19:29:42 [error] 8235#8235: *65135 limiting requests, excess: 20.918 by zone "authlimit", client: 192.168.50.48, server: , request: "PROPFIND /login HTTP/1.1", host: "192.168.50.245" Jul 6 19:29:43 Wintermute nginx: 2025/07/06 19:29:43 [error] 8235#8235: *65137 limiting requests, excess: 20.881 by zone "authlimit", client: 192.168.50.48, server: , request: "PROPFIND /login HTTP/1.1", host: "192.168.50.245" Jul 6 19:35:11 Wintermute kernel: kvm_amd: SVM disabled (by BIOS) in MSR_VM_CR on CPU 1 Jul 6 19:41:31 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 19:41:31 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Transmitter ID) Jul 6 19:41:31 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00001001/00002000 Jul 6 19:41:31 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First) Jul 6 19:41:31 Wintermute kernel: xhci_hcd 0000:01:00.0: [12] Timeout Jul 6 19:41:31 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 19:42:06 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0 Jul 6 19:42:06 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Transmitter ID) Jul 6 19:42:06 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00001001/00002000 Jul 6 19:42:06 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First) Jul 6 19:42:06 Wintermute kernel: xhci_hcd 0000:01:00.0: [12] Timeout Jul 6 19:42:06 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0I'm not sure where to turn next so any help is very apprecaited! I was leaning towards formatting disk 1 and trying again, but I'm worried the mariadb is broken as wellThanks!
July 7, 20251 yr Community Expert 10 hours ago, Shadey1 said:(device md7p1): vs-5150 search_by_key: invalid format found in block 185272346. Fsck?Check filesystem don disk7
July 7, 20251 yr Author This seems pretty healthy for disk 7 (I asked claude😆)reiserfsck 3.6.27 Will read-only check consistency of the filesystem on /dev/md7p1 Will put log info to 'stdout' ########### reiserfsck --check started at Mon Jul 7 13:47:05 2025 ########### Replaying journal: Trans replayed: mountid 529, transid 2101693, desc 339, len 1, commit 341, next trans offset 324 Replaying journal: | | 0.1% 1 trans Trans replayed: mountid 529, transid 2101694, desc 342, len 1, commit 344, next trans offset 327 Trans replayed: mountid 529, transid 2101695, desc 345, len 1, commit 347, next trans offset 330 Replaying journal: | / 0.2% 3 trans Trans replayed: mountid 529, transid 2101696, desc 348, len 1, commit 350, next trans offset 333 Trans replayed: mountid 529, transid 2101697, desc 351, len 1, commit 353, next trans offset 336 Trans replayed: mountid 529, transid 2101698, desc 354, len 10, commit 365, next trans offset 348 Replaying journal: | - 0.4% 6 trans Trans replayed: mountid 529, transid 2101699, desc 366, len 20, commit 387, next trans offset 370 Replaying journal: | \ 0.5% 7 trans Trans replayed: mountid 529, transid 2101700, desc 388, len 5, commit 394, next trans offset 377 Replaying journal: | | 0.6% 8 trans Trans replayed: mountid 529, transid 2101701, desc 395, len 4, commit 400, next trans offset 383 Trans replayed: mountid 529, transid 2101702, desc 401, len 4, commit 406, next trans offset 389 Replaying journal: | / 0.7% 10 trans Trans replayed: mountid 529, transid 2101703, desc 407, len 4, commit 412, next trans offset 395 Trans replayed: mountid 529, transid 2101704, desc 413, len 4, commit 418, next trans offset 401 Trans replayed: mountid 529, transid 2101705, desc 419, len 4, commit 424, next trans offset 407 Replaying journal: | - 0.9% 13 trans Trans replayed: mountid 529, transid 2101706, desc 425, len 4, commit 430, next trans offset 413 Replaying journal: | \ 1.0% 14 trans Trans replayed: mountid 529, transid 2101707, desc 431, len 4, commit 436, next trans offset 419 Trans replayed: mountid 529, transid 2101708, desc 437, len 4, commit 442, next trans offset 425 Replaying journal: | | 1.1% 16 trans Trans replayed: mountid 529, transid 2101709, desc 443, len 4, commit 448, next trans offset 431 Trans replayed: mountid 529, transid 2101710, desc 449, len 4, commit 454, next trans offset 437 Trans replayed: mountid 529, transid 2101711, desc 455, len 4, commit 460, next trans offset 443 Replaying journal: |= / 1.3% 19 trans Trans replayed: mountid 529, transid 2101712, desc 461, len 4, commit 466, next trans offset 449 Trans replayed: mountid 529, transid 2101713, desc 467, len 4, commit 472, next trans offset 455 Replaying journal: |= - 1.5% 21 trans Trans replayed: mountid 529, transid 2101714, desc 473, len 4, commit 478, next trans offset 461 Trans replayed: mountid 529, transid 2101715, desc 479, len 4, commit 484, next trans offset 467 Replaying journal: |= \ 1.6% 23 trans Trans replayed: mountid 529, transid 2101716, desc 485, len 4, commit 490, next trans offset 473 Trans replayed: mountid 529, transid 2101717, desc 491, len 4, commit 496, next trans offset 479 Trans replayed: mountid 529, transid 2101718, desc 497, len 4, commit 502, next trans offset 485 Replaying journal: |= | 1.8% 26 trans Trans replayed: mountid 529, transid 2101719, desc 503, len 4, commit 508, next trans offset 491 Replaying journal: |= / 1.9% 27 trans Trans replayed: mountid 529, transid 2101720, desc 509, len 4, commit 514, next trans offset 497 Trans replayed: mountid 529, transid 2101721, desc 515, len 4, commit 520, next trans offset 503 Replaying journal: |= - 2.0% 29 trans Trans replayed: mountid 529, transid 2101722, desc 521, len 4, commit 526, next trans offset 509 Trans replayed: mountid 529, transid 2101723, desc 527, len 4, commit 532, next trans offset 515 Trans replayed: mountid 529, transid 2101724, desc 533, len 4, commit 538, next trans offset 521 Replaying journal: |= \ 2.2% 32 trans Trans replayed: mountid 529, transid 2101725, desc 539, len 4, commit 544, next trans offset 527 Replaying journal: |= | 2.3% 33 trans Trans replayed: mountid 529, transid 2101726, desc 545, len 4, commit 550, next trans offset 533 Trans replayed: mountid 529, transid 2101727, desc 551, len 4, commit 556, next trans offset 539 Trans replayed: mountid 529, transid 2101728, desc 557, len 4, commit 562, next trans offset 545 Replaying journal: |= / 2.5% 36 trans Trans replayed: mountid 529, transid 2101729, desc 563, len 4, commit 568, next trans offset 