August 4, 20251 yr I have 2 pools, no array. A cache zfs pool (2nvme) that I'm getting errors on in fix common problems. I'd also like to get this appdata share to use exclusive access. All files appear to be on cache but it still says no.Can someone maybe see why i'm getting the errors below? I've tried to search but the solutions don't seem applicable from what i saw. thanks to anyone who can assistps, i'm also on the new beta, not sure if that is causing any issues or notmars-diagnostics-20250804-0828.zip Edited August 4, 20251 yr by erdius added screenshot
August 4, 20251 yr Community Expert I believe FCP does not yet support having a share using multiple pools, recommend reporting that in the existing plugin support thread:
August 4, 20251 yr Author o48 minutes ago, JorgeB said:I believe FCP does not yet support having a share using multiple pools, recommend reporting that in the existing plugin support thread:ok thanks, so no reason to believe the doom messages?Any reason why my appdata is not showing as exclusive?
August 4, 20251 yr Author To add to this, docker is acting weird, i tried to add a docker app and get this error messagemkdir /mnt/user/appdata/watchstate: no space left on device.there is obviously space on that device
August 4, 20251 yr Community Expert 1 hour ago, erdius said:Any reason why my appdata is not showing as exclusive?That won't be related to FCP, did you enable NFS export for that share before? If you did you need to restart the array.
August 4, 20251 yr Author No NFS. I took the cowards way out and formatted the cache and restored a backup, all is working as expected now.
