February 24Feb 24 Good morning everyone, for some time now, the error message in the subject has been appearing on my Unraid server. I have already tried replacing the USB stick and positioning it on a different USB port on the server, but it did not yield positive results. I don't know what the specific issue is, so I am attaching the relevant logs from my server to this thread. Thank you all for your support. tower-diagnostics-20260224-1458.zip
February 24Feb 24 Community Expert Your logs are filling up with a lot of thisFeb 24 04:41:34 Tower kernel: br-2d799c063852: port 3(veth0f962ca) entered disabled state Feb 24 04:41:34 Tower kernel: veth0f962ca (unregistering): left allmulticast mode Feb 24 04:41:34 Tower kernel: veth0f962ca (unregistering): left promiscuous mode Feb 24 04:41:34 Tower kernel: br-2d799c063852: port 3(veth0f962ca) entered disabled state Feb 24 04:41:34 Tower kernel: br-2d799c063852: port 3(veth2063f81) entered blocking state Feb 24 04:41:34 Tower kernel: br-2d799c063852: port 3(veth2063f81) entered disabled state Feb 24 04:41:34 Tower kernel: veth2063f81: entered allmulticast mode Feb 24 04:41:34 Tower kernel: veth2063f81: entered promiscuous mode Feb 24 04:41:34 Tower kernel: eth0: renamed from vetha55abe8Can't see anything else because of that. Can you make those stop?Reboot to clear the logs, then get diagnostics again when you get that error message.
February 24Feb 24 Author Hi trutl,I restarted the server as you instructed and I’m attaching the related logs. tower-diagnostics-20260224-1724.zip
February 24Feb 24 Community Expert 1 hour ago, trurl said:when you get that error message.Did you already get that error message again since rebooting?
February 24Feb 24 Community Expert Solution Feb 24 17:24:58 Tower kernel: br-2d799c063852: port 7(veth229ee34) entered disabled stateFeb 24 17:24:58 Tower kernel: br-2d799c063852: port 7(veth8a92399) entered blocking stateFeb 24 17:24:58 Tower kernel: br-2d799c063852: port 7(veth8a92399) entered disabled stateFeb 24 17:24:58 Tower kernel: veth8a92399: entered allmulticast modeFeb 24 17:24:58 Tower kernel: veth8a92399: entered promiscuous modeFeb 24 17:24:58 Tower kernel: eth0: renamed from vethe3de5c4If these keep going on, you likely have a container constantly restarting. Check their uptimes and look for one that has only been running for a few seconds.
February 24Feb 24 Author 1 hour ago, trurl said:Did you already get that error message again since rebooting?yes→1 hour ago, JorgeB said:Feb 24 17:24:58 Tower kernel: br-2d799c063852: port 7(veth229ee34) entered disabled stateFeb 24 17:24:58 Tower kernel: br-2d799c063852: port 7(veth8a92399) entered blocking stateFeb 24 17:24:58 Tower kernel: br-2d799c063852: port 7(veth8a92399) entered disabled stateFeb 24 17:24:58 Tower kernel: veth8a92399: entered allmulticast modeFeb 24 17:24:58 Tower kernel: veth8a92399: entered promiscuous modeFeb 24 17:24:58 Tower kernel: eth0: renamed from vethe3de5c4If these keep going on, you likely have a container constantly restarting. Check their uptimes and look for one that has only been running for a few seconds.I will keep an eye on the situation.
February 24Feb 24 Author Hi JorgeB,I monitored the containers in question and found one with a short uptime of about 20 seconds ("pterodactyl-daemon"). Since I don't use it, I proceeded to shut it down, disable auto-start, and restart the server, but the error persists:Please find the server logs attached again.Thank you for your support. tower-diagnostics-20260224-2010.zip
February 25Feb 25 Community Expert The problem is with share.cfg, delete that file, then make a dummy change to recreate it. You can, for example, toggle the SMB or NFS services, clicking Apply each time.
February 26Feb 26 Author Hi Jorge,I followed your advice to remove and stop the pterodactyl-daemon. At first, the error still appeared (probably because it was cached), but now it’s gone, so I think that was indeed the issue.I also waited 24 hours to be sure, and the error hasn’t shown up again, so it definitely seems that was the problem.Thanks a lot for your support!
