July 25, 201214 yr I have an MD1200/IDE unRAID server built for me by Lime Technology several years ago. There is one parity drive and 11 data drives. After a recent power outage, a disk (#7) went bad and I replaced it with a slightly larger disk. The data rebuild began and appeared to finish. However upon reviewing the main web interface, I noticed that drives 10 and 11 had no temperature readings and several write errors. I rebooted, and the same drives were not found/missing. These 2 drives are both connected to the same port on a PCI IDE expansion card using a master/slave IDE connector cable. I replaced the cable thinking it might be the problem, and after a restart both drives reappeared. However, disk 11 has a red ball next to it. There is no longer any option to perform a parity check on the web interface. Movies stored on these 2 drives no longer can be played across my network. Any help in figuring out what might be the problem would be most appreciated. I will attach a syslog (which I have little hope of deciphering). syslog-2012-07-24.txt
