unMENU mount usb drive problem
Hello,
I am unable to mount a USB drive.  It appears in the Disk Management screen but there are no buttons.  I have tried it formatted as NTFS and FAT32 and neither will work.
Screenshot:
What so you see when you type
vol_id /dev/sde1
and
blkid /dev/sde1
They are the commands used by unMENU to determine how the disk is formatted.
Joe L.
Unfortunately I can't test that as after formatting the disk again and copying contents back to it, it started showing up properly in unMENU and lets me mount it.
Now I'm having trouble with the share button.  No new shares appear after clicking it.  Telnetting to the box shows that it has been mounted properly.  Not sure how to debug the share?  Nothing shows up in the system log.
