Problems with Sabnzbd, and Couchpotato.
Hello everyone, I am a noob, who is having a lot of issues with sabnzbd, and couchpotato. Here is my problem. I followed the website instructions on loading Sabnzbd, Sickbeard, and Couchpotato, only to have two out of the three, after I reboot unraid to appear as before when I first installed them. I then would have to reinstall the two again, only to loose them when I reboot. Please help, I do not know what to do? :-[
Sounds like you're not configuring the plugins to store their data on a permanent store. If you have a cache disk, it's best to use this. Personally I use a disk not part of the array (so it doesn't spin up all the time) using SNAP and store the data files there. To configure this, go into the settings of each plugin and look for the configuration options - change this to a persistent location.
