Wireguard low speed.
Hello everybody.
I have this problem and I am going crazy.
2 Unraid servers linked using wireguard. One of them is the server. Connection is usually okay although sometimes (once a week?? the connection is lost and I have to manually reset it. But the real problem are the low speeds.
Both servers links to internet using 1 Gbps and the speeds I get copying files are about 3Mbps. So far I have tried:
Connect using laptops (not server to server, just client to server): same crappy speeds.
Change protocol shares from SMB to NFS or FTP. Same crappy speeds.
Iperf3 test between servers: unrealiable: sometimes 800mbps sometimes 150mbps
Copying data using virtual machines, dockers or unraid explorer itself with no improvements.
Tweak a litle MTU values: from 1320 to 1500. Same results.
I am quite desperate becasue moving big files takes forever.
Configuration seems to be ok and the connections are fine, it is just the speed that is very low.
Servers are unraid 7.1.x
Any ideas?.
PS: as the server to server connection gets lost from time to time. is there an easy way to cron it? like reset it every night?.
Thank you very much.
