Introducing boiler, a plugin packaging and distribution system for unRAID
I have unraid 5.0 and i got a second usb to test, so i DL 5.0 nothing on it and installed boiler, i ran the "sources" command that it says to do, did not work so  i rebooted and tried the below command and got this error. Before i install it on my live system can you point me in the right direction.
Tower login: root
Linux 3.9.6p-unRAID.
root@Tower:~# boiler search
/usr/lib/ruby/1.9.1/net/http.rb:800:in `connect': SSL_connect returned=1 errno=0 state=SSLv3 read server certificate B: certificate verify failed (OpenSSL::SSL::SSLError)
        from /usr/lib/ruby/1.9.1/net/http.rb:800:in `block in connect'
        from /usr/lib/ruby/1.9.1/timeout.rb:55:in `timeout'
        from /usr/lib/ruby/1.9.1/timeout.rb:100:in `timeout'
        from /usr/lib/ruby/1.9.1/net/http.rb:800:in `connect'
        from /usr/lib/ruby/1.9.1/net/http.rb:756:in `do_start'
        from /usr/lib/ruby/1.9.1/net/http.rb:745:in `start'
        from /usr/lib/ruby/1.9.1/net/http.rb:1285:in `request'
        from /boot/custom/gems/ruby/1.9.1/gems/httparty-0.12.0/lib/httparty/request.rb:93:in `perform'
        from /boot/custom/gems/ruby/1.9.1/gems/httparty-0.12.0/lib/httparty.rb:486:in `perform_request'
        from /boot/custom/gems/ruby/1.9.1/gems/httparty-0.12.0/lib/httparty.rb:423:in `get'
        from /boot/custom/gems/ruby/1.9.1/gems/httparty-0.12.0/lib/httparty.rb:518:in `get'
        from /usr/local/boiler/boiler/lib/boiler/helpers.rb:129:in `remote_version'
        from /usr/local/boiler/boiler/lib/boiler/helpers.rb:118:in `check_for_update'
        from /usr/local/boiler/boiler/lib/boiler/cli.rb:18:in `initialize'
        from /boot/custom/gems/ruby/1.9.1/bundler/gems/thor-577fcc457805/lib/thor.rb:360:in `new'
        from /boot/custom/gems/ruby/1.9.1/bundler/gems/thor-577fcc457805/lib/thor.rb:360:in `dispatch'
        from /boot/custom/gems/ruby/1.9.1/bundler/gems/thor-577fcc457805/lib/thor/base.rb:441:in `start'
        from /usr/local/bin/boiler:13:in `<main>'
root@Tower:~#
You probably need to run `c_rehash` to relink your certificates. This is an issue that comes up anytime SSL is involved (and boiler uses SSL a lot).
  • Replies 92
  • Views 23.8k
Tower login: root
root@Tower:~#
Thanks but can you EILI5 i typed the c_rehash but got an error.
Tower login: root
root@Tower:~# c_rehash
-bash: /usr/bin/c_rehash: /usr/bin/perl: bad interpreter: No such file or directory
root@Tower:~#
Sorry, I should have mentioned that c_rehash is an openssl utility written in perl. You'll need to install perl to run it. Should be easy enough:
trolley install perl
Then run c_rehash.
Nicinabox, like what your doing here.  Great to see professional development practices applied to a community project like this.
I too had the certificate errors above when I first installed boiler to try it out.  I didn't know what I was doing and haven't had time to troubleshoot.  I took the brute force approach and reran the installer and then everything worked for some reason.  Now I get the error again (several reboots later).
I clearly don't understand what's causing this but perhaps this info might help you address a potential problem (or explain what I did wrong ).
Cheers and best of luck.
Sent from my Nexus 4 using Tapatalk
You're not doing anything wrong.
There's an issue about the certificate stuff on Github. The issue is due in part to the order that dependencies are installed (another part is that unraid doesn't ship with the ca-certificates package). I've talked more about that in hopes of raising some awareness on the issue, since it really does impact the reliability of projects like this.
I have a plan for addressing this issue, but it's not exactly elegant. It would be ideal to have an official solution from Limetech, but it's unlikely that will happen.
Tower login: root
root@Tower:~#
I also have this issue. Running `c_rehash` just gave me this:
Doing /etc/ssl/certs
/etc/ssl/certs is empty.
Same as defected07
Doind /etc/ssl/certs
Whaaa
trolley install ca-certificates
c_rehash
boiler
Boiler is supposed to do all that for you on install. Was there a failure during installation? Did this occur after a reboot for the first time, or immediately after install?
Whaaa
c_rehash
boiler
whoaaa wait, this is the first ive seen this trolley install ca-certificates
i did trolley install perl and that went fine
Whaaa
c_rehash
boiler
and now it works, YEA!!
Commands:
  boiler convert PLG            # Convert a plg to boiler package
  boiler deploy DIR HOST        # Pack and copy to an unRAID machine (for te...
  boiler help [COMMAND]          # Describe available commands or one specifi...
  boiler info NAME              # Get info on installed package
  boiler init [DIRECTORY]        # Create a boiler.json in the specified dire...
  boiler install NAME [VERSION]  # Install a package by name
  boiler list [NAME]            # List installed packages
  boiler open NAME              # Open a package's homepage
  boiler pack DIR                # Pack a directory for distribution
  boiler register NAME URL      # Register a package
  boiler remove NAME            # Remove (uninstall) a package
  boiler search NAME            # Search for packages
  boiler update NAME [VERSION]  # Update package by name
  boiler version                # Prints version
root@Tower:~#
Whaaa
c_rehash
boiler
So i tried this on my main system
install trolley
install boiler
trolley install ca-certs (did not download anything as trolley or boiler installed the certs)
trolley install perl (no DL it found it )
c_hash ( re-did the certs
boiler. fails same error (/usr/lib/ruby/1.9.1/net/http.rb:800:in `connect': SSL_connect returned=1 errno=0 state=SSLv3 read server certificate B: certificate verify failed (OpenSSL::SSL::SSLError)
closed out of telnet session, same problem on a new telnet window.
I cannot reboot it since im am accessing via VM on the unraid,
I will be rebooting once I am on site later this morning.
nicinabox
Got it working, I've been having issues with my router, that i need to reboot it every once in a while.
So i did and re_hash and voila got boiler running. thanks!
nicinabox
I'm working to make this more reliable so issues like this don't continue to be a pain.
nicinabox
Thanks for your hard work,
i was looking at  the commands for boiler , the one that says convert from plg how does that work?
I want to try this on nzbdrone plg that one of the other users wrote.
Whaaa
c_rehash
boiler
Just wanted to confirm this worked for me too, minus the Perl install, because I already had it. Thanks!
Those of you having SSL issues: be sure you're using openssl >= 1.0.1. I just discovered this on my production machine where I was seeing SSL errors and had an outdated openssl (but updated ca-certificates).
Boiler 0.4.0 should take care of this automatically.
Boiler update OpenSSL
Yeas or no ?
Yeas or no ?
`trolley update openssl` because openssl is a Slackware package. ;)
Maybe I should have that functionality pass through so it would be a easier. I'll think about it.
