downloadski Posted September 5, 2012 Share Posted September 5, 2012 I am trying to get my PWM fans (Noctua) in control on the X9SCM-F mainbord. It works great on the Supermicro X7SPA i have. The sensor command shows the following devices: nct6776-isa-0a30 Adapter: ISA adapter fan1: 1620 RPM (min = 300 RPM) -> FAN-A on the mainbord = CPU cooler Noctua B9 PWM fan2: 0 RPM (min = 300 RPM) ALARM -> FAN 4 on the mainbord, not used fan3: 1491 RPM (min = 300 RPM) -> FAN 1 on the mainbord = Noctua F12 PWM and Noctua B8 PWM fan4: 1456 RPM (min = 300 RPM) -> FAN 2 on the mainbord = 2 Noctua F12 PWM fan5: 1422 RPM (min = 300 RPM) -> FAN 3 on the mainbord = 2 Noctua F12 PWM This is not matching, but when i log on with IPMI it matches the fan numbering on the mainbord, so the sensors command gives the wrong output it seems. OR it just starts numbering with 1 and continues to 5 ? In the IPMI display there is a red line at 600 rpm (minimal threshold i assume) With the mainbord setting on Full, it runs on 100%, all fans run ok, but noise level is too high. when i select Standard, it should be 50% (650 rpm) Optimal should be 30% (400 rpm) in both the standard and Optimal mode, the fans spin up, drop down and spin back up etc. (about a 25 second cycle) it seems to go down to 300 rpm, and than up to 1300 I found a post on hardforum that the threashold in the bios is set above 300 (700 actually) and this causes the spin up/spin downs http://hardforum.com/showpost.php?p=1038204386&postcount=5 Also that person claimed that FAN-A was linked to pwm1 and FAN1-4 are linked to pwm2 (so only 2 controls for all these fan headers) I assume if i can use PWM control from unraid with a fan script, it could put the lower limit above 700 to avoid this up/down behaviour. Is there a fellow X9SCM-F owner who uses PWM with a fan script ? (i tried to send settings with echo to pwm1 and pwm2, but this does not work) An other option i found on hardforum was to use IPMI to set another threshold. I do not find options for this in the IPMI View 2.9.10 from supermicro which i downloaded. Is there othere IPMI tooling that can do more ? Link to comment
downloadski Posted September 6, 2012 Author Share Posted September 6, 2012 I can control the fans it seems: root@Tower2:/sys/class/hwmon/hwmon1/device/echo 1 > pwm2_enable root@Tower2:/sys/class/hwmon/hwmon1/device# echo 255 > pwm2 root@Tower2:/sys/class/hwmon/hwmon1/device# cat fan5_input 1422 root@Tower2:/sys/class/hwmon/hwmon1/device# echo 120 > pwm2 root@Tower2:/sys/class/hwmon/hwmon1/device# cat fan5_input 718 root@Tower2:/sys/class/hwmon/hwmon1/device# echo 60 > pwm2 root@Tower2:/sys/class/hwmon/hwmon1/device# cat fan5_input 346 Now there seems not longer a 700 rpm threshold Link to comment
mrow Posted September 8, 2012 Share Posted September 8, 2012 For some reason when I enter "/sys/class/hwmon/hwmon1/device/echo 1 > pwm2_enable" in a telnet session I get the error "/sys/class/hwmon/hwmon1/device/echo: No such file or directory" but if I manually navigate to "/sys/class/hwmon/hwmon1/device/" and type "echo 1 > pwm2_enable" it works. What am I doing wrong here? I want to add this to my go script because without it the X9SCM-F is running my CPU fan at only 950 RPM whereas the base speed is supposed to be 2000 RPM. Enabling pwm2 brings it up to the proper speed though. Link to comment
dikkiedirk Posted September 8, 2012 Share Posted September 8, 2012 I don't even have a sensor command, I'm on 5.0 RC3. Must I install a package? Link to comment
