August 3, 201214 yr Upgraded the motherboard. Regular menu will not load but unmenu will. Attached syslog. Tried the usual killall emhttp stuff with no luck. Thanks! syslog-2012-08-02.txt
August 3, 201214 yr See here: http://lime-technology.com/forum/index.php?topic=21597.msg193408#msg193408
August 4, 201214 yr Author Turned out to be a bad pci-e 4x slot on the motherboard. Moved the m1015 to another slot and it fired right up. Thanks for the help!
