August 2, 201214 yr I had a power outage a couple days ago and unRaid had to recheck the parity after reboot. It seemed to work fine and there were no errors. Now the array won't start up. All the green lights next to the drives are blinking like they are being accessed and it says "starting" but nothing ever happens. I'm dying to watch this weeks Breaking Bad, but it's stuck on the file server! HELP! 5.0-beta12a log.txt
August 3, 201214 yr This has usually been one of the add-ons starting up before the array is online and preventing it from starting. You might want to disable them and see if it helps. If the green indicators on the web-management page are blinking, it indicates the drives are sleeping (spun down) Joe L.
August 3, 201214 yr Author I got it started up by shutting down Sabnzbd, sickbeard, and couchpotato. But now I can't figure out how to get new versions installed.
August 3, 201214 yr I got it started up by shutting down Sabnzbd, sickbeard, and couchpotato. But now I can't figure out how to get new versions installed. See their respective add-on authors for guidance. I think that newer versions of those preventing the array from starting have been posted.
August 3, 201214 yr Author I got everything working using these plugins https://github.com/Influencer/UNplugged
