Syslog attached- startup problem after working inside case
Okay, so my unraid had been running fine for quite a while. I had to get something from the case (a spare 3.5" to 5.25" adapter bracket- nothing having to do with the configuration or installed hardware.) Anyway, since taking it down and putting it back together and powering back up, I have not been able to see the web interface or telnet in. When I connect the unraid to a monitor on boot, it does load the software from the CF card, and shows a list at the end of the boot sequence of the shares or folders or something, then goes to the login, and root does work. That's how I got the syslog. Ifconifg shows it's taking the same static IP it's always have and I assigned in the config, but I can't get to the web interface. There is also a lot of disk activity light on the restart, like it's doing a parity check or something, but again, no web interface or no shares/drives available on the network. Any advice would be appreciated. Thanks. Syslog attached.
Unglug/replug/replace the LAN cable... and check the link LED on the hub and NIC.
Thanks, nope, I was using a swapped, known good network cable and switch. I did change to another new and tested cable too, just for grins, and no go. Both cables show NIC link LED lights, and in the boot up on-screen, and with ifconfig, show the tower is getting the IP address.
PS- the config has 7 drives, including the parity 500GB, three other 500GB, a pair of 250s and one 300.
Does anyone know what do these items from the log mean:
Dec 22 23:33:33 unraid kernel: unraid: allocated 15222kB
Dec 22 23:33:33 unraid kernel: md1: running, size: 488386552 blocks
Dec 22 23:33:33 unraid kernel: md2: running, size: 488385496 blocks
Dec 22 23:33:33 unraid kernel: md3: running, size: 245117344 blocks
Dec 22 23:33:33 unraid kernel: md4: running, size: 293057320 blocks
Dec 22 23:33:33 unraid kernel: md5: running, size: 488386552 blocks
Dec 22 23:33:33 unraid kernel: md6: running, size: 245117344 blocks
Dec 22 23:33:34 unraid kernel: mdcmd (5): check
Dec 22 23:33:34 unraid kernel: md: recovery thread got woken up ...
Dec 22 23:33:34 unraid kernel: md: recovery thread checking parity...
Dec 22 23:33:28 unraid kernel: hda: MAXTOR STM3500630A, ATA DISK drive
Dec 22 23:33:28 unraid kernel: hda: host max PIO4 wanted PIO255(auto-tune) selected PIO4
Dec 22 23:33:28 unraid kernel: hda: UDMA/100 mode selected
Dec 22 23:33:28 unraid kernel: ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Dec 22 23:33:28 unraid kernel: hda: max request size: 512KiB
Dec 22 23:33:28 unraid kernel: hda: Host Protected Area detected.
Dec 22 23:33:28 unraid kernel: ^Icurrent capacity is 976771055 sectors (500106 MB)
Dec 22 23:33:28 unraid kernel: ^Inative  capacity is 976773168 sectors (500107 MB)
Dec 22 23:33:28 unraid kernel: hda: Host Protected Area disable
Dec 22 23:33:34 unraid kernel: can't shrink filesystem on-line
Dec 22 23:33:34 unraid last message repeated 4 times
Dec 22 23:33:35 unraid kernel: ReiserFS: md4: replayed 2 transactions in 1 seconds
Dec 22 23:33:35 unraid kernel: ReiserFS: md4: Using r5 hash to sort names
Dec 22 23:33:35 unraid kernel: can't shrink filesystem on-line
Dec 22 23:33:36 unraid emhttp: shcmd (18): mkdir -m 700 /mnt/user
Dec 22 23:33:36 unraid emhttp: shcmd (19): /usr/local/sbin/shfs /mnt/user
Dec 22 23:33:37 unraid shfs: duplicate object: /mnt/disk2/.DS_Store
Dec 22 23:33:37 unraid shfs: duplicate object: /mnt/disk3/.DS_Store
Dec 22 23:33:38 unraid shfs: duplicate object: /mnt/disk4/ehthumbs_vista.db
Dec 22 23:33:38 unraid shfs: duplicate object: /mnt/disk4/.DS_Store
Dec 22 23:33:38 unraid shfs: duplicate object: /mnt/disk5/.DS_Store
Dec 22 23:33:38 unraid shfs: duplicate object: /mnt/disk6/.DS_Store
Can you ping it?
Can you ping OUT from unRAID?
If so, post the output from
ps -eaf
The array seems fine.  It appears you did not stop the array when you last rebooted, so 2 transactions are replayed for each drive, and a parity check is started, causing heavy disk activity.  No problem otherwise with the array.
Your IP is set as a static IP from the network.cfg file, and there is no attempt to use DHCP.  The NIC is found and configured correctly, but the following line shows that it does not see a network attached.  It looks like the cable is disconnected, or the router is down.
ifplugd(eth0)[1488]: Initialization complete, link beat not detected.
Thanks. Odd it was working fine and the cables and router I reused were working. Anyway, I got frustrated yesterday and am replacing the drives anyway with a 1.5TB for permanent storage, so I just started pulling the drives last night and connecting to my PC to copy using YAReG to copy from the ReiserFS disks. Anyway, when I get time I'll put the unraid back together and check the connections again. Thanks.
