October 30, 2025Oct 30 Noticed this morning that i have an ethernet port that is going crazy and disconnecting over and over again. Ive updated dockers and plugins and made sure fix common problems is happy and there isnt any errors in there. What can cause this? Is that port just dying? i would find that to be odd as this motherboard is only a year old and was bought brand new. At the moment everything is still working as the motherboard has dual 10G ports on it but im not sure what to troubleshoot. i also have no idea how long this has been going on as i restarted my system today which cleared the log file. Thanks in advance for any help on this.
October 30, 2025Oct 30 Community Expert Disable docker and see if those errors continue. If they stop, it points to one of your containers having a problem.
October 30, 2025Oct 30 Author 4 minutes ago, Veah said:Disable docker and see if those errors continue. If they stop, it points to one of your containers having a problem.ok so i disabled docker and it did go away. how do i tell what docker is causing the problem without going 1 by 1?
October 30, 2025Oct 30 Community Expert I do not believe there's a way. Try disabling half then half again sort of method is best I can suggest. Edited October 30, 2025Oct 30 by Veah
October 30, 2025Oct 30 Author Well thats really weird. It seems the docker thats causing the problem is Clourflared. its currently disabled and everything seems to be working fine so im not even sure why i have it as ive definitely slept and drank since then. Guess ill leave it off and see what happens
October 30, 2025Oct 30 Community Expert 1 hour ago, Dragoonka said:It seems the docker thats causing the problem is Clourflared.Post about this problem in the support thread for this Docker container. Be sure to include the Diagnostics file and any log files from the container.
