August 9Aug 9 I am about to rebuild my server, and I am looking for guidance on how to best utilise my drives and configure my pools. I can fit 20 drives in my case, and I have picked the most useful 20 I have.This is what I'm currently planning, but not set in stone.Main Array (xfs)5 x WD Red 26TB (one of these as parity)2 x Seagate Ironwolf 12TB2 x Hitachi Deskstar 8TB1 x Seagate Ironwolf 8TB1 x Seagate Barracuda 4TBAppdata (btrfs)2 x Samsung 970 Evo Plus 500GB in Raid 1 (mirror)The above is how my current server is configured, except without the WD Red drives, and the appdata pool is also used as cache for the main array. Since it is only 500GB though, the Samsung 970s often fill up when I download a lot in a short space of time.With the new build, I will have much more space and ports for drives, so I was thinking of adding a few other pools.Cache pool (btrfs/ZFS??)2 x Intel D3-S4510 960GB SSD in RAID 0 or JBODHaving 2TB just for cache should stop the appdata drives from filling up with downloads.Other SSD Pool (ZFS??)4 x Intel D3-S4510 480GB SSD1 x Crucial MX300 500GB SSDMy best idea so far with these drives is to use them as storage for data that would benefit from increased speed. I'm thinking maybe Photos for Immich, Nextcloud files, Paperless documents. Having said that, I currently don't have any speed complaints with Nextcloud or paperless (they are just simple documents after all), and I haven't deployed Immich yet so I'm not sure how much SSD speed will matter there. Currently my Nextcloud files are 311GB and my photos are 430GB.Since this would be important data, I would set it up with some sort of parity protected array or RAID config and maybe ZFS to help protect it.I do run a lot of containers (76) but the only other one I can think that might benefit from fast storage is frigate. Not sure if that's a better use case than the above.I also plan to do Plex transcoding in RAM.So how does this plan sound? Any obvious mistakes, or better file system/RAID choices?Do you have any other suggestions on what I should use the SSDs for, or a better way to configure all these drives?The drives that didn't make the cut were a 2TB Seagate Barracuda Green, a 1TB WD HDD, and 2 x Intel DC S3510 240GB SSDs. I figured adding a few faster SSDs would be more useful than 3TB of extra HDD space.
August 9Aug 9 Community Expert Solution 12 hours ago, Janddy said:I am about to rebuild my server, and I am looking for guidance on how to best utilise my drives and configure my pools. I can fit 20 drives in my case, and I have picked the most useful 20 I have.This is what I'm currently planning, but not set in stone.Main Array (xfs)5 x WD Red 26TB (one of these as parity)2 x Seagate Ironwolf 12TB2 x Hitachi Deskstar 8TB1 x Seagate Ironwolf 8TB1 x Seagate Barracuda 4TBAppdata (btrfs)2 x Samsung 970 Evo Plus 500GB in Raid 1 (mirror)The above is how my current server is configured, except without the WD Red drives, and the appdata pool is also used as cache for the main array. Since it is only 500GB though, the Samsung 970s often fill up when I download a lot in a short space of time.With the new build, I will have much more space and ports for drives, so I was thinking of adding a few other pools.Cache pool (btrfs/ZFS??)2 x Intel D3-S4510 960GB SSD in RAID 0 or JBODHaving 2TB just for cache should stop the appdata drives from filling up with downloads.Other SSD Pool (ZFS??)4 x Intel D3-S4510 480GB SSD1 x Crucial MX300 500GB SSDMy best idea so far with these drives is to use them as storage for data that would benefit from increased speed. I'm thinking maybe Photos for Immich, Nextcloud files, Paperless documents. Having said that, I currently don't have any speed complaints with Nextcloud or paperless (they are just simple documents after all), and I haven't deployed Immich yet so I'm not sure how much SSD speed will matter there. Currently my Nextcloud files are 311GB and my photos are 430GB.Since this would be important data, I would set it up with some sort of parity protected array or RAID config and maybe ZFS to help protect it.I do run a lot of containers (76) but the only other one I can think that might benefit from fast storage is frigate. Not sure if that's a better use case than the above.I also plan to do Plex transcoding in RAM.So how does this plan sound? Any obvious mistakes, or better file system/RAID choices?Do you have any other suggestions on what I should use the SSDs for, or a better way to configure all these drives?The drives that didn't make the cut were a 2TB Seagate Barracuda Green, a 1TB WD HDD, and 2 x Intel DC S3510 240GB SSDs. I figured adding a few faster SSDs would be more useful than 3TB of extra HDD space.the 2x intel, disks I would btrfs RAID0 use for downloads and have mover run more often to move the files the 5x ~480/500GB I would put in a zfs RAIDZ1/RAIDZ2 pool Edited August 9Aug 9 by MowMdown
August 10Aug 10 Author Thanks, that makes sense to me. I wasn't sure between btrfs and zfs for the download disks, but I'm guessing the benefits of zfs won't really apply when you've got 2 disks and the data isn't that important such as downloads.And I think I'll probably do RAIDZ1 for the other pool so I have more space and room to grow. The files will be backed up externally anyway in case a drive fails.