551 Trans replayed: mountid 529, transid 2101730, desc 569, len 4, commit 574, next trans offset 557 Trans replayed: mountid 529, transid 2101731, desc 575, len 4, commit 580, next trans offset 563 Replaying journal: |= - 2.7% 39 trans Trans replayed: mountid 529, transid 2101732, desc 581, len 4, commit 586, next trans offset 569 Replaying journal: |= \ 2.8% 40 trans Trans replayed: mountid 529, transid 2101733, desc 587, len 4, commit 592, next trans offset 575 Trans replayed: mountid 529, transid 2101734, desc 593, len 4, commit 598, next trans offset 581 Replaying journal: |= | 2.9% 42 trans Trans replayed: mountid 529, transid 2101735, desc 599, len 4, commit 604, next trans offset 587 Replaying journal: |= / 3.0% 43 trans Trans replayed: mountid 529, transid 2101736, desc 605, len 4, commit 610, next trans offset 593 Trans replayed: mountid 529, transid 2101737, desc 611, len 4, commit 616, next trans offset 599 Replaying journal: |= - 3.1% 45 trans Trans replayed: mountid 529, transid 2101738, desc 617, len 4, commit 622, next trans offset 605 Trans replayed: mountid 529, transid 2101739, desc 623, len 4, commit 628, next trans offset 611 Replaying journal: |= \ 3.3% 47 trans Trans replayed: mountid 529, transid 2101740, desc 629, len 4, commit 634, next trans offset 617 Trans replayed: mountid 529, transid 2101741, desc 635, len 4, commit 640, next trans offset 623 Replaying journal: |= | 3.4% 49 trans Trans replayed: mountid 529, transid 2101742, desc 641, len 4, commit 646, next trans offset 629 Replaying journal: |= / 3.5% 50 trans Trans replayed: mountid 529, transid 2101743, desc 647, len 4, commit 652, next trans offset 635 Trans replayed: mountid 529, transid 2101744, desc 653, len 4, commit 658, next trans offset 641 Replaying journal: |= - 3.6% 52 trans Trans replayed: mountid 529, transid 2101745, desc 659, len 4, commit 664, next trans offset 647 Trans replayed: mountid 529, transid 2101746, desc 665, len 4, commit 670, next trans offset 653 Trans replayed: mountid 529, transid 2101747, desc 671, len 4, commit 676, next trans offset 659 Replaying journal: |== \ 3.8% 55 trans Trans replayed: mountid 529, transid 2101748, desc 677, len 4, commit 682, next trans offset 665 Trans replayed: mountid 529, transid 2101749, desc 683, len 4, commit 688, next trans offset 671 Trans replayed: mountid 529, transid 2101750, desc 689, len 4, commit 694, next trans offset 677 Replaying journal: |== | 4.0% 58 trans Trans replayed: mountid 529, transid 2101751, desc 695, len 4, commit 700, next trans offset 683 Replaying journal: |== / 4.1% 59 trans Trans replayed: mountid 529, transid 2101752, desc 701, len 4, commit 706, next trans offset 689 Trans replayed: mountid 529, transid 2101753, desc 707, len 4, commit 712, next trans offset 695 Replaying journal: |== - 4.2% 61 trans Trans replayed: mountid 529, transid 2101754, desc 713, len 4, commit 718, next trans offset 701 Replaying journal: |== \ 4.3% 62 trans Trans replayed: mountid 529, transid 2101755, desc 719, len 4, commit 724, next trans offset 707 Trans replayed: mountid 529, transid 2101756, desc 725, len 4, commit 730, next trans offset 713 Trans replayed: mountid 529, transid 2101757, desc 731, len 4, commit 736, next trans offset 719 Replaying journal: |== | 4.5% 65 trans Trans replayed: mountid 529, transid 2101758, desc 737, len 4, commit 742, next trans offset 725 Replaying journal: |== / 4.6% 66 trans Trans replayed: mountid 529, transid 2101759, desc 743, len 4, commit 748, next trans offset 731 Trans replayed: mountid 529, transid 2101760, desc 749, len 4, commit 754, next trans offset 737 Replaying journal: |== - 4.7% 68 trans Trans replayed: mountid 529, transid 2101761, desc 755, len 4, commit 760, next trans offset 743 Trans replayed: mountid 529, transid 2101762, desc 761, len 4, commit 766, next trans offset 749 Trans replayed: mountid 529, transid 2101763, desc 767, len 4, commit 772, next trans offset 755 Replaying journal: |== \ 4.9% 71 trans Trans replayed: mountid 529, transid 2101764, desc 773, len 4, commit 778, next trans offset 761 Trans replayed: mountid 529, transid 2101765, desc 779, len 4, commit 784, next trans offset 767 Trans replayed: mountid 529, transid 2101766, desc 785, len 4, commit 790, next trans offset 773 Replaying journal: |== | 5.1% 74 trans Trans replayed: mountid 529, transid 2101767, desc 791, len 4, commit 796, next trans offset 779 Replaying journal: |== / 5.2% 75 trans Trans replayed: mountid 529, transid 2101768, desc 797, len 4, commit 802, next trans offset 785 Replaying journal: |== - 5.3% 76 trans Trans replayed: mountid 529, transid 2101769, desc 803, len 4, commit 808, next trans offset 791 Trans replayed: mountid 529, transid 2101770, desc 809, len 4, commit 814, next trans offset 797 Replaying journal: |== \ 5.4% 78 trans Trans replayed: mountid 529, transid 2101771, desc 815, len 4, commit 820, next trans offset 803 Trans replayed: mountid 529, transid 2101772, desc 821, len 4, commit 826, next trans offset 809 Trans replayed: mountid 529, transid 2101773, desc 827, len 4, commit 832, next trans offset 815 Replaying journal: |== | 5.6% 81 trans Trans replayed: mountid 529, transid 2101774, desc 833, len 4, commit 838, next trans offset 821 Replaying journal: |== / 5.7% 82 trans Trans replayed: mountid 529, transid 2101775, desc 839, len 4, commit 844, next trans offset 827 Trans replayed: mountid 529, transid 2101776, desc 845, len 4, commit 850, next trans offset 833 Replaying journal: |== - 5.8% 84 trans Trans replayed: mountid 529, transid 2101777, desc 851, len 4, commit 856, next trans offset 839 Replaying journal: |== \ 5.9% 85 trans Trans replayed: mountid 529, transid 2101778, desc 857, len 4, commit 862, next trans offset 845 Trans replayed: mountid 529, transid 2101779, desc 863, len 4, commit 868, next trans offset 851 Replaying journal: |== | 6.0% 87 trans Trans replayed: mountid 529, transid 2101780, desc 869, len 4, commit 874, next trans offset 857 Trans replayed: mountid 529, transid 2101781, desc 875, len 4, commit 880, next trans offset 863 Replaying journal: |== / 6.2% 89 trans Trans replayed: mountid 529, transid 2101782, desc 881, len 4, commit 886, next trans offset 869 Trans replayed: mountid 529, transid 2101783, desc 