Writing speed is slow since using xfs-encryption
Hey there,
I just reinstalled my Unraid System to use xfs encryption.
I realized that since I did that, my writing speed is basically halfed, as when I write onto the pool, it will read and write onto the disk and parity disk at the same time, instead of just writing to the disk/parity.
Is that an expexted behaviour with xfs encryption?
I would love to use encryption, but not at the cost of half the writing speed.
Thanks in advance
Mia
Edited by bl00dy-c0d3
That's the expected behavior with normal writing mode; turbo write should be faster, at the expense of all drives spinning up for writes.
Ohh okay
Thank you!
Probably had that enabled before I reinstalled the system.