downloadski Posted September 8, 2012 Author Share Posted September 8, 2012 I have installed perl via unmenu Also i use the script made by dstroot: http://lime-technology.com/forum/index.php?topic=11310.60 i had to alter 1 line only: ARRAY_FAN=/sys/class/hwmon/hwmon1/device/pwm4 into: ARRAY_FAN=/sys/class/hwmon/hwmon1/device/pwm2" Also you need to perhaps change a line for the fan to minitor the speed of: ARRAY_FAN_INPUT=/sys/class/hwmon/hwmon1/device/fan4_input # Used to track actual rpm values There needs to be a fan connected otherwise it iwll return 0 and not work i think. Link to comment
dikkiedirk Posted September 10, 2012 Share Posted September 10, 2012 I am trying to get my PWM fans (Noctua) in control on the X9SCM-F mainbord. It works great on the Supermicro X7SPA i have. The sensor command shows the following devices: nct6776-isa-0a30 Adapter: ISA adapter fan1: 1620 RPM (min = 300 RPM) -> FAN-A on the mainbord = CPU cooler Noctua B9 PWM fan2: 0 RPM (min = 300 RPM) ALARM -> FAN 4 on the mainbord, not used fan3: 1491 RPM (min = 300 RPM) -> FAN 1 on the mainbord = Noctua F12 PWM and Noctua B8 PWM fan4: 1456 RPM (min = 300 RPM) -> FAN 2 on the mainbord = 2 Noctua F12 PWM fan5: 1422 RPM (min = 300 RPM) -> FAN 3 on the mainbord = 2 Noctua F12 PWM This is not matching, but when i log on with IPMI it matches the fan numbering on the mainbord, so the sensors command gives the wrong output it seems. OR it just starts numbering with 1 and continues to 5 ? In the IPMI display there is a red line at 600 rpm (minimal threshold i assume) With the mainbord setting on Full, it runs on 100%, all fans run ok, but noise level is too high. when i select Standard, it should be 50% (650 rpm) Optimal should be 30% (400 rpm) in both the standard and Optimal mode, the fans spin up, drop down and spin back up etc. (about a 25 second cycle) it seems to go down to 300 rpm, and than up to 1300 I found a post on hardforum that the threashold in the bios is set above 300 (700 actually) and this causes the spin up/spin downs http://hardforum.com/showpost.php?p=1038204386&postcount=5 Also that person claimed that FAN-A was linked to pwm1 and FAN1-4 are linked to pwm2 (so only 2 controls for all these fan headers) I assume if i can use PWM control from unraid with a fan script, it could put the lower limit above 700 to avoid this up/down behaviour. Is there a fellow X9SCM-F owner who uses PWM with a fan script ? (i tried to send settings with echo to pwm1 and pwm2, but this does not work) An other option i found on hardforum was to use IPMI to set another threshold. I do not find options for this in the IPMI View 2.9.10 from supermicro which i downloaded. Is there othere IPMI tooling that can do more ? nct6776-isa-0a30 doesn't show on my x9scm. is there something wrong with the unraid kernel? Using 5.0 RC6 test2. Or are there BIOS settings involved? Link to comment
StevenD Posted September 10, 2012 Share Posted September 10, 2012 I'm wondering if something changed as well. I'm running a SuperMicro C2SEE, and when I upgraded from 4.7 to 5.0 last week, PWMCONFIG no longer detects anything. Its not that big of a deal to me anymore since the other servers I added to the rack drown my unRAID box out anyway, but it would be nice to know why I can no longer do PWM fan control. Link to comment
