July 4, 201313 yr Hi guys, I've recently moved over to 5.0 (clean install), only installed SimpleFeatures and some of it's plugins so far. I've added a new disk to the array and started the clearing process, however the web interface has become unresponsive. Can't access it or tell what it's doing unless I go to the pc and take control via command line. I'm not too worried because I suspect that it's just doing it's thing and hopefully in a few hours when the clearing process is done I will be able to access it again? Or at least I'm going to wait quite a while before I attempt to do a reboot at command line to get things going again. The only reason I pose this question is because i've noticed quite a big slow down in accessing my server over the web interface and intermittent problems (having to refresh and pages taking long to load) and I didn't notice them in the previous stable unraid version (4.7). Is anyone else noticing this? OR getting any problems relating to system responsiveness in the web interface? Is this simply a side effect of a RC build? Any thoughts welcome. Thanks Nokoff
July 4, 201313 yr Hi guys, I've recently moved over to 5.0 (clean install), only installed SimpleFeatures and some of it's plugins so far. I've added a new disk to the array and started the clearing process, however the web interface has become unresponsive. Can't access it or tell what it's doing unless I go to the pc and take control via command line. I'm not too worried because I suspect that it's just doing it's thing and hopefully in a few hours when the clearing process is done I will be able to access it again? Or at least I'm going to wait quite a while before I attempt to do a reboot at command line to get things going again. The only reason I pose this question is because i've noticed quite a big slow down in accessing my server over the web interface and intermittent problems (having to refresh and pages taking long to load) and I didn't notice them in the previous stable unraid version (4.7). Is anyone else noticing this? OR getting any problems relating to system responsiveness in the web interface? Is this simply a side effect of a RC build? Any thoughts welcome. Thanks Nokoff Try this without any plugins.
