July 29, 201214 yr Hello All, I have been running unRAID 4.7 for a while now without any problems but recently it will be running fine then beep a few times and then it is unreachable by the web page, telnet and of course my xbmc. Has anybody heard of this happening before. It comes back on line after a few hours but I want to know why it goes off line and stop it from doing that. I searched the forums and google but found nothing.
July 29, 201214 yr Hello All, I have been running unRAID 4.7 for a while now without any problems but recently it will be running fine then beep a few times and then it is unreachable by the web page, telnet and of course my xbmc. Has anybody heard of this happening before. It comes back on line after a few hours but I want to know why it goes off line and stop it from doing that. I searched the forums and google but found nothing. unRAID will beep when the network connection drops. Check the cabling. (or the router/switch it is connected to)
July 29, 201214 yr Author Thank you for the prompt response, I restarted the server and it is working fine now but next time it does this again I will check that the NIC LED's are flashing. Thanks again!
