December 2, 201213 yr Need to increase cooling - everything is stock as far as case/fans etc.... suggestions/recommendations? Thanks Myk
December 2, 201213 yr Need to increase cooling - everything is stock as far as case/fans etc.... suggestions/recommendations? Thanks Myk Get the 120mm fan wall, from Norco. There are then many choices of higher volume 120mm fans to use. I replaced the 80 mm fans on the rear of the case as well, as they sounded like a Mack truck.
