article: Running OSX Mavericks under KVM with QEMM
  • Replies 128
  • Views 41.3k
I had the same issue, need to move the USB pass trough away from this part.
Right, it's either here or in the devices section as part of a hostdev block. But unfortunately the hostdev blocks that's working for the Windows VM isn't for the Mac, hence why I'm trying it here. I'm assuming you have usb controller passthrough working correctly via a hostdev block?
I have this setting know, USB mouse and a keyboard
<hostdev mode='subsystem' type='usb' managed='yes'>
      <source>
        <vendor id='0x046d'/>
        <product id='0xc52b'/>
      </source>
    </hostdev>
      <source>
        <vendor id='0x045e'/>
        <product id='0x0040'/>
      </source>
    </hostdev>
I see, you're not passing in a controller simply the devices. I'm trying to pass in the controller.