887, len 4, commit 892, next trans offset 875 Replaying journal: |=== - 6.3% 91 trans Trans replayed: mountid 529, transid 2101784, desc 893, len 4, commit 898, next trans offset 881 Replaying journal: |=== \ 6.4% 92 trans Trans replayed: mountid 529, transid 2101785, desc 899, len 4, commit 904, next trans offset 887 Trans replayed: mountid 529, transid 2101786, desc 905, len 4, commit 910, next trans offset 893 Replaying journal: |=== | 6.5% 94 trans Trans replayed: mountid 529, transid 2101787, desc 911, len 4, commit 916, next trans offset 899 Trans replayed: mountid 529, transid 2101788, desc 917, len 4, commit 922, next trans offset 905 Trans replayed: mountid 529, transid 2101789, desc 923, len 4, commit 928, next trans offset 911 Replaying journal: |=== / 6.7% 97 trans Trans replayed: mountid 529, transid 2101790, desc 929, len 4, commit 934, next trans offset 917 Replaying journal: |=== - 6.8% 98 trans Trans replayed: mountid 529, transid 2101791, desc 935, len 4, commit 940, next trans offset 923 Trans replayed: mountid 529, transid 2101792, desc 941, len 4, commit 946, next trans offset 929 Replaying journal: |=== \ 6.9% 100 trans Trans replayed: mountid 529, transid 2101793, desc 947, len 4, commit 952, next trans offset 935 Trans replayed: mountid 529, transid 2101794, desc 953, len 4, commit 958, next trans offset 941 Replaying journal: |=== | 7.1% 102 trans Trans replayed: mountid 529, transid 2101795, desc 959, len 4, commit 964, next trans offset 947 Trans replayed: mountid 529, transid 2101796, desc 965, len 4, commit 970, next trans offset 953 Replaying journal: |=== / 7.2% 104 trans Trans replayed: mountid 529, transid 2101797, desc 971, len 4, commit 976, next trans offset 959 Trans replayed: mountid 529, transid 2101798, desc 977, len 4, commit 982, next trans offset 965 Trans replayed: mountid 529, transid 2101799, desc 983, len 4, commit 988, next trans offset 971 Replaying journal: |=== - 7.4% 107 trans Trans replayed: mountid 529, transid 2101800, desc 989, len 4, commit 994, next trans offset 977 Replaying journal: |=== \ 7.5% 108 trans Trans replayed: mountid 529, transid 2101801, desc 995, len 4, commit 1000, next trans offset 983 Trans replayed: mountid 529, transid 2101802, desc 1001, len 4, commit 1006, next trans offset 989 Replaying journal: |=== | 7.6% 110 trans Trans replayed: mountid 529, transid 2101803, desc 1007, len 4, commit 1012, next trans offset 995 Replaying journal: |=== / 7.7% 111 trans Trans replayed: mountid 529, transid 2101804, desc 1013, len 4, commit 1018, next trans offset 1001 Trans replayed: mountid 529, transid 2101805, desc 1019, len 4, commit 1024, next trans offset 1007 Replaying journal: |=== - 7.8% 113 trans Trans replayed: mountid 529, transid 2101806, desc 1025, len 4, commit 1030, next trans offset 1013 Trans replayed: mountid 529, transid 2101807, desc 1031, len 4, commit 1036, next trans offset 1019 Replaying journal: |=== \ 8.0% 115 trans Trans replayed: mountid 529, transid 2101808, desc 1037, len 4, commit 1042, next trans offset 1025 Trans replayed: mountid 529, transid 2101809, desc 1043, len 4, commit 1048, next trans offset 1031 Replaying journal: |=== | 8.1% 117 trans Trans replayed: mountid 529, transid 2101810, desc 1049, len 4, commit 1054, next trans offset 1037 Replaying journal: |=== / 8.2% 118 trans Trans replayed: mountid 529, transid 2101811, desc 1055, len 4, commit 1060, next trans offset 1043 Trans replayed: mountid 529, transid 2101812, desc 1061, len 4, commit 1066, next trans offset 1049 Replaying journal: |=== - 8.3% 120 trans Trans replayed: mountid 529, transid 2101813, desc 1067, len 4, commit 1072, next trans offset 1055 Replaying journal: |=== \ 8.4% 121 trans Trans replayed: mountid 529, transid 2101814, desc 1073, len 4, commit 1078, next trans offset 1061 Trans replayed: mountid 529, transid 2101815, desc 1079, len 4, commit 1084, next trans offset 1067 Replaying journal: |=== | 8.5% 123 trans Trans replayed: mountid 529, transid 2101816, desc 1085, len 4, commit 1090, next trans offset 1073 Trans replayed: mountid 529, transid 2101817, desc 1091, len 4, commit 1096, next trans offset 1079 Trans replayed: mountid 529, transid 2101818, desc 1097, len 4, commit 1102, next trans offset 1085 Replaying journal: |=== / 8.7% 126 trans Trans replayed: mountid 529, transid 2101819, desc 1103, len 4, commit 1108, next trans offset 1091 Replaying journal: |==== - 8.8% 127 trans Trans replayed: mountid 529, transid 2101820, desc 1109, len 4, commit 1114, next trans offset 1097 Trans replayed: mountid 529, transid 2101821, desc 1115, len 4, commit 1120, next trans offset 1103 Trans replayed: mountid 529, transid 2101822, desc 1121, len 4, commit 1126, next trans offset 1109 Replaying journal: |==== \ 9.0% 130 trans Trans replayed: mountid 529, transid 2101823, desc 1127, len 4, commit 1132, next trans offset 1115 Replaying journal: |==== | 9.1% 131 trans Trans replayed: mountid 529, transid 2101824, desc 1133, len 5, commit 1139, next trans offset 1122 Trans replayed: mountid 529, transid 2101825, desc 1140, len 4, commit 1145, next trans offset 1128 Replaying journal: |==== / 9.2% 133 trans Trans replayed: mountid 529, transid 2101826, desc 1146, len 4, commit 1151, next trans offset 1134 Replaying journal: |==== - 9.3% 134 trans Trans replayed: mountid 529, transid 2101827, desc 1152, len 4, commit 1157, next trans offset 1140 Trans replayed: mountid 529, transid 2101828, desc 1158, len 4, commit 1163, next trans offset 1146 Replaying journal: |==== \ 9.4% 136 trans Trans replayed: mountid 529, transid 2101829, desc 1164, len 4, commit 1169, next trans offset 1152 Trans replayed: mountid 529, transid 2101830, desc 1170, len 4, commit 1175, next trans offset 1158 Trans replayed: mountid 529, transid 2101831, desc 1176, len 4, commit 1181, next trans offset 1164 Replaying journal: |==== | 9.6% 139 trans Trans replayed: mountid 529, transid 2101832, desc 1182, len 4, commit 1187, next trans offset 1170 Replaying journal: |==== / 9.7% 140 trans Trans replayed: mountid 529, transid 2101833, desc 1188, len 4, commit 1193, next trans offset 1176 Trans replayed: mountid 529, transid 2101834, desc 1194, len 4, commit 1199, next trans offset 1182 Trans replayed: mountid 529, transid 2101835, desc 