OpenVPN and routing problems
I have OpenVPN client setup so that is constantly connected and re-connect in case it drops.
I have also got my default route set so to eth0: so only apps binding with tun0: (the vpn interface) will use it, and any other traffic won't.
It works quite well, but I have noticed that I cannot connect to Plex from outside my home network anymore, I suspect I have broken the routing but my knowledge in that domain is severely limited.
Here is my routing table:
root@Tower:~# route
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
default         router.asus.com 128.0.0.0       UG    0      0        0 eth0
default         10.10.10.133    0.0.0.0         UG    0      0        0 tun0
10.10.10.1      10.10.10.133    255.255.255.255 UGH   0      0        0 tun0
10.10.10.133    *               255.255.255.255 UH    0      0        0 tun0
109.201.137.163 router.asus.com 255.255.255.255 UGH   0      0        0 eth0
loopback        *               255.0.0.0       U     0      0        0 lo
192.168.1.0     *               255.255.255.0   U     0      0        0 eth0
Can anybody help me understanding what is going on?
Many thanks in advance!
