June 21, 201313 yr I am using the Configuration Tutorial. I am at the section: Add Drives to the Array I have run preclear x3 on both drives, Assigned largest as parity and the other as disk 1. Enabled shares. I am on Step 5: Under MAIN, the start button is greyed out and it says "No array disk devices have been assigned" It seems that under DEVICES: The changes are NOT taking effect immediately syslog.zip
June 21, 201313 yr Author Sorry, I should have thought to post that SanDisk Cruzer Fit 4 GB USB Flash Drive SDCZ33-004G-B35 Western Digital WD Black WD4001FAEX 4TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive (parity) Western Digital Red WD30EFRX 3TB IntelliPower 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive GIGABYTE GA-F2A85XM-D3H FM2 AMD A85X (Hudson D4) HDMI SATA 6Gb/s USB 3.0 Micro ATX AMD Motherboard AMD A4-5300 Trinity 3.4GHz (3.6GHz Turbo) Socket FM2 65W Dual-Core Desktop APU (CPU + GPU) with DirectX 11 Graphic AMD Radeon HD 7480D AD5300OKHJBOX G.SKILL Ripjaws X Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL9D-4GBXM CORSAIR Builder Series CX430 430W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply
June 21, 201313 yr I am using the Configuration Tutorial. I am at the section: Add Drives to the Array I have run preclear x3 on both drives, Assigned largest as parity and the other as disk 1. Enabled shares. I am on Step 5: Under MAIN, the start button is greyed out and it says "No array disk devices have been assigned" It seems that under DEVICES: The changes are NOT taking effect immediately 4.7 does NOT support drives larger than 2.2TB. Redo your install with 5rc15a and try again.
June 22, 201313 yr I would also hold off installing any add-ons as this thread, http://lime-technology.com/forum/index.php?topic=28142.0 makes me think there is probably going to be another RC. Will just make it easier to upgrade.
July 12, 201313 yr Author Just a followup - things are working great with RC5a and plus license - 5 disks
July 12, 201313 yr Just a followup - things are working great with RC5a and plus license - 5 disks I assume you meant RC15a? It is worth pointing that RC16c is the current latest release and 5.0 final is looking imminent.
July 12, 201313 yr Just a followup - things are working great with RC5a and plus license - 5 disks Definitely upgrade to RC16c ==> there's a serious data loss issue in RC15a that's been resolved with the latest release.
