April 3Apr 3 HI,I'm running 7.2.4 and I'm having some trouble that I can't figure out. For reasons I won't go into, I need to move my tower and that means I won't be able to connect it via ethernet: only wifi. I bought a usb WiFi dongle and have set it up in Network setting and it has connected to my wifi so I essentially have both ethernet (eth0) and wifi (wlan0) running. I would have thought that if I unplug my ethernet cable then Unraid would switch to wifi but it doesn't seem to. My web giu just goes blank and won't come back unless I plug the ethernet cable back in.My question is how can I get my tower to run on wifi and not ethernet?Thanks in advance
April 3Apr 3 Community Expert You may need to attach a keyboard and monitor to troubleshoot networking.
April 3Apr 3 Community Expert You should be able to connect to both at the same time using the respective IP address, if you unplug the cable you may need to wait a minute or so to be able to access it using the name.
April 3Apr 3 Author brilliant. thanks so much. I was being an idiot and using the IP for the eth0 connection.All good. thanks
April 3Apr 3 Community Expert You can edit your sig by clicking on your avatar/username in the upper right corner and selecting Account Settings. You can also enable viewing of sigs there. I can see yours and it says you are on Unraid 5.05