1200, len 4, commit 1205, next trans offset 1188 Replaying journal: |==== - 9.9% 143 trans Trans replayed: mountid 529, transid 2101836, desc 1206, len 4, commit 1211, next trans offset 1194 Trans replayed: mountid 529, transid 2101837, desc 1212, len 4, commit 1217, next trans offset 1200 Trans replayed: mountid 529, transid 2101838, desc 1218, len 4, commit 1223, next trans offset 1206 Replaying journal: |==== \ 10.1% 146 trans Trans replayed: mountid 529, transid 2101839, desc 1224, len 4, commit 1229, next trans offset 1212 Replaying journal: |==== | 10.2% 147 trans Trans replayed: mountid 529, transid 2101840, desc 1230, len 4, commit 1235, next trans offset 1218 Trans replayed: mountid 529, transid 2101841, desc 1236, len 4, commit 1241, next trans offset 1224 Replaying journal: |==== / 10.3% 149 trans Trans replayed: mountid 529, transid 2101842, desc 1242, len 4, commit 1247, next trans offset 1230 Trans replayed: mountid 529, transid 2101843, desc 1248, len 4, commit 1253, next trans offset 1236 Trans replayed: mountid 529, transid 2101844, desc 1254, len 4, commit 1259, next trans offset 1242 Replaying journal: |==== - 10.5% 152 trans Trans replayed: mountid 529, transid 2101845, desc 1260, len 4, commit 1265, next trans offset 1248 Trans replayed: mountid 529, transid 2101846, desc 1266, len 4, commit 1271, next trans offset 1254 Replaying journal: |==== \ 10.7% 154 trans Trans replayed: mountid 529, transid 2101847, desc 1272, len 4, commit 1277, next trans offset 1260 Trans replayed: mountid 529, transid 2101848, desc 1278, len 4, commit 1283, next trans offset 1266 Replaying journal: |==== | 10.8% 156 trans Trans replayed: mountid 529, transid 2101849, desc 1284, len 4, commit 1289, next trans offset 1272 Replaying journal: |==== / 10.9% 157 trans Trans replayed: mountid 529, transid 2101850, desc 1290, len 4, commit 1295, next trans offset 1278 Trans replayed: mountid 529, transid 2101851, desc 1296, len 4, commit 1301, next trans offset 1284 Replaying journal: |==== - 11.0% 159 trans Trans replayed: mountid 529, transid 2101852, desc 1302, len 4, commit 1307, next trans offset 1290 Replaying journal: |==== \ 11.1% 160 trans Trans replayed: mountid 529, transid 2101853, desc 1308, len 4, commit 1313, next trans offset 1296 Trans replayed: mountid 529, transid 2101854, desc 1314, len 4, commit 1319, next trans offset 1302 Replaying journal: |==== | 11.2% 162 trans Trans replayed: mountid 529, transid 2101855, desc 1320, len 4, commit 1325, next trans offset 1308 Replaying journal: |===== / 11.3% 163 trans Trans replayed: mountid 529, transid 2101856, desc 1326, len 4, commit 1331, next trans offset 1314 Trans replayed: mountid 529, transid 2101857, desc 1332, len 4, commit 1337, next trans offset 1320 Replaying journal: |===== - 11.4% 165 trans Trans replayed: mountid 529, transid 2101858, desc 1338, len 4, commit 1343, next trans offset 1326 Trans replayed: mountid 529, transid 2101859, desc 1344, len 4, commit 1349, next trans offset 1332 Trans replayed: mountid 529, transid 2101860, desc 1350, len 4, commit 1355, next trans offset 1338 Replaying journal: |===== \ 11.6% 168 trans Trans replayed: mountid 529, transid 2101861, desc 1356, len 4, commit 1361, next trans offset 1344 Replaying journal: |===== | 11.7% 169 trans Trans replayed: mountid 529, transid 2101862, desc 1362, len 4, commit 1367, next trans offset 1350 Replaying journal: |===== / 11.8% 170 trans Trans replayed: mountid 529, transid 2101863, desc 1368, len 4, commit 1373, next trans offset 1356 Trans replayed: mountid 529, transid 2101864, desc 1374, len 4, commit 1379, next trans offset 1362 Replaying journal: |===== - 11.9% 172 trans Trans replayed: mountid 529, transid 2101865, desc 1380, len 4, commit 1385, next trans offset 1368 Trans replayed: mountid 529, transid 2101866, desc 1386, len 4, commit 1391, next trans offset 1374 Trans replayed: mountid 529, transid 2101867, desc 1392, len 4, commit 1397, next trans offset 1380 Replaying journal: |===== \ 12.1% 175 trans Trans replayed: mountid 529, transid 2101868, desc 1398, len 4, commit 1403, next trans offset 1386 Replaying journal: |===== | 12.2% 176 trans Trans replayed: mountid 529, transid 2101869, desc 1404, len 4, commit 1409, next trans offset 1392 Trans replayed: mountid 529, transid 2101870, desc 1410, len 5, commit 1416, next trans offset 1399 Replaying journal: |===== / 12.3% 178 trans Trans replayed: mountid 529, transid 2101871, desc 1417, len 4, commit 1422, next trans offset 1405 Replaying journal: |===== - 12.4% 179 trans Trans replayed: mountid 529, transid 2101872, desc 1423, len 4, commit 1428, next trans offset 1411 Trans replayed: mountid 529, transid 2101873, desc 1429, len 4, commit 1434, next trans offset 1417 Replaying journal: |===== \ 12.5% 181 trans Trans replayed: mountid 529, transid 2101874, desc 1435, len 4, commit 1440, next trans offset 1423 Trans replayed: mountid 529, transid 2101875, desc 1441, len 4, commit 1446, next trans offset 1429 Trans replayed: mountid 529, transid 2101876, desc 1447, len 4, commit 1452, next trans offset 1435 Trans replayed: mountid 529, transid 2101877, desc 1453, len 4, commit 1458, next trans offset 1441 Replaying journal: |===== | 12.8% 185 trans Trans replayed: mountid 529, transid 2101878, desc 1459, len 4, commit 1464, next trans offset 1447 Trans replayed: mountid 529, transid 2101879, desc 1465, len 4, commit 1470, next trans offset 1453 Trans replayed: mountid 529, transid 2101880, desc 1471, len 4, commit 1476, next trans offset 1459 Replaying journal: |===== / 13.0% 188 trans Trans replayed: mountid 529, transid 2101881, desc 1477, len 4, commit 1482, next trans offset 1465 Replaying journal: |===== - 13.1% 189 trans Trans replayed: mountid 529, transid 2101882, desc 1483, len 4, commit 1488, next trans offset 1471 Trans replayed: mountid 529, transid 2101883, desc 1489, len 4, commit 1494, next trans offset 1477 Replaying journal: |===== \ 13.2% 191 trans Trans replayed: mountid 529, transid 2101884, desc 1495, len 4, commit 1500, next trans offset 1483 Trans replayed: mountid 529, transid 2101885, desc 1501, len 4, commit 1506, next trans offset 1489 Trans replayed: mountid 529, transid 2101886, desc 1507, len 4, commit 1512, next trans offset 1495 