AirVideo, Transcoding, Wireless and CPU?
So, I turned off my server for 2 days, and tonight I turned it back on, and for some reason or another I get this: Java installation NOT detected. Please install a compatible version of Java.
JRE is installed.  I went to unmenu, setting clicked on JRE, and it shows Status: Java vNo is installed.
So, I'll go ahead and see if I can install it again via telnet.
Quick question, how do I uninstall / remove plugins?  Do, I just delete them from the plug-in folder and reboot?
Well, I've tried installing the JRE plugin, and it won't work.  This is the error I get:
root@Tower:/boot/config/plugins# installplg jre-6u27-i586-1aj.plg
installing plugin: jre-6u27-i586-1aj
file /boot/packages/jre-6u27-i586-1.txz: downloading from http://carroll.cac.psu.edu/pub/linux/distributions/slackware/slackware-current/slackware/l/jre-6u27-i586-1.txz ... http://carroll.cac.psu.edu/pub/linux/distributions/slackware/slackware-current/slackware/l/jre-6u27-i586-1.txz:
2013-01-12 04:41:58 ERROR 404: Not Found.
bad download, deleting
Use this one.  It's my cloud copy of jre plugin, updated to use jre version 7u2
or from command line:
wget -q -P /boot/config/plugins http://dl.dropbox.com/u/572553/UnRAID/jre7u2/jre-7u2-i586.plg
installplg /boot/config/plugins/jre-7u2-i586.plg
then enable it via unraid webgui settings page
I deleted my priovious JRE, and I've installed the 7u2.  For some reason or another my server became unresponsive via IP, telnet, etc.  I had to do a hard reset, and now conducting a parity check, but AirVideo starts up when the server is rebooted.