downloadski Posted September 11, 2012 Author Share Posted September 11, 2012 nct6776-isa-0a30 doesn't show on my x9scm. is there something wrong with the unraid kernel? Using 5.0 RC6 test2. Or are there BIOS settings involved? i do not know, this is what i see: root@Tower2:~# sensors coretemp-isa-0000 Adapter: ISA adapter Physical id 0: +33.0 C (high = +90.0 C, crit = +94.0 C) Core 0: +25.0 C (high = +90.0 C, crit = +94.0 C) Core 1: +30.0 C (high = +90.0 C, crit = +94.0 C) Core 2: +25.0 C (high = +90.0 C, crit = +94.0 C) Core 3: +33.0 C (high = +90.0 C, crit = +94.0 C) nct6776-isa-0a30 Adapter: ISA adapter in0: +0.92 V (min = +0.60 V, max = +1.49 V) in1: +1.85 V (min = +1.62 V, max = +1.99 V) in2: +3.36 V (min = +2.96 V, max = +3.63 V) in3: +3.36 V (min = +2.96 V, max = +3.63 V) in4: +1.53 V (min = +1.35 V, max = +1.65 V) in5: +1.26 V (min = +1.13 V, max = +1.38 V) in7: +3.34 V (min = +2.96 V, max = +3.63 V) in8: +3.09 V (min = +2.96 V, max = +3.63 V) fan1: 1706 RPM (min = 300 RPM) fan2: 0 RPM (min = 300 RPM) ALARM fan3: 991 RPM (min = 300 RPM) fan4: 1004 RPM (min = 300 RPM) fan5: 974 RPM (min = 300 RPM) SYSTIN: +40.0 C (high = +75.0 C, hyst = +70.0 C) sensor = thermistor CPUTIN: +32.5 C (high = +80.0 C, hyst = +75.0 C) sensor = thermistor AUXTIN: +1.5 C sensor = thermistor PECI Agent 0: +38.5 C (high = +95.0 C, hyst = +92.0 C) cpu0_vid: +0.000 V Link to comment
dikkiedirk Posted September 11, 2012 Share Posted September 11, 2012 I only see the coretemp output. The other one is missing. I use RC6-test2. Has there been something deleted from the kernel? I need test2 because I have a LSI2008 controller. I changed to RC6-test. Same result, just coretemp. How to get the PWM-output? Link to comment
downloadski Posted September 11, 2012 Author Share Posted September 11, 2012 you need to run sensors-detect to find these controllers i think. In the script you load the drivers for these modules: # Load adapter drivers: modprobe ipmi-si # Load chip drivers: modprobe coretemp modprobe w83627ehf Link to comment
dikkiedirk Posted September 11, 2012 Share Posted September 11, 2012 you need to run sensors-detect to find these controllers i think. In the script you load the drivers for these modules: # Load adapter drivers: modprobe ipmi-si # Load chip drivers: modprobe coretemp modprobe w83627ehf Thanks, I do get the output like you described with the sensors command. Do you add these lines to the go script? Link to comment
mrow Posted September 11, 2012 Share Posted September 11, 2012 If you install the plugin he listed it'll run those commands automatically for the modprobe sensors. Link to comment
dabl Posted September 11, 2012 Share Posted September 11, 2012 I'm wondering if something changed as well. I'm running a SuperMicro C2SEE, and when I upgraded from 4.7 to 5.0 last week, PWMCONFIG no longer detects anything. Its not that big of a deal to me anymore since the other servers I added to the rack drown my unRAID box out anyway, but it would be nice to know why I can no longer do PWM fan control. Wow this is a huge deal to me (I have a SuperMicro C2SEE). Can confirm/deny PWMCONFIG doesn't/does work with SuperMicro C2SEE on unraid v5? I'll start a different thread about it. Link to comment
StevenD Posted September 12, 2012 Share Posted September 12, 2012 I'm wondering if something changed as well. I'm running a SuperMicro C2SEE, and when I upgraded from 4.7 to 5.0 last week, PWMCONFIG no longer detects anything. Its not that big of a deal to me anymore since the other servers I added to the rack drown my unRAID box out anyway, but it would be nice to know why I can no longer do PWM fan control. Wow this is a huge deal to me (I have a SuperMicro C2SEE). Can confirm/deny PWMCONFIG doesn't/does work with SuperMicro C2SEE on unraid v5? I'll start a different thread about it. Thanks to downloadski, its now working! Stock 5.0 on C2SEE: root@nas:~# sensors coretemp-isa-0000 Adapter: ISA adapter Core 0: +43.0 C (high = +74.0 C, crit = +100.0 C) Core 1: +39.0 C (high = +74.0 C, crit = +100.0 C) Core 2: +45.0 C (high = +74.0 C, crit = +100.0 C) Core 3: +45.0 C (high = +74.0 C, crit = +100.0 