Replaying journal: |===== | 13.4% 194 trans Trans replayed: mountid 529, transid 2101887, desc 1513, len 4, commit 1518, next trans offset 1501 Replaying journal: |===== / 13.5% 195 trans Trans replayed: mountid 529, transid 2101888, desc 1519, len 4, commit 1524, next trans offset 1507 Replaying journal: |===== - 13.6% 196 trans Trans replayed: mountid 529, transid 2101889, desc 1525, len 4, commit 1530, next trans offset 1513 Trans replayed: mountid 529, transid 2101890, desc 1531, len 4, commit 1536, next trans offset 1519 Replaying journal: |===== \ 13.7% 198 trans Trans replayed: mountid 529, transid 2101891, desc 1537, len 4, commit 1542, next trans offset 1525 Trans replayed: mountid 529, transid 2101892, desc 1543, len 4, commit 1548, next trans offset 1531 Trans replayed: mountid 529, transid 2101893, desc 1549, len 4, commit 1554, next trans offset 1537 Replaying journal: |====== | 13.9% 201 trans Trans replayed: mountid 529, transid 2101894, desc 1555, len 4, commit 1560, next trans offset 1543 Replaying journal: |====== / 14.0% 202 trans Trans replayed: mountid 529, transid 2101895, desc 1561, len 4, commit 1566, next trans offset 1549 Trans replayed: mountid 529, transid 2101896, desc 1567, len 4, commit 1572, next trans offset 1555 Replaying journal: |====== - 14.1% 204 trans Trans replayed: mountid 529, transid 2101897, desc 1573, len 5, commit 1579, next trans offset 1562 Replaying journal: |====== \ 14.2% 205 trans Trans replayed: mountid 529, transid 2101898, desc 1580, len 5, commit 1586, next trans offset 1569 Trans replayed: mountid 529, transid 2101899, desc 1587, len 5, commit 1593, next trans offset 1576 Replaying journal: |====== | 14.3% 207 trans Trans replayed: mountid 529, transid 2101900, desc 1594, len 5, commit 1600, next trans offset 1583 Trans replayed: mountid 529, transid 2101901, desc 1601, len 5, commit 1607, next trans offset 1590 Replaying journal: |====== / 14.5% 209 trans Trans replayed: mountid 529, transid 2101902, desc 1608, len 5, commit 1614, next trans offset 1597 Trans replayed: mountid 529, transid 2101903, desc 1615, len 5, commit 1621, next trans offset 1604 Replaying journal: |====== - 14.6% 211 trans Trans replayed: mountid 529, transid 2101904, desc 1622, len 5, commit 1628, next trans offset 1611 Trans replayed: mountid 529, transid 2101905, desc 1629, len 5, commit 1635, next trans offset 1618 Trans replayed: mountid 529, transid 2101906, desc 1636, len 5, commit 1642, next trans offset 1625 Replaying journal: |====== \ 14.8% 214 trans Trans replayed: mountid 529, transid 2101907, desc 1643, len 5, commit 1649, next trans offset 1632 Trans replayed: mountid 529, transid 2101908, desc 1650, len 5, commit 1656, next trans offset 1639 Trans replayed: mountid 529, transid 2101909, desc 1657, len 5, commit 1663, next trans offset 1646 Replaying journal: |====== | 15.0% 217 trans Trans replayed: mountid 529, transid 2101910, desc 1664, len 5, commit 1670, next trans offset 1653 Replaying journal: |====== / 15.1% 218 trans Trans replayed: mountid 529, transid 2101911, desc 1671, len 5, commit 1677, next trans offset 1660 Trans replayed: mountid 529, transid 2101912, desc 1678, len 5, commit 1684, next trans offset 1667 Replaying journal: |====== - 15.2% 220 trans Trans replayed: mountid 529, transid 2101913, desc 1685, len 5, commit 1691, next trans offset 1674 Replaying journal: |====== \ 15.3% 221 trans Trans replayed: mountid 529, transid 2101914, desc 1692, len 5, commit 1698, next trans offset 1681 Trans replayed: mountid 529, transid 2101915, desc 1699, len 5, commit 1705, next trans offset 1688 Trans replayed: mountid 529, transid 2101916, desc 1706, len 5, commit 1712, next trans offset 1695 Replaying journal: |====== | 15.5% 224 trans Trans replayed: mountid 529, transid 2101917, desc 1713, len 5, commit 1719, next trans offset 1702 Replaying journal: |====== / 15.6% 225 trans Trans replayed: mountid 529, transid 2101918, desc 1720, len 5, commit 1726, next trans offset 1709 Trans replayed: mountid 529, transid 2101919, desc 1727, len 5, commit 1733, next trans offset 1716 Replaying journal: |====== - 15.7% 227 trans Trans replayed: mountid 529, transid 2101920, desc 1734, len 6, commit 1741, next trans offset 1724 Trans replayed: mountid 529, transid 2101921, desc 1742, len 5, commit 1748, next trans offset 1731 Trans replayed: mountid 529, transid 2101922, desc 1749, len 5, commit 1755, next trans offset 1738 Replaying journal: |====== \ 15.9% 230 trans Trans replayed: mountid 529, transid 2101923, desc 1756, len 5, commit 1762, next trans offset 1745 Trans replayed: mountid 529, transid 2101924, desc 1763, len 5, commit 1769, next trans offset 1752 Trans replayed: mountid 529, transid 2101925, desc 1770, len 5, commit 1776, next trans offset 1759 Replaying journal: |====== | 16.1% 233 trans Trans replayed: mountid 529, transid 2101926, desc 1777, len 5, commit 1783, next trans offset 1766 Replaying journal: |====== / 16.2% 234 trans Trans replayed: mountid 529, transid 2101927, desc 1784, len 5, commit 1790, next trans offset 1773 Trans replayed: mountid 529, transid 2101928, desc 1791, len 5, commit 1797, next trans offset 1780 Trans replayed: mountid 529, transid 2101929, desc 1798, len 5, commit 1804, next trans offset 1787 Replaying journal: |======= - 16.4% 237 trans Trans replayed: mountid 529, transid 2101930, desc 1805, len 5, commit 1811, next trans offset 1794 Replaying journal: |======= \ 16.5% 238 trans Trans replayed: mountid 529, transid 2101931, desc 1812, len 5, commit 1818, next trans offset 1801 Trans replayed: mountid 529, transid 2101932, desc 1819, len 5, commit 1825, next trans offset 1808 Replaying journal: |======= | 16.6% 240 trans Trans replayed: mountid 529, transid 2101933, desc 1826, len 5, commit 1832, next trans offset 1815 Trans replayed: mountid 529, transid 2101934, desc 1833, len 5, commit 1839, next trans offset 1822 Trans replayed: mountid 529, transid 2101935, desc 1840, len 5, commit 1846, next trans offset 1829 Replaying journal: |======= / 16.8% 243 trans Trans replayed: mountid 529, transid 2101936, desc 1847, len 5, commit 1853, next trans offset 1836 Replaying journal: |======= - 16.9% 244 trans Trans replayed: mountid 529, transid 2101937, desc 1854, len 5, commit 