June 22, 201313 yr Curious if anyone making a Mini-ITX build using the Rosewill RS-MI-01 case knows of any good [QUIET] CPU coolers that will fit into the limited space between the CPU and the underside of the PSU. The OEM cooler on my socket AM3 CPU fits fine, but is noisy. I'm wondering if anyone knows of any better CPU coolers that fit. Maybe a Scythe Shuriken possibly? Something else? My experience is that this case is not a good choice for a quiet build. There's not enough room for good airflow, and the limited space prevents using big heatsinks.
June 22, 201313 yr I used a Scythe Shuriken Rev.B SCSK-110 on a 250 X2 in a very tight HTPC. It was much more quite than the stock cooler
