Hardware power consumption?
How can I find out what my Unraid rig's power usage is at idle and all drives spun up.
Is there software?
I think you will need hardware for this. There is a deviced called a Kill-A-Watt meter (or similar) that you can plug your computer into and read the watts used. Many better UPSes have a similar feature. To measure spun up vs non-spun up is just a matter of the state of your drives when you take the reading.
found it on newegg
Kill a watt load meter $18
thanks!