1860, next trans offset 1843 Trans replayed: mountid 529, transid 2101938, desc 1861, len 5, commit 1867, next trans offset 1850 Replaying journal: |======= \ 17.0% 246 trans Trans replayed: mountid 529, transid 2101939, desc 1868, len 5, commit 1874, next trans offset 1857 Replaying journal: |======= | 17.1% 247 trans Trans replayed: mountid 529, transid 2101940, desc 1875, len 5, commit 1881, next trans offset 1864 Replaying journal: |======= / 17.2% 248 trans Trans replayed: mountid 529, transid 2101941, desc 1882, len 5, commit 1888, next trans offset 1871 Trans replayed: mountid 529, transid 2101942, desc 1889, len 5, commit 1895, next trans offset 1878 Replaying journal: |======= - 17.3% 250 trans Trans replayed: mountid 529, transid 2101943, desc 1896, len 5, commit 1902, next trans offset 1885 Trans replayed: mountid 529, transid 2101944, desc 1903, len 5, commit 1909, next trans offset 1892 Trans replayed: mountid 529, transid 2101945, desc 1910, len 5, commit 1916, next trans offset 1899 Replaying journal: |======= \ 17.5% 253 trans Trans replayed: mountid 529, transid 2101946, desc 1917, len 5, commit 1923, next trans offset 1906 Replaying journal: |======= | 17.6% 254 trans Trans replayed: mountid 529, transid 2101947, desc 1924, len 5, commit 1930, next trans offset 1913 Trans replayed: mountid 529, transid 2101948, desc 1931, len 5, commit 1937, next trans offset 1920 Replaying journal: |======= / 17.7% 256 trans Trans replayed: mountid 529, transid 2101949, desc 1938, len 5, commit 1944, next trans offset 1927 Replaying journal: |======= - 17.8% 257 trans Trans replayed: mountid 529, transid 2101950, desc 1945, len 5, commit 1951, next trans offset 1934 Trans replayed: mountid 529, transid 2101951, desc 1952, len 5, commit 1958, next trans offset 1941 Replaying journal: |======= \ 17.9% 259 trans Trans replayed: mountid 529, transid 2101952, desc 1959, len 5, commit 1965, next trans offset 1948 Trans replayed: mountid 529, transid 2101953, desc 1966, len 5, commit 1972, next trans offset 1955 Trans replayed: mountid 529, transid 2101954, desc 1973, len 5, commit 1979, next trans offset 1962 Replaying journal: |======= | 18.1% 262 trans Trans replayed: mountid 529, transid 2101955, desc 1980, len 15, commit 1996, next trans offset 1979 Replaying journal: |======= / 18.2% 263 trans Trans replayed: mountid 529, transid 2101956, desc 1997, len 1, commit 1999, next trans offset 1982 Replaying journal: |======= - 18.3% 264 trans Trans replayed: mountid 529, transid 2101957, desc 2000, len 1, commit 2002, next trans offset 1985 Trans replayed: mountid 529, transid 2101958, desc 2003, len 11, commit 2015, next trans offset 1998 Replaying journal: |======= \ 18.4% 266 trans Trans replayed: mountid 529, transid 2101959, desc 2016, len 8, commit 2025, next trans offset 2008 Replaying journal: |======= | 18.5% 267 trans Trans replayed: mountid 529, transid 2101960, desc 2026, len 8, commit 2035, next trans offset 2018 Trans replayed: mountid 529, transid 2101961, desc 2036, len 1, commit 2038, next trans offset 2021 Replaying journal: |======= / 18.6% 269 trans Trans replayed: mountid 529, transid 2101962, desc 2039, len 8, commit 2048, next trans offset 2031 Replaying journal: |======= - 18.7% 270 trans Trans replayed: mountid 529, transid 2101963, desc 2049, len 1, commit 2051, next trans offset 2034 Trans replayed: mountid 529, transid 2101964, desc 2052, len 1, commit 2054, next trans offset 2037 Replaying journal: |======== \ 18.8% 272 trans Trans replayed: mountid 529, transid 2101965, desc 2055, len 1, commit 2057, next trans offset 2040 Replaying journal: |======== | 18.9% 273 trans Trans replayed: mountid 529, transid 2101966, desc 2058, len 1, commit 2060, next trans offset 2043 Trans replayed: mountid 529, transid 2101967, desc 2061, len 1, commit 2063, next trans offset 2046 Trans replayed: mountid 529, transid 2101968, desc 2064, len 1, commit 2066, next trans offset 2049 Replaying journal: |======== / 19.1% 276 trans Trans replayed: mountid 529, transid 2101969, desc 2067, len 1, commit 2069, next trans offset 2052 Trans replayed: mountid 529, transid 2101970, desc 2070, len 1, commit 2072, next trans offset 2055 Trans replayed: mountid 529, transid 2101971, desc 2073, len 1, commit 2075, next trans offset 2058 Replaying journal: |======== - 19.3% 279 trans Trans replayed: mountid 529, transid 2101972, desc 2076, len 1, commit 2078, next trans offset 2061 Replaying journal: |======== \ 19.4% 280 trans Trans replayed: mountid 529, transid 2101973, desc 2079, len 1, commit 2081, next trans offset 2064 Trans replayed: mountid 529, transid 2101974, desc 2082, len 1, commit 2084, next trans offset 2067 Trans replayed: mountid 529, transid 2101975, desc 2085, len 2, commit 2088, next trans offset 2071 Replaying journal: |======== | 19.6% 283 trans Trans replayed: mountid 529, transid 2101976, desc 2089, len 1, commit 2091, next trans offset 2074 Trans replayed: mountid 529, transid 2101977, desc 2092, len 2, commit 2095, next trans offset 2078 Replaying journal: |======== / 19.7% 285 trans Trans replayed: mountid 529, transid 2101978, desc 2096, len 1, commit 2098, next trans offset 2081 Trans replayed: mountid 529, transid 2101979, desc 2099, len 2, commit 2102, next trans offset 2085 Trans replayed: mountid 529, transid 2101980, desc 2103, len 2, commit 2106, next trans offset 2089 Replaying journal: |======== - 19.9% 288 trans Trans replayed: mountid 529, transid 2101981, desc 2107, len 2, commit 2110, next trans offset 2093 Replaying journal: |======== \ 20.0% 289 trans Trans replayed: mountid 529, transid 2101982, desc 2111, len 2, commit 2114, next trans offset 2097 Trans replayed: mountid 529, transid 2101983, desc 2115, len 1, commit 2117, next trans offset 2100 Trans replayed: mountid 529, transid 2101984, desc 2118, len 1, commit 2120, next trans offset 2103 Replaying journal: |======== | 20.2% 292 trans Trans replayed: mountid 529, transid 2101985, desc 2121, len 2, commit 2124, next trans offset 2107 Replaying journal: |======== / 20.3% 293 trans Trans replayed: mountid 529, transid 2101986, desc 2125, len 2, commit 2128, next trans offset 2111 Trans replayed: mountid 529, transid 2101987, desc 2129, len 1, commit 2131, next trans offset 2114 