April 25, 201313 yr ...which memory specifically? ...or did you indent to use only one, single module?...see here, then: http://lime-technology.com/forum/index.php?topic=27096.msg237689#msg237689
April 25, 201313 yr Author http://www.amazon.com/Crucial-PC3-10600-240-Pin-Unbuffered-CT2CP102464BA1339/dp/B005NU48JG
April 25, 201313 yr ...I believe that this is non-ECC memory, ...it will not work. I suggest to use the kingston memory finder for that board, then search for the best offer for your RAM of choice
April 25, 201313 yr ...I believe that this is non-ECC memory, ...it will not work. I suggest to use the kingston memory finder for that board, then search for the best offer for your RAM of choice You are correct. From the product description on that page: It is Unbuffered and is non-ECC
May 25, 201313 yr Author *UPDATED FIRST MESSAGE* I've been looking for details on the power draw of these parts and cannot find them anywhere! Any ideas?
