August 20, 201412 yr I am getting this error: Warning: Unknown: failed to open stream: No such file or directory in Unknown on line 0 Fatal error: Unknown: Failed opening required '/usr/local/emhttp/plugins/webGui/include/local_prepend.php' (include_path='.:') in Unknown on line 0 I can ssh and we over to unmenu but not the standard web gui. Syslog attached. I am in dire need of the array back online to get my data. syslog-2014-08-19.txt
August 20, 201412 yr Your syslog indicates you are trying to run Dynamix with unRAID 6b5a. Dynamix is not compatible unRAID 6b4 and later. See here
