"Flash Drive Corrupted. Post diagnostic on forum for help"
Sirs,
My array wont spin up. Instead I'm getting a msg that my Flash Drive is corrupted and to post my diagnostics on the Forum. So here they are.
I would appreciate a remedy as soon as possible.
BTW when I try to backup my flash drive from the Main tab, I land on 404 Not Found.
tower-diagnostics-20260225-1130.zip
Lot's of stuff missing from those.
Do you have a current flash backup?
USB NOT recommended for assigned disks for many reasons.
Feb 24 15:14:49 Tower kernel: usb 5-3: USB disconnect, device number 2
Feb 24 15:14:50 Tower emhttpd: Unregistered Flash device error (ENOFLASH3)
Feb 24 15:14:50 Tower kernel: FAT-fs (sda1): Directory bread(block 30720) failed
Feb 24 15:14:50 Tower kernel: FAT-fs (sda1): Directory bread(block 30721) failed
The flash drive is dropping offline; try a different USB port. If it persists, replace it.
