Introducing boiler, a plugin packaging and distribution system for unRAID
Registry page is not populating using Google Chrome.  I do have some extensions running, but nothing that should be messing with java script or anything to that effect...
Loaded up with internet explorer at work, and it loaded just fine...
Ogi
  • Replies 92
  • Views 23.8k
Ogi
So strange! Are you able to view data at http://boiler-plugins-list.herokuapp.com/ ?
at http://registry.getboiler.com/
I get blank page using both Chrome and Internet Explorer from my work computer.
I will try again from my home computer this evening.
I get a bunch of text:
[{"name":"trolley","description":"A simple package tool for Slackware, designed for unRAID.","owner":"nicinabox","website":"https://github.com/nicinabox/trolley","forks":1,"stars":4,"created":"2013-10-01T08:42:24Z","updated":"2014-01-23T00:35:44Z"},{"name":"sabnzbd_unplugged","description":"boiler package for sabnzbd_unplugged","owner":"dawiki","website":"https://github.com/dawiki/sabnzbd_unplugged","forks":0,"stars":0,"created":"2013-12-19T21:39:26Z","updated":"2013-12-20T19:56:44Z"},
I'll try adding error reporting to see if I can catch potential errors. I have no idea why it wouldn't load for some of you.
No idea either, ill try that other URL when I get back to my desk...
Ogi
This is what I see on that page:
[{"name":"trolley","description":"A simple package tool for Slackware, designed for unRAID.","owner":"nicinabox","website":"https://github.com/nicinabox/trolley","forks":1,"stars":4,"created":"2013-10-01T08:42:24Z","updated":"2014-01-23T00:35:44Z"},{"name":"sabnzbd_unplugged","description":"boiler package for sabnzbd_unplugged","owner":"dawiki","website":"https://github.com/dawiki/sabnzbd_unplugged","forks":0,"stars":0,"created":"2013-12-19T21:39:26Z","updated":"2013-12-20T19:56:44Z"},{"name":"couchpotato_v2_unplugged","description":null,"owner":"dawiki","website":"https://github.com/dawiki/couchpotato_v2_unplugged","forks":0,"stars":0,"created":"2013-12-20T13:50:29Z","updated":"2013-12-20T19:55:45Z"},{"name":"transmission_unplugged","description":"boiler package for transmission_unplugged","owner":"dawiki","website":"https://github.com/dawiki/transmission_unplugged","forks":0,"stars":0,"created":"2013-12-20T13:04:33Z","updated":"2013-12-20T19:57:01Z"},{"name":"sickbeard_unplugged","description":null,"owner":"dawiki","website":"https://github.com/dawiki/sickbeard_unplugged","forks":0,"stars":0,"created":"2013-12-20T21:17:30Z","updated":"2013-12-20T21:49:35Z"},{"name":"plexupdater","description":null,"owner":"dawiki","website":"https://github.com/dawiki/plexupdater","forks":0,"stars":0,"created":"2013-12-20T20:38:59Z","updated":"2013-12-20T21:09:39Z"},{"name":"btsync","description":"BTSync for unRAID","owner":"nicinabox","website":"https://github.com/nicinabox/boiler-btsync","forks":0,"stars":0,"created":"2013-12-23T00:56:47Z","updated":"2013-12-23T01:00:09Z"},{"name":"boiler","description":"The missing package manager for unRAID","owner":"nicinabox","website":"https://github.com/nicinabox/boiler","forks":1,"stars":2,"created":"2013-12-16T21:28:34Z","updated":"2014-01-24T03:22:59Z"},{"name":"tvnamer","description":"","owner":"nicinabox","website":"https://github.com/nicinabox/boiler-tvnamer","forks":0,"stars":0,"created":"2014-01-03T00:49:42Z","updated":"2014-01-03T04:34:18Z"}]
Package API now includes 64 bit packages for 14.1+, including patch versions.
