January 26, 201412 yr I built my server with the AMD parts listed in my signature, I was just given some Intel parts. Provided the Mobo fits in the case is there any reason I can't switch over?
January 26, 201412 yr If you have an Intel mobo and CPU, and it fits in the case, there's no reason you can't switch. If the RAM for your existing build isn't compatible with the Intel mobo, then you'd need new RAM also.
January 26, 201412 yr Author Ok but as far as taking my data drives out and plugging them in, I should be ok?
January 27, 201412 yr Ok but as far as taking my data drives out and plugging them in, I should be ok? That should work, yes.
