GPU Passthrough for GTX 560 Ti → Started with Code 43, now stuck at Code 12 — need help on Unraid VM
Hello everyone,
I’m running into major issues trying to passthrough my GPU to a Windows 11 VM, and I’d really appreciate assistance from the community. I’ll walk through everything I’ve tried so far (error 43 → error 12) and include my VM XML excerpt so you can spot what I might be missing.
My Setup:
  • Host OS: Unraid (7.1.4)
  • CPU: AMD Ryzen 5 8600G
  • GPU to passthrough: NVIDIA GTX 560 Ti
  • VM Guest: Windows 11
  • VM Config: machine type pc-q35-8.2/i440fx-5.1 (tried both), firmware currently Legacy (SeaBIOS)
  • IOMMU/AMD-Vi enabled in BIOS, have toggled “Above 4G Decoding” ON and OFF
  • I have isolated the GPU, bound it to vfio
Issue Cronology
  1. Initial problem → Error 43
    • After installing the NVIDIA driver in Windows VM, Device Manager shows Code 43: “This device cannot start. (Code 43)”.
    • This is the classic issue where the NVIDIA driver detects the VM environment and refuses to load
    • I tried hiding the VM hypervisor, setting vendor_id, hiding KVM, etc.
  2. Troubleshooting leads to Error 12
    • After making changes (including using a dumped vBIOS ROM and adjusting XML), the error 43 went away for a moment, but I then received Error 12: “This device cannot find enough free resources that it can use.” Most likely because I switched to q35.
    • Error 12 typically points to insufficient MMIO/PCIe resource allocation for the passthrough device.
Here is my VM configuration (xml)
<domain type='kvm' xmlns:qemu='http://libvirt.org/schemas/domain/qemu/1.0'>
  <name>Windows 11</name>
  <uuid>14b70a5c-2796-21a3-82f1-eee9aa2d0454</uuid>
  <metadata>
    <vmtemplate xmlns="unraid" name="Windows 11" iconold="windows11.png" icon="windows11.png" os="windowstpm" webui="" storage="default"/>
  </metadata>
  <memory unit='KiB'>16777216</memory>
  <currentMemory unit='KiB'>16777216</currentMemory>
  <memoryBacking>
    <nosharepages/>
  </memoryBacking>
  <vcpu placement='static'>6</vcpu>
  <cputune>
    <vcpupin vcpu='0' cpuset='0'/>
    <vcpupin vcpu='1' cpuset='6'/>
    <vcpupin vcpu='2' cpuset='1'/>
    <vcpupin vcpu='3' cpuset='7'/>
    <vcpupin vcpu='4' cpuset='2'/>
    <vcpupin vcpu='5' cpuset='8'/>
  </cputune>
  <os>
    <type arch='x86_64' machine='pc-q35-8.2'>hvm</type>
  </os>
  <features>
    <acpi/>
    <apic/>
    <hyperv mode='custom'>
      <relaxed state='on'/>
      <vapic state='on'/>
      <vpindex state='on'/>
      <synic state='on'/>
      <stimer state='on'/>
    </hyperv>
    <kvm>
      <hidden state='on'/>
    </kvm>
    <ioapic driver='kvm'/>
  </features>
    <topology sockets='1' dies='1' clusters='1' cores='3' threads='2'/>
    <cache mode='passthrough'/>
    <feature policy='require' name='topoext'/>
  </cpu>
  <clock offset='localtime'>
  </clock>
  <on_crash>restart</on_crash>
  <devices>
      <source file='/mnt/user/isos/Win11_24H2_German_x64.iso'/>
      <target dev='hda' bus='sata'/>
      <readonly/>
      <boot order='2'/>
    </disk>
      <source file='/mnt/user/isos/virtio-win-0.1.285-1.iso'/>
      <target dev='hdb' bus='sata'/>
      <readonly/>
    </disk>
      <driver name='qemu' type='raw' cache='writeback' discard='unmap'/>
      <source file='/mnt/user/domains/Windows 11/vdisk1.img'/>
      <target dev='hdc' bus='sata'/>
      <serial>vdisk1</serial>
      <boot order='1'/>
      <address type='drive' controller='0' bus='0' target='0' unit='2'/>
    </disk>
    </controller>
      <master startport='0'/>
    </controller>
      <master startport='2'/>
    </controller>
      <master startport='4'/>
    </controller>
    <controller type='pci' index='0' model='pcie-root'/>
    <controller type='pci' index='1' model='pcie-root-port'>
      <model name='pcie-root-port'/>
      <target chassis='1' port='0x8'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x0' multifunction='on'/>
    </controller>
    <controller type='pci' index='2' model='pcie-root-port'>
      <target chassis='2' port='0x9'/>
    </controller>
    <controller type='pci' index='3' model='pcie-root-port'>
      <target chassis='3' port='0xa'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x2'/>
    </controller>
    <controller type='pci' index='4' model='pcie-root-port'>
      <target chassis='4' port='0xb'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x3'/>
    </controller>
    <controller type='pci' index='5' model='pcie-root-port'>
      <target chassis='5' port='0xc'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x4'/>
    </controller>
    <controller type='pci' index='6' model='pcie-root-port'>
      <target chassis='6' port='0xd'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x5'/>
    </controller>
    <controller type='pci' index='7' model='pcie-to-pci-bridge'>
      <model name='pcie-pci-bridge'/>
      <address type='pci' domain='0x0000' bus='0x01' slot='0x00' function='0x0'/>
    </controller>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x00' function='0x0'/>
    </controller>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x1f' function='0x2'/>
    </controller>
    <interface type='bridge'>
      <mac address='52:54:00:74:ea:ce'/>
      <source bridge='br0'/>
      <model type='rtl8139'/>
      <address type='pci' domain='0x0000' bus='0x07' slot='0x01' function='0x0'/>
    </interface>
    <serial type='pty'>
        <model name='isa-serial'/>
      </target>
    </serial>
    <console type='pty'>
    </console>
    <channel type='unix'>
    </channel>
    </input>
    <graphics type='vnc' port='-1' autoport='yes' websocket='-1' listen='0.0.0.0' sharePolicy='ignore'>
    </graphics>
    <audio id='1' type='none'/>
    <video>
      <model type='qxl' ram='65536' vram='16384' vgamem='16384' heads='1' primary='yes'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x1e' function='0x0'/>
    </video>
      <driver name='vfio'/>
      <source>
        <address domain='0x0000' bus='0x01' slot='0x00' function='0x0'/>
      </source>
      <rom file='/mnt/disk1/isos/560tibios-unfixed.rom'/>
      <address type='pci' domain='0x0000' bus='0x03' slot='0x00' function='0x0'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x01' slot='0x00' function='0x1'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x04' slot='0x00' function='0x0'/>
    </hostdev>
    <watchdog model='itco' action='reset'/>
    <memballoon model='none'/>
  </devices>
  <qemu:commandline>
    <qemu:arg value='-global'/>
    <qemu:arg value='q35-pcihost.pci-hole64-size=2048G'/>
  </qemu:commandline>
What I´ve tried so far:
  • Verified IOMMU grouping and that the GPU is fully bound to vfio.
  • Tested both “Above 4G Decoding” ON and OFF in the BIOS.
  • Ensured the GPU is not the host’s primary display device.
  • Tried different machine types (pc-i440fx vs pc-q35) and different BIOS types (SeaBIOS vs OVMF TMP).
  • Used a dumped BIOS ROM for the GPU.
  • Hidden the KVM hypervisor to avoid code 43 detection.
  • Added QEMU args for pci-hole64-size (for large MMIO space)
Edited by WimWagner
