July 31, 201214 yr Good evening, I was wondering if I needed to plug power connectors in each of the 3 Icy Dock 5-in-3 cage power connections ? If not, are there power connection that are critical/required? Thanks in advance.
July 31, 201214 yr According to the product specification page, yes, they are all required ( http://www.icydock.com/goods.php?id=48 ) in the image library there is a picture saying required to connect all power ports)
July 31, 201214 yr Author Thank you Wody! I was wondering if anyone had used the IcyDock without all three connectors powered. I appreciate the response.
