After a crash where I had to manually restart,waiting for system to mount drives
5.0-Beta-14.
System has been running fine, tried to update a plugin and it locked up. I could telnet in but powerdown script wouldn't run.
Manually powered down and started so I could run a parity check.
Web page loads but all drives say mounting, been like this for 5 mins.
Unmneu says parity check in progress with .01% done but nothing is mounted.
Just got these in the syslog.
May 15 07:11:40 Tower kernel: REISERFS (device md10): replayed 150 transactions in 743 seconds (Minor Issues)
May 15 07:11:40 Tower kernel: REISERFS (device md10): Using r5 hash to sort names (Routine)
May 15 07:11:43 Tower emhttp: shcmd (44): chmod 770 '/mnt/disk10' (Other emhttp)
May 15 07:11:43 Tower emhttp: shcmd (45): chown nobody:users '/mnt/disk10' (Other emhttp)
May 15 07:12:41 Tower kernel: REISERFS (device md8): replayed 162 transactions in 804 seconds (Minor Issues)
May 15 07:12:41 Tower kernel: REISERFS (device md8): Using r5 hash to sort names (Routine)
May 15 07:12:42 Tower emhttp: shcmd (46): chmod 770 '/mnt/disk8' (Other emhttp)
May 15 07:12:42 Tower emhttp: shcmd (47): chown nobody:users '/mnt/disk8' (Other emhttp)
syslog-2012-05-15.txt
It finally mounted the drives. Never took this long before. Hopefully the sync goes ok
I've seen unRAID take as long as 30 minutes for a drive's reiserfs file-system to replay its journal after an un-expected shutdown/power-loss.
This is normal.  Be patient.  Once mounted, the drives should be fine.  (usually, it takes between 5 and 15 minutes if I hard crash my system)
Joe L.
Ok. Thanks for the info.
I was planning on doing a sync today anyways, upgrading my motherboard this weekend.
