Replacement case for Azza 910 help
I used to use the Azza Helios 910 case but they do not seem to be available anymore.
I use these cages in my towers and the Azza 910 was awesome for these.
http://www.directcanada.com/products/?sku=11130AC7312&vpn=STB-3T4-E3-GP&manufacture=COOLERMASTER
Can anyone offer any suggestions?
Is a sempron 145 still enough for a tower with 12 drives or should it be a faster CPU now?
Thanks
The Zalman MS800 is about the best replacement.  The other case that was a good replacement was the Nexus Prominent 9, though that case is basically impossible to fine.
The Sempron is enough power, and if you have one sitting around then use it.  You can get a Intel Celeron G1620/G1820 for about the same price and it will get you more power for use later on if you want to install apps on unRAID.
With all that being said.  Send me a PM if you are interested in an AMD board that has never been used and a Prominent 9 case.  I cleaned out my parts cupboard (more a closet really) and found they two things sitting in the back.  I have not done research on price of either and I don't know how much the shipping might be but we can figure that out via PM if you are interested.
