June 14, 201214 yr Hi all, Excuse the extreme newbie post, I'm still testing 5.0b14 in a HP Proliant 240L and am not running multiple drives as yet. Had a power outage last night and was able to spin down and shut down unRAID with no apparent problems as it was on my UPS. Upon restarting, the disk is identified correctly with no errors and in green but the array cannot be started. A full reboot of the box hasn't helped and I feel (perhaps incorrectly) that the disk ( 1 x 250Gb) is still spun down. Syslog attached. Appreciate your help. Thanks! syslog.txt
June 14, 201214 yr Hi all, Excuse the extreme newbie post, I'm still testing 5.0b14 in a HP Proliant 240L and am not running multiple drives as yet. Had a power outage last night and was able to spin down and shut down unRAID with no apparent problems as it was on my UPS. Upon restarting, the disk is identified correctly with no errors and in green but the array cannot be started. A full reboot of the box hasn't helped and I feel (perhaps incorrectly) that the disk ( 1 x 250Gb) is still spun down. Syslog attached. Appreciate your help. Thanks! I see nothing unusual in the syslog. It appears the array has started. The network connection is up.
June 14, 201214 yr Author Yep, all things network and the disk itself appear OK, however this is what I'm seeing (attached)
June 14, 201214 yr Are you running any add-ons? The array is probably trying to mount the shares but the mount point isn't empty. This is a known issue with my Sab plugin Sent from my HTC Vivid
June 14, 201214 yr Author Disabling SABnzbd did the trick, thanks muchly Influencer! Is there a specific version of unRAID and/or SABnzbd I can run that won't have this issue?
