Sabnzbd post-processing script help....
I had my Windows machine setup just fine with post-processing using sabtosickbeard.exe script. Now that I'm trying to install on unraid, which is Linux based, what script do I use. If I set my script folder up and copy that sabtosickbeard.py file into the scripts folder then goto categories it doesn't show up in the dropdown. Any direction on setting post-processing up with use of Sickbeard?
Make sure it has the X bit set.
So:
chmod +x sabtosickbeard.py
Yep, that did it.
Thanks.
Now, I have another problem. I installed RC3 and getting LOTS of write errors. Sabnzbd tells me all the time it can't create folders when it wants to.
