August 2, 201412 yr I have attached a syslog to this. I have 3 issues I need help with please. Forget the ethernet going down at the end of the syslog, I just had to reset the router. My monthly parity check ran on August 1st at about 1.30am and about 5 hours into it the webGui became unresponsive, it had been working fine during the parity check a few hours earlier. I have a .TemporaryItems folder that I understand is created by my mac over network shares but I cannot delete it as I can't see it in finder, also is it needed as the cache_dirs scans it. The third issue is in relation to my micro SD card giving an error about running a check on the flash card due to a bad shutdown. I have posted this before and a few users have seen this error. I have the lock switch off on my SD card holder but I have seen a error come up on my IPMI view screen about write protected flash when doing a reboot a few weeks back, the Micro SD card is a Sandisk 8Gb UHC 1 and maybe it is to fast or incompatible with unRAID. Thanks syslog.txt
August 2, 201412 yr If you can, plug the flash drive into a windows machine and run chkdsk (windows may offer to repair the disk as soon as you plug it in). I haven't had much luck repairing fat volume!es in Linux.
August 2, 201412 yr Author I tried with a mac and no luck. I will try windows, Im wondering if it is read only on boot or something because I can drag and drop plugins onto it fine.