Trans replayed: mountid 529, transid 2101988, desc 2132, len 2, commit 2135, next trans offset 2118 Replaying journal: |======== - 20.5% 296 trans Trans replayed: mountid 529, transid 2101989, desc 2136, len 2, commit 2139, next trans offset 2122 Trans replayed: mountid 529, transid 2101990, desc 2140, len 1, commit 2142, next trans offset 2125 Replaying journal: |======== \ 20.6% 298 trans Trans replayed: mountid 529, transid 2101991, desc 2143, len 8, commit 2152, next trans offset 2135 Replaying journal: |======== | 20.7% 299 trans Trans replayed: mountid 529, transid 2101992, desc 2153, len 1, commit 2155, next trans offset 2138 Trans replayed: mountid 529, transid 2101993, desc 2156, len 1, commit 2158, next trans offset 2141 Replaying journal: |======== / 20.8% 301 trans Trans replayed: mountid 529, transid 2101994, desc 2159, len 1, commit 2161, next trans offset 2144 Trans replayed: mountid 529, transid 2101995, desc 2162, len 2, commit 2165, next trans offset 2148 Replaying journal: |======== - 21.0% 303 trans Trans replayed: mountid 529, transid 2101996, desc 2166, len 2, commit 2169, next trans offset 2152 Trans replayed: mountid 529, transid 2101997, desc 2170, len 2, commit 2173, next trans offset 2156 Replaying journal: |======== \ 21.1% 305 trans Trans replayed: mountid 529, transid 2101998, desc 2174, len 1, commit 2176, next trans offset 2159 Trans replayed: mountid 529, transid 2101999, desc 2177, len 1, commit 2179, next trans offset 2162 Trans replayed: mountid 529, transid 2102000, desc 2180, len 2, commit 2183, next trans offset 2166 Replaying journal: |========= | 21.3% 308 trans Trans replayed: mountid 529, transid 2102001, desc 2184, len 2, commit 2187, next trans offset 2170 Replaying journal: |========= / 21.4% 309 trans Trans replayed: mountid 529, transid 2102002, desc 2188, len 2, commit 2191, next trans offset 2174 Trans replayed: mountid 529, transid 2102003, desc 2192, len 2, commit 2195, next trans offset 2178 Replaying journal: |========= - 21.5% 311 trans Trans replayed: mountid 529, transid 2102004, desc 2196, len 2, commit 2199, next trans offset 2182 Trans replayed: mountid 529, transid 2102005, desc 2200, len 1, commit 2202, next trans offset 2185 Replaying journal: Done. Reiserfs journal '/dev/md7p1' in blocks [18..8211]: 313 transactions replayedI also ran it on disk 1Phase 1 - find and verify superblock... Phase 2 - using internal log - zero log... - scan filesystem freespace and inode maps... - found root inode chunk Phase 3 - for each AG... - scan (but don't clear) agi unlinked lists... - process known inodes and perform inode discovery... - agno = 0 - agno = 1 - agno = 2 - agno = 3 - agno = 4 - agno = 5 - process newly discovered inodes... Phase 4 - check for duplicate blocks... - setting up duplicate extent list... - check for inodes claiming duplicate blocks... - agno = 0 - agno = 1 - agno = 2 - agno = 3 - agno = 4 - agno = 5 No modify flag set, skipping phase 5 Phase 6 - check inode connectivity... - traversing filesystem ... - traversal finished ... - moving disconnected inodes to lost+found ... Phase 7 - verify link counts... No modify flag set, skipping filesystem flush and exiting.After that I was unable to start the array again, no error just nothing after pressing start. Rebooted unraid and it works again. Edited July 7, 20251 yr by Shadey1
July 7, 20251 yr Author And now this after the restart. I think it's because the drive is full, but I can't see an easy way to confirm it moved all the files other than scrolling 2 screens side by side right nowI've worked out a way to do it. Top level file structure and 'calcultate'Movies is 3 files different, no big deal, Disk 1 (the newer is the largest)The only area of significant difference is 'appdata' which appears to be about 0.9gig larger on the old drive.I suspect this is down to it still updating as I'm doing stuff, but to the old drive! That's also insanely large for a small database of watched episodes etc!I tried to delete some things from both drives via the unraid GUI, but the stuff on disk 7 just stays, no error, nothing. It does remove on disk 1 though!I'm thinking at this stage it's wipe disk 7, and maybe repoint the docker images to disk 1? Edited July 7, 20251 yr by Shadey1
July 7, 20251 yr Community Expert Fsck on disk7 appears to not have completed, run it on the CLI to see if there's anything more.
July 7, 20251 yr Author Jul 7 16:25:01 Wintermute ool www[8314]: /usr/local/emhttp/plugins/dynamix/scripts/reiserfs_check 'start' '/dev/md7p1' 'WDC_WD40EZRZ-00GXCB0_WD-WCC7K7PFVDZK' ''Jul 7 16:25:16 Wintermute kernel: kvm_amd: SVM disabled (by BIOS) in MSR_VM_CR on CPU 1Jul 7 16:25:34 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0Jul 7 16:25:34 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Transmitter ID)Jul 7 16:25:34 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00001001/00002000Jul 7 16:25:34 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First)Jul 7 16:25:34 Wintermute kernel: xhci_hcd 0000:01:00.0: [12] TimeoutJul 7 16:25:34 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0I've rebooted the server a few times, and it didn't even start the first 2 tries, now this.Jul 7 16:37:29 Wintermute ool www[12116]: /usr/local/emhttp/plugins/dynamix/scripts/reiserfs_check 'start' '/dev/md7p1' 'WDC_WD40EZRZ-00GXCB0_WD-WCC7K7PFVDZK' ''or reiserfsck 3.6.27 Will read-only check consistency of the filesystem on /dev/md7p1 Will put log info to 'stdout' ########### reiserfsck --check started at Mon Jul 7 16:37:29 2025 ########### Replaying journal: Replaying journal: Done. Reiserfs journal '/dev/md7p1' in blocks [18..8211]: 0 transactions replayedOr via CLIAlso worth noting that I checked all the cables in the machine, nothing loose. Edited July 7, 20251 yr by Shadey1
July 7, 20251 yr Community Expert Use /dev/md7p154 minutes ago, Shadey1 said:Jul 7 16:25:34 Wintermute kernel: xhci_hcd 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Transmitter ID)Jul 7 16:25:34 Wintermute kernel: xhci_hcd 0000:01:00.0: device [1022:43bb] error status/mask=00001001/00002000Jul 7 16:25:34 Wintermute kernel: xhci_hcd 0000:01:00.0: [ 0] RxErr (First)Jul 7 16:25:34 Wintermute kernel: xhci_hcd 0000:01:00.0: [12] TimeoutJul 7 16:25:34 Wintermute kernel: pcieport 0000:00:01.2: AER: Corrected error message received from 0000:01:00.0For this, try this first:https://forums.unraid.net/topic/118286-nvme-drives-throwing-errors-filling-logs-instantly-how-to-resolve/?do=findComment&comment=1165009
