March 21, 201313 yr I finally was able to get all of my data transferred to my new unRAID server today and was ready to install my new parity drive when i started experiencing issues. I stopped the array and then the web interface became unresponsive so i verified that all of my plugins were stopped which they were, i ran a lsof | grep /mnt and it returned nothing so i followed the steps to stop the array manually just in case it hadn't done so and then rebooted via telnet. Once it was back up i was able to access unmenu but not the web interface, so i manually shut the array down again and then removed the simple features plugin and then rebooted. Once it came back up i was able to access the web interface just fine, so i verified all simple features stuff was removed from my flash drive and then re-downloaded it and put it back on my flash drive and rebooted. On reboot, i was able to access the SF web interface just fine, so I again attempted to stop my array so I could add my parity disk and everything went unresponsive again. Obviously the issue revolves around the simple features plugin but to be honest I don't understand why it isn't functioning well now. I have run this just fine for almost 2 weeks and have stopped/started the array multiple times, why am i running into these issues now? Even after i remove everything SF related and re-install it the issues come back. Can someone explain this to me?
March 21, 201313 yr You might be better served posting this here: http://lime-technology.com/forum/index.php?topic=12698.0
March 21, 201313 yr I would go with the vanilla setup, get your array protected, add any additional data to array run a parity check and only then play with add ons. Simple features is once, but has had issues with the newer rc of unraid. Unmenu has been working great for me. I just want my media streamed to me with an interface that I can use when needed, which is not that often.