Example:
http://slackware-packages.herokuapp.com/packages/ruby
  "id": 717,
  "name": "ruby",
  "slug": "ruby",
  "versions": [
      "id": 717,
      "version": "1.9.1_p378",
      "build": "1",
      "arch": "i486",
      "patch": false,
      "size_compressed": 3592192,
      "size_uncompressed": 26357760,
      "summary": "ruby (Interpreted object-oriented scripting language)",
      "description": "ruby (Interpreted object-oriented scripting language)\n\nRuby is an interpreted scripting language for quick and easy object-oriented programming.  It has many features to process text files and to do system management tasks (as in Perl).  It is simple, straight-forward, and extensible.\n\nVisit the Ruby project online at http:\/\/www.ruby-lang.org\/",
      "x64": false,
      "package_name": "ruby-1.9.1_p378-i486-1.txz",
      "file_name": "ruby-1.9.1_p378-i486-1",
      "path": "\/slackware\/slackware-13.1\/slackware\/d\/ruby-1.9.1_p378-i486-1.txz",
      "slackware": "13.1"
      "id": 1813,
      "version": "1.9.1_p431",
      "build": "1",
      "arch": "i486",
      "patch": false,
      "size_compressed": 3272704,
      "size_uncompressed": 26603520,
      "x64": false,
      "package_name": "ruby-1.9.1_p431-i486-1.txz",
      "file_name": "ruby-1.9.1_p431-i486-1",
      "path": "\/slackware\/slackware-13.37\/slackware\/d\/ruby-1.9.1_p431-i486-1.txz",
      "slackware": "13.37"
      "id": 3008,
      "version": "1.9.3_p194",
      "build": "2",
      "arch": "i486",
      "patch": false,
      "size_compressed": 4030464,
      "size_uncompressed": 19087360,
      "x64": false,
      "package_name": "ruby-1.9.3_p194-i486-2.txz",
      "file_name": "ruby-1.9.3_p194-i486-2",
      "path": "\/slackware\/slackware-14.0\/slackware\/d\/ruby-1.9.3_p194-i486-2.txz",
      "slackware": "14.0"
      "id": 6838,
      "version": "1.9.3_p448",
      "build": "1",
      "arch": "x86_64",
      "patch": false,
      "size_compressed": 5251072,
      "size_uncompressed": 37396480,
      "x64": true,
      "package_name": "ruby-1.9.3_p448-x86_64-1.txz",
      "file_name": "ruby-1.9.3_p448-x86_64-1",
      "path": "\/slackware\/slackware64-14.1\/slackware64\/d\/ruby-1.9.3_p448-x86_64-1.txz",
      "slackware": "14.1"
      "id": 5577,
      "build": "1",
      "arch": "i486",
      "patch": false,
      "size_compressed": 5234688,
      "size_uncompressed": 37068800,
      "x64": false,
      "package_name": "ruby-1.9.3_p448-i486-1.txz",
      "file_name": "ruby-1.9.3_p448-i486-1",
      "path": "\/slackware\/slackware-14.1\/slackware\/d\/ruby-1.9.3_p448-i486-1.txz",
      "slackware": "14.1"
      "id": 1065,
      "version": "1.9.3_p484",
      "build": "1_slack13.1",
      "arch": "i486",
      "patch": true,
      "size_compressed": 5038080,
      "size_uncompressed": 35891200,
      "x64": false,
      "package_name": "ruby-1.9.3_p484-i486-1_slack13.1.txz",
      "file_name": "ruby-1.9.3_p484-i486-1_slack13.1",
      "path": "\/slackware\/slackware-13.1\/patches\/packages\/ruby-1.9.3_p484-i486-1_slack13.1.txz",
      "slackware": "13.1"
      "id": 5915,
      "build": "1_slack14.1",
      "arch": "i486",
      "patch": true,
      "size_compressed": 4714496,
      "size_uncompressed": 37079040,
      "x64": false,
      "package_name": "ruby-1.9.3_p484-i486-1_slack14.1.txz",
      "file_name": "ruby-1.9.3_p484-i486-1_slack14.1",
      "path": "\/slackware\/slackware-14.1\/patches\/packages\/ruby-1.9.3_p484-i486-1_slack14.1.txz",
      "slackware": "14.1"
      "id": 7175,
      "arch": "x86_64",
      "patch": true,
      "size_compressed": 4710400,
      "size_uncompressed": 37416960,
      "x64": true,
      "package_name": "ruby-1.9.3_p484-x86_64-1_slack14.1.txz",
      "file_name": "ruby-1.9.3_p484-x86_64-1_slack14.1",
      "path": "\/slackware\/slackware64-14.1\/patches\/packages\/ruby-1.9.3_p484-x86_64-1_slack14.1.txz",
      "slackware": "14.1"
      "id": 2158,
      "build": "1_slack13.37",
      "arch": "i486",
      "patch": true,
      "size_compressed": 4526080,
      "size_uncompressed": 36055040,
      "x64": false,
      "package_name": "ruby-1.9.3_p484-i486-1_slack13.37.txz",
      "file_name": "ruby-1.9.3_p484-i486-1_slack13.37",
      "path": "\/slackware\/slackware-13.37\/patches\/packages\/ruby-1.9.3_p484-i486-1_slack13.37.txz",
      "id": 3375,
      "build": "1_slack14.0",
      "arch": "i486",
      "patch": true,
      "size_compressed": 5206016,
      "size_uncompressed": 36874240,
      "x64": false,
      "package_name": "ruby-1.9.3_p484-i486-1_slack14.0.txz",
      "file_name": "ruby-1.9.3_p484-i486-1_slack14.0",
      "path": "\/slackware\/slackware-14.0\/patches\/packages\/ruby-1.9.3_p484-i486-1_slack14.0.txz",
      "slackware": "14.0"
Ogi
I added jslogger to the app to log exceptions. If you are getting a js error, I should be able to see it.
I am able to see view the boiler registry page on my home computer using Chrome with no issues.
Ogi
This is what I see from Chrome.
Nic,
I have my unRaid 6.0beta test system up and running and will gladly help you beta test your 64bit Boiler app.
I would love to get SB/SAB/CP up and running on the 64bit system.
