upgrade from 4.7 to 5.04 slow write and syncback pro issues
I have two issues since I have upgraded to 5.04.
1) Syncback pro no longer has access to read and write files.
I have SMB enabled with export as Yes and all shares are public. I did create a user but doesn't seem to matter since all shares are public? I can access the shares and read and write to them directly. But when syncback pro tries to read the share it has access denied.
(OK so I've been reading some more on the forums and I did not run NewParms, I am doing that now so hopefully it will fix the permissions issues with Syncback Pro)
(Update running NewParms fixed the problem with Syncback, I'll open another thread for my poor write speed)
2) Slow write speeds around 8mb/s, previously it was around 20-25mb/s. I thought adding a cache disk would speed this up. I added a new pci-e controller card (see profile for type) with the cache drive and 2 other 2TB disks are on. All shares are set to use the cache drive.
I have attached my most current syslog. If you need any thing else to diagnose please let me know. Any help is much appreciated.
syslog-20131228-103821.zip
There are no errors indicted in the syslog. The array was running for about 2 minutes. Provide a syslog that includes an error event. Note the time.