July 7, 20251 yr Author Jul 7 18:54:46 Wintermute ool www[13295]: /usr/local/emhttp/plugins/dynamix/scripts/reiserfs_check 'start' '/dev/md7p1' 'WDC_WD40EZRZ-00GXCB0_WD-WCC7K7PFVDZK' ''Nothing again, both for CLI and GUI. It seems to start to run then ignore it all. I tried deleting a file off disk 7 and it shows a permissions error. or it deletes and hides it until you reboot.I saw this in the logs last rebootJul 7 19:04:48 Wintermute emhttpd: Starting services...Jul 7 19:04:48 Wintermute emhttpd: shcmd (86): /etc/rc.d/rc.samba reloadJul 7 19:04:49 Wintermute emhttpd: shcmd (89): exportfs -raJul 7 19:04:49 Wintermute emhttpd: shcmd (91): /etc/rc.d/rc.avahidaemon reloadJul 7 19:04:49 Wintermute avahi-daemon[1790]: Got SIGHUP, reloading.Jul 7 19:04:49 Wintermute emhttpd: shcmd (100): /usr/local/sbin/mount_image '/mnt/user/appdata/docker.img' /var/lib/docker 20Jul 7 19:04:49 Wintermute kernel: loop2: detected capacity change from 0 to 41943040Jul 7 19:04:49 Wintermute kernel: BTRFS: device fsid 86f5e929-4a8c-4d3e-88bc-d58221cb0bf3 devid 1 transid 1813064 /dev/loop2 scanned by udevd (6124)Jul 7 19:04:49 Wintermute kernel: BTRFS info (device loop2): first mount of filesystem 86f5e929-4a8c-4d3e-88bc-d58221cb0bf3Jul 7 19:04:49 Wintermute kernel: BTRFS info (device loop2): using crc32c (crc32c-intel) checksum algorithmJul 7 19:04:49 Wintermute kernel: BTRFS info (device loop2): using free space treeJul 7 19:04:49 Wintermute kernel: BTRFS warning (device loop2): devid 1 physical 0 len 4194304 inside the reserved spaceJul 7 19:04:49 Wintermute kernel: BTRFS info (device loop2): bdev /dev/loop2 errs: wr 0, rd 0, flush 0, corrupt 25, gen 0Jul 7 19:04:49 Wintermute kernel: BTRFS info (device loop2): auto enabling async discardJul 7 19:04:49 Wintermute root: Resize device id 1 (/dev/loop2) from 20.00GiB to maxJul 7 19:04:49 Wintermute emhttpd: shcmd (102): /etc/rc.d/rc.docker startJul 7 19:04:49 Wintermute rc.docker: Starting Docker daemon...Jul 7 19:04:50 Wintermute sysDrivers: SysDrivers Build CompleteJul 7 19:04:52 Wintermute kernel: BTRFS warning (device loop2): csum failed root 5 ino 2218 off 118784 csum 0x8941f998 expected csum 0xb7aaad05 mirror 1Jul 7 19:04:52 Wintermute kernel: BTRFS error (device loop2): bdev /dev/loop2 errs: wr 0, rd 0, flush 0, corrupt 26, gen 0Jul 7 19:04:52 Wintermute kernel: BTRFS warning (device loop2): csum failed root 5 ino 2218 off 118784 csum 0x8941f998 expected csum 0xb7aaad05 mirror 1Jul 7 19:04:52 Wintermute kernel: BTRFS error (device loop2): bdev /dev/loop2 errs: wr 0, rd 0, flush 0, corrupt 27, gen 0Jul 7 19:04:52 Wintermute kernel: BTRFS warning (device loop2): csum failed root 5 ino 2218 off 118784 csum 0x8941f998 expected csum 0xb7aaad05 mirror 1Jul 7 19:04:52 Wintermute kernel: BTRFS error (device loop2): bdev /dev/loop2 errs: wr 0, rd 0, flush 0, corrupt 28, gen 0Jul 7 19:05:01 Wintermute kernel: BTRFS warning (device loop2): csum failed root 5 ino 2218 off 118784 csum 0x8941f998 expected csum 0xb7aaad05 mirror 1Jul 7 19:05:01 Wintermute kernel: BTRFS error (device loop2): bdev /dev/loop2 errs: wr 0, rd 0, flush 0, corrupt 29, gen 0Jul 7 19:05:01 Wintermute kernel: BTRFS warning (device loop2): csum failed root 5 ino 2218 off 118784 csum 0x8941f998 expected csum 0xb7aaad05 mirror 1Jul 7 19:05:01 Wintermute kernel: BTRFS error (device loop2): bdev /dev/loop2 errs: wr 0, rd 0, flush 0, corrupt 30, gen 0 Edited July 7, 20251 yr by Shadey1
July 8, 20251 yr Community Expert Solution 12 hours ago, Shadey1 said:Jul 7 19:05:01 Wintermute kernel: BTRFS error (device loop2): bdev /dev/loop2 errs: wr 0, rd 0, flush 0, corrupt 30, gen 0Docker image is corrupt, delete and recreate:https://docs.unraid.net/unraid-os/manual/docker-management/#re-create-the-docker-image-fileThen:https://docs.unraid.net/unraid-os/manual/docker-management/#re-installing-docker-applicationsAlso see below if you have any custom docker networks:https://docs.unraid.net/unraid-os/manual/docker-management/#docker-custom-networksIt may also be a good idea to run memtest.
July 8, 20251 yr Author Amazing, my docker works now. Thank you!(EDIT: I installed duplicate-file-handler to check the state of the drive and it just hangs, I then checked the docker images and it's putting them on disk 7, so it's filling up and breaks the dockers again. I think I need to move them to another drive in that case)I still have this issue though, and a disk7 full of the stuff I moved to disk1Is it as simple as formatting disk 7 now and it should stop getting confused?Mapped drive:Network location (with the right password) Edited July 8, 20251 yr by Shadey1
July 8, 20251 yr Community Expert 50 minutes ago, Shadey1 said:I still have this issue though, and a disk7 full of the stuff I moved to disk1Double check all the data is really on disk1 and you can then format.
July 8, 20251 yr Author EDIT: Ignore that, I removed each one and remapped them. It's working fine. How very odd.Thanks again for all the help!Yeah it all looked the same, I double checked and moved app data over to disk 1 again.It wouldn't let me delete anything on disk 7 so I formatted it, it took a few minutes and then the array was back up and running with app data having repopulated onto disk 7 by itself.The only issue is that I still cannot access the array from my windows machines still Edited July 8, 20251 yr by Shadey1
July 8, 20251 yr Community Expert If you are using Windows 11 24H2 see here:https://forums.unraid.net/topic/177975-formatted-my-pc-and-installed-fresh-windows-11-now-cant-access-smb-shares/?do=findComment&comment=1478526
July 12, 20251 yr Author On 7/8/2025 at 10:55 AM, JorgeB said:If you are using Windows 11 24H2 see here:https://forums.unraid.net/topic/177975-formatted-my-pc-and-installed-fresh-windows-11-now-cant-access-smb-shares/?do=findComment&comment=1478526Yeah I'd done this weeks ago, seemed to need removing and readding. Weirdly kodi is now double scanning anything new, so I need to work that out, I wonder if it's because the app data moved drive but I'll do some digging
