July 9, 201412 yr hey guys im new to unRAID this is my first time using it im trying to install transmission using installplg but i keep getting this errror: file /boot/config/plugins/transmission/transmission.png: downloading from --no-check-certificate https://github.com/downloads/Influencer/UNplugged/transmission.png ... WARNING: cannot verify github.com's certificate, issued by `/C=US/O=DigiCert Inc/OU=www.digicert.com/CN=DigiCert SHA2 Extended Validation Server CA': Unable to locally verify the issuer's authority. OpenSSL: error:14077410:SSL routines:SSL23_GET_SERVER_HELLO:sslv3 alert handshake failure Unable to establish SSL connection. bad download, deleting its really annoying because i dont know what to do, I've tried running installplg transmission.plg but i get the same message everytime i hope someone could help please..
July 9, 201412 yr I would suggest you don't try and use Influencers plugins at this point. Use the ones from PhAzE as he's updated them for UnRAID 5/6. The influencer plugins are fairly old and outdated (though theoretically they should still work in most instances).
July 9, 201412 yr Author hey thanks for the advice it was greatly appreciated i used the ones from PhAzE and got it to work