C) Adding "modprobe w83627ehf" to the GO file: root@nas:~# modprobe w83627ehf root@nas:~# sensors coretemp-isa-0000 Adapter: ISA adapter Core 0: +43.0 C (high = +74.0 C, crit = +100.0 C) Core 1: +39.0 C (high = +74.0 C, crit = +100.0 C) Core 2: +45.0 C (high = +74.0 C, crit = +100.0 C) Core 3: +45.0 C (high = +74.0 C, crit = +100.0 C) w83627dhg-isa-0290 Adapter: ISA adapter Vcore: +1.14 V (min = +0.92 V, max = +1.48 V) in1: +1.84 V (min = +1.65 V, max = +1.99 V) AVCC: +3.31 V (min = +2.96 V, max = +3.63 V) VCC: +3.31 V (min = +3.26 V, max = +3.28 V) ALARM in4: +1.58 V (min = +1.35 V, max = +1.65 V) in5: +1.26 V (min = +1.13 V, max = +1.38 V) in6: +1.46 V (min = +1.42 V, max = +1.52 V) 3VSB: +3.38 V (min = +2.96 V, max = +3.63 V) Vbat: +3.31 V (min = +2.96 V, max = +3.63 V) fan1: 1875 RPM (min = 712 RPM, div = fan2: 1939 RPM (min = 712 RPM, div = fan3: 2109 RPM (min = 712 RPM, div = fan4: 1875 RPM (min = 712 RPM, div = fan5: 1854 RPM (min = 712 RPM, div = temp1: +50.0 C (high = +60.0 C, hyst = +55.0 C) sensor = thermistor temp2: +43.0 C (high = +79.0 C, hyst = +74.0 C) sensor = diode temp3: +0.0 C (high = +79.0 C, hyst = +74.0 C) sensor = diode cpu0_vid: +1.513 V I can now see everything! I also have two "hwmon"s root@nas:/sys/class/hwmon/hwmon1# ls device@ power/ subsystem@ uevent root@nas:/sys/class/hwmon/hwmon1# cd device root@nas:/sys/class/hwmon/hwmon1/device# ls cpu0_vid fan4_div in1_min in5_max modalias pwm2_start_output pwm4_enable temp1_type driver@ fan4_input in2_alarm in5_min name pwm2_step_output pwm4_max_output temp2_alarm fan1_alarm fan4_min in2_input in6_alarm power/ pwm2_stop_output pwm4_mode temp2_input fan1_div fan5_alarm in2_max in6_input pwm1 pwm2_stop_time pwm4_start_output temp2_max fan1_input fan5_div in2_min in6_max pwm1_enable pwm2_target pwm4_step_output temp2_max_hyst fan1_min fan5_input in3_alarm in6_min pwm1_mode pwm2_tolerance pwm4_stop_output temp2_offset fan2_alarm fan5_min in3_input in7_alarm pwm1_start_output pwm3 pwm4_stop_time temp2_type fan2_div hwmon/ in3_max in7_input pwm1_stop_output pwm3_enable pwm4_target temp3_alarm fan2_input in0_alarm in3_min in7_max pwm1_stop_time pwm3_mode pwm4_tolerance temp3_input fan2_min in0_input in4_alarm in7_min pwm1_target pwm3_start_output subsystem@ temp3_max fan3_alarm in0_max in4_input in8_alarm pwm1_tolerance pwm3_stop_output temp1_alarm temp3_max_hyst fan3_div in0_min in4_max in8_input pwm2 pwm3_stop_time temp1_input temp3_offset fan3_input in1_alarm in4_min in8_max pwm2_enable pwm3_target temp1_max temp3_type fan3_min in1_input in5_alarm in8_min pwm2_max_output pwm3_tolerance temp1_max_hyst uevent fan4_alarm in1_max in5_input intrusion0_alarm pwm2_mode pwm4 temp1_offset unraid-fan-speed.sh works now too! root@nas:/boot/custom/bin# unraid-fan-speed.sh Highest temp is: 41 Setting pwm to: 225 Link to comment
StevenD Posted September 12, 2012 Share Posted September 12, 2012 I just checked and apparently my fans were spinning pretty slow. I noticed that since I switched to 5.0 my temps went up 4-6 degrees. Now that the sensors, and the fan speed control script, are working again, my temps are back down. I'm very happy! Thanks again downloadski!! Link to comment
dabl Posted September 12, 2012 Share Posted September 12, 2012 Awesome, thanks downloadski and StevenD, appreciated! Link to comment
downloadski Posted September 12, 2012 Author Share Posted September 12, 2012 You are welcome. All the thanks need to go to dstroot and others who made the plugin in one of the x7spa threads. Link to comment
dikkiedirk Posted September 12, 2012 Share Posted September 12, 2012 If you install the plugin he listed it'll run those commands automatically for the modprobe sensors. Where do I get this plugin? Link to comment
