Problems with Sabnzbd and Sickbeard
I have just replaced my old unraid server (made by old parts laying around) with a new HP Microserver N40L.
And up untill yesterday everything was working just fine. But after a power outage I restarted the server, and now SABnzbd and sickbeard wont start. When I take my array live (that's when sabnzbd and sickbeard are supposed to start) the main webui hangs. After disabling sabnzbd and sickbeard it starts up just fine.
When I try to start sabnzbd manually after the array is online i get this line in the bottom of the screen:
Starting SABnzbd: sudo -u root python /usr/local/sabnzbd/SABnzbd.py --daemon --server 0.0.0.0:7000 --config-file /mnt/disk1/.apps/sabnzbd --pid /var/run/sabnzbd/ 2>&1 >/dev/null
I am using the free version of unraid (version 5.0-rc2), with one 2tb parity drive, and two 2tb data drives.
The plugins are from here:
https://github.com/W-W/unRAID
Can someone please tell me what's going on with my sabnzbd and sickbeard installation? :-\
The config file may have been corrupted because of the power outage and the unclean/quick shutdown.
I have installed both plugins from scratch, with new paths just in case there was some corrupt data.
No one?
I just had this problem when installing for the first time. It's because when the script installs or updates it does this:
version=($(wget -q -O - http://sabnzbdplus.sourceforge.net/version/latest | awk NR==1))
which hasn't been updated to the latest version, 0.7.0. This means it tried to get 0.6.15 from the incorrect place and doesn't install anything.
I changed the line above to this:
#version=($(wget -q -O - http://sabnzbdplus.sourceforge.net/version/latest | awk NR==1))
version="0.7.0"
and the install went fine :)
I'll have to remember to change it back, but it should get you up and running.
That was it! Thank you very much. You just made my day :)
That should have been 0.7.0, not 0.0.7, but I guess you realised that :)
thanks, works for me too..
