(7.1.4) DNS issue suspected - network settings help
Hey Friends!
I added a 10gbit PCIe card to my nas, and set it up as br0/eth0. Bridging is enabled. Bonding is disabled.
I’m noticing the unraid plugins can’t check for updates though. Fix common problems indicates it can’t connect to github and the DNS settings need updating. In network settings, I see this error in red at the bottom left of screen: Interface - Ethernet Port 1 is down. Check cable!
I normally leave the unraid in auto dhcp, and then assign static IP at the router.
Diagnostic attached. Any guidance is appreciated!
servetux-diagnostics-20251116-1236.zip
Edited by TeddyTux
clarifying
Solved by TeddyTux
NIC is getting the address from DHCP, so it's likely using the router as the DNS server. If that is not working, you can try using 208.67.222.222 and 208.67.220.220 instead of using your router.
I figured it out! No issues on the unraid end. I needed to setup some firewall rules on the router. Thanks for your help! Apologies for the wild goose chase.