dikkiedirk Posted September 12, 2012 Share Posted September 12, 2012 I just checked and apparently my fans were spinning pretty slow. I noticed that since I switched to 5.0 my temps went up 4-6 degrees. Now that the sensors, and the fan speed control script, are working again, my temps are back down. I'm very happy! Thanks again downloadski!! Yes, good job downloadski and thank you so very much! Link to comment
downloadski Posted September 12, 2012 Author Share Posted September 12, 2012 If you install the plugin he listed it'll run those commands automatically for the modprobe sensors. Where do I get this plugin? http://lime-technology.com/forum/index.php?topic=11310.msg153187#msg153187 Link to comment
aiden Posted October 23, 2012 Share Posted October 23, 2012 Also i use the script made by dstroot: http://lime-technology.com/forum/index.php?action=post;quote=153187;topic=11310.60;last_msg=165603 i had to alter 1 line only: ARRAY_FAN=/sys/class/hwmon/hwmon1/device/pwm4 into: ARRAY_FAN=/sys/class/hwmon/hwmon1/device/pwm2" Also you need to perhaps change a line for the fan to minitor the speed of: ARRAY_FAN_INPUT=/sys/class/hwmon/hwmon1/device/fan4_input # Used to track actual rpm values There needs to be a fan connected otherwise it iwll return 0 and not work i think. Downloadski, I wrote the original script (based on Starcat's work) that dstroot improved, cleaned up, and looped so there isn't a need for a cron job. Your modifications are correct, and in fact I made the exact same changes for my X9SCM board a while back. I just found this thread, but I wanted to confirm your changes are valid. You do need to make both changes you suggested, because without the fan speed detection, the script will fail. Good work on doing the digging around and finding the correct pwm variables. However, has anyone noticed that occasionally the board will force the fans to drop below 700? I modified my script to check every minute, so it resets to the correct speed, but it is annoying. I'm running the 1.1 bios, with the Fan Control Speed set on Standard in the bios. Anyone else having this issue? Link to comment
downloadski Posted October 26, 2012 Author Share Posted October 26, 2012 Aiden, i must thank you also than. It works for me, and never drops below 700 i think (would the mainbord not ramp it back up to full if so ?) I have to look in the script to force my cpu fan down as well. Perhaps not temperature controlled, but just in decrements of 10% down and check i not see the temp go up. I have a rather large fan and a 45 watt tdp cpu, so i never see it above 30 degrees celcius. The noise can be much lower without overheating the cpu i bet. Link to comment
aiden Posted November 3, 2012 Share Posted November 3, 2012 What value are you using for FAN_OFF_PWM? Link to comment
downloadski Posted November 19, 2012 Author Share Posted November 19, 2012 i have 45 configured now With 0 the systems ramps them up to full speed. The systems runs now with 1 TB samsungs that stay pretty cool. So i had to adjust the low temperature a bit down, and now it is ok again. Link to comment
PeterB Posted February 13, 2013 Share Posted February 13, 2013 For some reason when I enter "/sys/class/hwmon/hwmon1/device/echo 1 > pwm2_enable" in a telnet session I get the error "/sys/class/hwmon/hwmon1/device/echo: No such file or directory" but if I manually navigate to "/sys/class/hwmon/hwmon1/device/" and type "echo 1 > pwm2_enable" it works. What am I doing wrong here? Errr.... that should be: echo 1 > /sys/class/hwmon/hwmon1/device/pwm2_enable Link to comment