It appears you haven't posted your updates yet for 64bit/Slack 14.1 yet so let me know when you are ready for a beta tester.
Nic,
Rad!
If you happen to get a 6.0 running in VirtualBox PLEASE LET ME KNOW.
Being the BDU that I am, if I install boxcar I assume I can only install packages that are registered in/for boxcar ?
I.e. If I wanted to install flexget I would need to wait for someone to create a boxcar package for it (or try and create in myself). Or can it pull and install any package out there that runs on unRAID Slackware base ?
If you're referring to the web UI boxcar, that was true. Boxcar addons were platform specific and incompatible with existing packages. After a lot of careful consideration I decided this was a Bad Idea.
Boiler is agnostic. It doesn't care what languages you use or what you application does. It's compatible with existing plg plugins if they are converted (and there is a tool that can do this). The packages must be registered in order to be available in the registry.
Think of boiler like a URL shortener for your package. Once registered, anyone can look it up and install it from the registry.
Does that answer your question?
Yep, it does.  Thanks.
what about current unMENU packages.  Is there a converter for them ?
unMENU has a mixed bag of stuff. It's got mostly OS (slackware) packages like kernel-headers, glibc, openssl, etc, but there are also some 3rd party packages included (ntfs3g, powerdown, bandwidth monitor).
a) OS packages are natively supported (boiler relies on trolley to handle this)
b) Boiler only has a converter for plg plugins, currently
If you're interested in installing OS packages in a similar manner to boiler, check out trolley. These packages come officially from slackware, there is no conversion or registry process to use it. It supports packages from 13.1-14.1, and 14.1 64-bit (unreleased).
Hey nicinabox,
So today I loaded up the boiler registry and I now get a message:
There was an error loading the list :(
Again, this is on my work PC using google chrome.  The same PC using IE10 loads it up just fine.
Let me know if there is any further testing I can do.
Hey nicinabox,
Really strange. I believe the issue lies with the cross-origin ajax request. It seems to only affect Windows users.
Hey nicinabox,
I should point out that this PC has been passed down to a number of people before I inherited it, and I've experienced some other weird behavior in non-web based applications.  I haven't been successful in convincing IT to reload from an image.
Hey nicinabox,
Is this a work machine? Are you behind a corporate firewall?
Hey nicinabox,
It is indeed a work machine, I am sure there is some kind of internet filter in place, but I don't think that would be the issue, as the boiler list loads up just fine on IT10 (on the same PC).
Nic,
Me too. Hoping to get some of the apps I was running under 32bit going in 64bit. This looks like a promising approach.
I have unraid 5.0 and i got a second usb to test, so i DL 5.0 nothing on it and installed boiler, i ran the "sources" command that it says to do, did not work so  i rebooted and tried the below command and got this error. Before i install it on my live system can you point me in the right direction.
Tower login: root
Linux 3.9.6p-unRAID.
root@Tower:~# boiler search
/usr/lib/ruby/1.9.1/net/http.rb:800:in `connect': SSL_connect returned=1 errno=0 state=SSLv3 read server certificate B: certificate verify failed (OpenSSL::SSL::SSLError)
        from /usr/lib/ruby/1.9.1/net/http.rb:800:in `block in connect'
        from /usr/lib/ruby/1.9.1/timeout.rb:55:in `timeout'
        from /usr/lib/ruby/1.9.1/timeout.rb:100:in `timeout'
        from /usr/lib/ruby/1.9.1/net/http.rb:800:in `connect'
        from /usr/lib/ruby/1.9.1/net/http.rb:756:in `do_start'
        from /usr/lib/ruby/1.9.1/net/http.rb:745:in `start'
        from /usr/lib/ruby/1.9.1/net/http.rb:1285:in `request'
        from /boot/custom/gems/ruby/1.9.1/gems/httparty-0.12.0/lib/httparty/request.rb:93:in `perform'
        from /boot/custom/gems/ruby/1.9.1/gems/httparty-0.12.0/lib/httparty.rb:486:in `perform_request'
        from /boot/custom/gems/ruby/1.9.1/gems/httparty-0.12.0/lib/httparty.rb:423:in `get'
        from /boot/custom/gems/ruby/1.9.1/gems/httparty-0.12.0/lib/httparty.rb:518:in `get'
        from /usr/local/boiler/boiler/lib/boiler/helpers.rb:129:in `remote_version'
        from /usr/local/boiler/boiler/lib/boiler/helpers.rb:118:in `check_for_update'
        from /usr/local/boiler/boiler/lib/boiler/cli.rb:18:in `initialize'
        from /boot/custom/gems/ruby/1.9.1/bundler/gems/thor-577fcc457805/lib/thor.rb:360:in `new'
        from /boot/custom/gems/ruby/1.9.1/bundler/gems/thor-577fcc457805/lib/thor.rb:360:in `dispatch'
        from /boot/custom/gems/ruby/1.9.1/bundler/gems/thor-577fcc457805/lib/thor/base.rb:441:in `start'
        from /usr/local/bin/boiler:13:in `<main>'
root@Tower:~#
