September 9, 201312 yr For the past few days, the transfer speed on my unRaid server suddenly went from 30-40 mb/sec to between 500kb to 2 mb/sec. I started seeing the change as soon as I purchased the plus license key and installed a cache drive. I tried playing with the settings on my linksys e4200, and unmounting the cache drive, but the speed remained the same. I also tried connecting my old NAS with the same cable and port, and did not experience the same problem I have with unRaid. Can someone take a look at my syslog and see what's going on? Thanks. Here's my eth0 log Tower login: root Linux 3.9.6p-unRAID. root@Tower:~# ethtool eth0 Settings for eth0: Supported ports: [ TP ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Supports auto-negotiation: Yes Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Advertised pause frame use: Symmetric Receive-only Advertised auto-negotiation: Yes Speed: 1000Mb/s Duplex: Full Port: Twisted Pair PHYAD: 0 Transceiver: internal Auto-negotiation: on MDI-X: Unknown Supports Wake-on: pumbg Wake-on: g Current message level: 0x00000033 (51) Link detected: yes root@Tower:~# syslog.txt
September 10, 201312 yr Author Tower login: root Linux 3.9.6p-unRAID. root@Tower:~# ifconfig eth0 Link encap:Ethernet HWaddr inet addr:192.168.1.115 Bcast:192.168.1.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:297 errors:0 dropped:0 overruns:0 frame:0 TX packets:340 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:31382 (30.6 KiB) TX bytes:146828 (143.3 KiB) Interrupt:40 Base address:0x8000 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:8 errors:0 dropped:0 overruns:0 frame:0 TX packets:8 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:560 (560.0 B) TX bytes:560 (560.0 B) root@Tower:~#
September 10, 201312 yr Author new ifconfig and syslog Tower login: root Linux 3.9.6p-unRAID. root@Tower:~# cp /var/log/syslog /boot root@Tower:~# ifconfig eth0 Link encap:Ethernet HWaddr inet addr:192.168.1.115 Bcast:192.168.1.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:16250 errors:0 dropped:0 overruns:0 frame:0 TX packets:11663 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:23950671 (22.8 MiB) TX bytes:1018148 (994.2 KiB) Interrupt:40 Base address:0x8000 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:8 errors:0 dropped:0 overruns:0 frame:0 TX packets:8 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:560 (560.0 B) TX bytes:560 (560.0 B) root@Tower:~# Tower login: root Linux 3.9.6p-unRAID. root@Tower:~# cp /var/log/syslog /boot root@Tower:~# ifconfig eth0 Link encap:Ethernet HWaddr inet addr:192.168.1.115 Bcast:192.168.1.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:16250 errors:0 dropped:0 overruns:0 frame:0 TX packets:11663 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:23950671 (22.8 MiB) TX bytes:1018148 (994.2 KiB) Interrupt:40 Base address:0x8000 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:8 errors:0 dropped:0 overruns:0 frame:0 TX packets:8 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:560 (560.0 B) TX bytes:560 (560.0 B) root@Tower:~# syslog.txt
September 11, 201312 yr The syslog only shows 2 minutes of activity. Where the transfers done during this period? About 20M was transferred to the server. How many files? Download and check the speed with teracopy (http://codesector.com/teracopy).
September 11, 201312 yr Author I was trying to transfer one big file during that period of time, but it was so slow that I cancelled it. I have been playing around with some settings on my pc end, and it seems that the problem only affects the speed copying from my pc to the unraid, copying from unraid to desktop was unaffected. For some reason, I could no longer map the unraid folder, and the only way to access it was from workgroup. I also tried teracopy, but for some reason, the speed was even slower than copying from windows explorer. I have attached a longer syslog of a transfer of a folder of multiple files (32.9 GB, 178 files, took around 3 hours) here if you could take a look for me, thanks. syslog.txt
