article: Running OSX Mavericks under KVM with QEMM
sure thing, sounds good.
  • Replies 128
  • Views 41.3k
Alright so here is what I want you to do.
ssh into unRAID and cd to where ever you keep your VM images.
1. type "nano test_osx"
2. Paste the following: Put in the OS X Key, Change the VNC IP, & Change the kernel and drive to match where ever you have them saved
/usr/bin/qemu-system-x86_64 -enable-kvm -m 2048 -cpu core2duo,vendor=GenuineIntel \
        -machine q35 \
        -usb -device usb-kbd -device usb-mouse \
        -device isa-applesmc,osk="PUT THE KEY HERE" \
        -kernel /mnt/vmdisk/vm_images/extra/chameleon_svn2510_boot \
        -smbios type=2 \
        -device ide-drive,bus=ide.2,drive=MacHDD \
        -drive id=MacHDD,if=none,file=/mnt/vmdisk-2/vm_images/Yosemite.img \
        -vga std \
        -vnc 192.168.1.50:5 \
3. type "chmod +x test_osx"
4. type "./test_osx"
5. Go to your VNC program and type in the VNC address (the above example would be 192.168.1.50:5905)
See if that boots into OS X and let me know!
It boots in a circle to the Chameleon loader.
I should point out that this HDD image never got installed, so should I point to the installer file somewhere as well?
YES! It works if I add the DVD lines like so:
        -machine q35 \
        -smbios type=2 \
        -device ide-drive,bus=ide.1,drive=MacDVD \
        -drive id=MacDVD,if=none,file=/mnt/extra/vm_tools/Yosemite.iso \
        -drive id=MacHDD,if=none,file=/mnt/extra/vms/Yosemite/Yosemite.qcow2 \
        -vga std \
        -vnc 0.0.0.0:5 \
It's installing OSX as I type this :)
Now to be able to make it permanent...
Is this the farthest point that you have been with creating an OS X VM? or have you gotten further with the guide?
OK, that's good news. Now the next step would be to figure out how that KVM script is handling the "geniuneintel" part and then convert it to XML. I know that with virsh you can do a "virsh dumpxml" command but the KVM script is not defined with virsh currently. Does anyone know of a way to convert the script to XML?
BTW, that script above is how @peter_sm and I first installed OS X (well how peter first installed OSX). It was a pain in the butt to work with when you are used to XML.
I found it fine to follow (from a Linux cmdline perspective) ;)
I'm not sure how to get it into XML format either, but so far it's installing fine!
Not too sure how to work nano?
I have the script made up like Tophicles and I can get into nano and enter the text but nothing seems to happen.
Nice work on getting to install for Tophicles though :D
Would you show me your output of the following:
virsh domxml-from-native qemu-argv /path/to/test_osx
oh sorry, once you get the text entered, use "ctrl+x" to exit and save from nano
@jude, I have a theory!
Will you enter this at the end of your OS X XML:
<qemu:arg value='-cpu'/>
<qemu:arg value='core2duo,vendor=GenuineIntel'/>
Entered text saved it in nano and exited and then did the following. What am I missing?
root@Tower:/mnt/disk/vmdisk/Image Media# nano test_osx
root@Tower:/mnt/disk/vmdisk/Image Media# chmod +x test_osx
root@Tower:/mnt/disk/vmdisk/Image Media# ./test_osx
./test_osx: line 1: usr/bin/qemu-system-x86_64: No such file or directory
I think you've got it. Installing !
BOOM!
How good are you? :D
Many thanks
cursor doesn't really track properly and makes it tuff to click on the continue button. Quite funny
I can confirm that the addition of
Just before the </domain> works a treat! :)
This is expected behaviour - from the guide:
(The mouse is going to be laggy until we get everything installed) Hint: Move the mouse faster to get the cursor to move farther.
yup, found the guide again and currently waiting for the install to finish so I can work through the rest including the mouse. This is great.
BTW I updated the guide and cleaned up the XML a bit.
Changes:
Added vcpupin
Changed qcow2 disk to img
Changed hard drive bus from ide to sata
Changed memballoon to none
Fantastic. Working really well. Thanks
Absolutely awesome. You nailed it.
Very cool to be able to run OSX10.10.3, a Win8.1 Gaming/HTPC, Dockers and unRaid on the same hardware simultaneously.  :)
Thanks again
archedraft/jude,
Would you be able to to post a short video on youtube, showing how you use your setup ?
To get an idea how you switch between os' and how responsive they appear on screen.
Hopefully you can accommodate.
Thanks in advance !
Currently I do not have the time but to give you an idea: I have an windows VM on one desk with dual monitors keyboard and mouse and on another desk I have my OS X vm that has its own monitor keyboard and mouse. Both are running at the same time. Two people can work on the computers at once. It like have two computers.
