Please help me :( First build ever and I'm overanalyzing it
Please help me...I'm having writers block (but with technology).  I feel like I have enough of the makings to make a really good system but cant make my mind up on what direction I should go.  RAID? Unraid? Use my gaming desktop as my server? Run a VM on my desktop as a server?  I'd hate to lose my desktop for a server only because I feel like its a bit of overkill but I'll do it if its really my only way and I couldnt/shouldnt run VM's for a server, etc.  I just want a media server and be able to run XBMC on my network at my house and use a PVR using my HR Prime.
Here's my goods!
Desktop:
Thermaltake Case http://www.thermaltakeusa.com/Product.aspx?C=1407&ID=1852#Tab1
QuadCore AMD Phenom II X4 Black Edition 965, 3716 MHz (18.5 x 201)
Gigabyte GA-790FXTA-UD5 (3 PCI, 1 PCI-E x1, 3 PCI-E x16, 4 DDR3 DIMM, Audio, Dual Gigabit LAN, IEEE-1394)
Motherboard Chipset  AMD 790FX, AMD K10
System Memory  20480 MB (DDR3-1333 DDR3 SDRAM)
DIMM1: G Skill F3-1333C9-8GAO  8 GB DDR3-1333 DDR3 SDRAM
DIMM2: G Skill F3-1333C9-8GAO  8 GB DDR3-1333 DDR3 SDRAM
DIMM3: G Skill F3-12800CL7-2GBRH  2 GB DDR3-1333 DDR3 SDRAM
DIMM4: G Skill F3-12800CL7-2GBRH  2 GB DDR3-1333 DDR3 SDRAM
Disk Drive  WDC WD20EURS-63Z9B1 ATA Device (2000 GB, SATA-II)
Disk Drive  INTEL SSDSA2CW160G3 ATA Device (160 GB, SATA-II)
Disk Drive  ST3000DM001-9YN166 ATA Device (3000 GB, 7200 RPM, SATA-III)
Disk Drive  ST31500341AS ATA Device (1500 GB, 7200 RPM, SATA-II)
HP Slimline (from 2008):
AMD Athlon 64 X2 5200+ 2.6GHz (65W) Dual Core processor with 2000MT/s (mega transfers/second) and socket AM2
ATSC and NTSC built in HDTV tuner with FM tuner
2GB PC2-5300 MB/sec 240 pin, DDR2 SDRAM installed, upgradeable to 4GB (2 memory slots)
500GB SATA 3G (3.0 Gb/sec) 7200 rpm hard drive
16X DVD± R/RW 12X RAM ±R DL LightScribe SATA optical drive
Wireless LAN 802.11 b/g with integrated 10/100 Base-T networking interface
TV tuner card with GeForce 6150SE nForce 430 chipset
6 USB 2.0 ports (2 front, 4 rear)
Dell Studio laptop:
Processor 2.2 GHz Intel Core 2 Duo
RAM 4 GB DDR2
Hard Drive 320 GB
Graphics Coprocessor Radeon HD 4570
Chipset Brand ATI
Card Description Radeon HD 4570
Graphics Card Ram Size 512 MB
Number of USB 2.0 Ports 3
I have 2 more Xbox 360's that I could use WMC if needed.
I'm willing to do whatever at this point, I just need to get on a track and follow it.  I've been racking my brain for days on this and feel like I havent gotten anywhere.  Thank you so much...I'm running out of options here.  I'll start building something then stop and try something different.
