iGPU passthrough → no display output, vGPU leads to UEFI Shell – need help
Hello everyone,
I’m trying to set up a Windows 11 VM on Unraid with iGPU passthrough (Ryzen 8600G) but having two major issues:
🔹 Problem 1: iGPU passthrough (real GPU)
  • I’ve bound both the iGPU (graphics + audio) in Tools → System Devices → “Bind to VFIO at Boot”Screenshot 2025-07-16 212817.png
  • I configured the VM to use the iGPU as GPU
Result: The VM starts, Unraid GUI disappears or stays, but no video output on my monitor via HDMI/DP. Black screen.
🔹 Problem 2: vGPU mode (no passthrough)
  • For testing I switched the VM to use vGPU (software emulated)
Result: VM launches, but instead of installing or booting Windows, I’m dumped into the UEFI Interactive Shell. No boot disk is found. Even with virtIO disk set up, the VM won’t auto-boot from disk.
✅ What I’ve already done
  • BIOS: SVM + IOMMU enabled
  • iGPU → Bind to VFIO at Boot
  • tried booting with vGPU
❓ What I need help with
  1. iGPU passthrough mode – how to get real monitor output instead of a black screen
  2. vGPU mode – how to make VM boot properly from virtIO disk (still ending in UEFI shell)
📌 Configuration details
  • Unraid version: 7.1.4
  • Motherboard: ASRock B650M Riptide (BIOS 3.30)
  • CPU/APU/iGPU: Ryzen 8600G
  • VM Machine: i440-9.2
  • BIOS for VM: OVMF / OVMF TPM (tried both
  • VirtIO disk bus/type: VirtIO
👋 Ask
  • What am I missing to get real monitor output in iGPU passthrough? Do I need a special VBIOS or ROM?
  • How can I set a persistent boot entry so the VM doesn’t drop into the UEFI shell in vGPU mode?
  • Are there any known quirks with Riptide B650M + ASRock BIOS 3.30 + Ryzen 8600G?
Edited by WimWagner
  • 2 months later...
Have you tried running the VM without the sound card?
